Which belt to choose? #201756
01/23/09 10:12 AM
01/23/09 10:12 AM
Anonymous OP
Anonymous OP
Im going to install a rollcage in the duster, new seats and new belts, but what belts to choose? Wraparound belts or bolt-on? Will both work with a rollcage? Anyone of these two to prefeer?
Please guide me!
Thanks!
//Chris
Re: Which belt to choose? #201757
01/23/09 10:26 AM
01/23/09 10:26 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Go with the wrap around unless you have a tab welded on for a bolt in belt.
Re: Which belt to choose? #201758
01/23/09 11:11 AM
01/23/09 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Please guide me!
Thanks!
//Chris
My shoulder belts are wrap around but all of the lower
belts are bolt on
Re: Which belt to choose? [Re: MR_P_BODY] #201759
01/23/09 11:53 AM
01/23/09 11:53 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Please guide me!
Thanks!
//Chris
belts are bolt on
Same here
Re: Which belt to choose? [Re: WILD BILL] #201760
01/23/09 12:22 PM
01/23/09 12:22 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You could go ether way as you are just having the cage installed. My view is the rap is more user friendly. Other than that you should look at the cam lock type belt, it'll cost a little more but worth every penny.
Re: Which belt to choose? #201761
01/23/09 02:23 PM
01/23/09 02:23 PM
I have had both, the wrap around slide around and don't stay in place like the bolt ons do. I like the bolt ons best I drill a hole thru the roll bar cross bar behind the seat and bolt both shoulder harness to that location Make sure your crossbar meets NHRA specs in realation to your shoulders when sitting in the seat first , if that is a concern at your local tracks The harness attaching point is suppose to be no lower than 6 inches below your shoulder, if I remember correctly, check the rule book to make sure what the exact spes. are
Re: Which belt to choose? [Re: Cab_Burge] #201762
01/23/09 03:15 PM
01/23/09 03:15 PM
Anonymous OP
Anonymous OP
Thx everyone, i think ill have a second look at the cam-lock belts after all
Are all the bolt-ons supposed to bolt the shoulder belts to the cross-bar? And wouldnt it count as a 4-point if you only had one attaching point for the shoulder belts on the crossbar? Arent 5-point supposed to have two attach-points for the shoulder belts?
//Chris
Re: Which belt to choose? #201763
01/23/09 11:24 PM
01/23/09 11:24 PM
//Chris
The shoulder belts must be attached to the cross bar no higher than the drivers shoulders or no lower than four inches below the drivers shoulders, not six inches The amount of points of contact are determined by how many places the belts touches your body, not how many points they are attached to on the car, I think anyway NHRA does not allow the Y type belts any more but they do not prohibit using a common attaching point on the shoulder straps according to section 19 of the general rules sub chapter 10:5 on page 281 in the 2009 rule book they do prohibit using bolts that go thru the belt webbing instead of using the proper hardware
