I have always used Moog with great results, lately folks have been talking about the quality but personally cant think of any troubles I've had with them. I have built 5 or 6 complete front ends in the last few years with Moogs, I did replace one set of lower control arm bushings due to what I thought to be checking. They had been installed for a couple of years but not put on the car. I found it during an inspection of the parts for final assemble so I replaced them just for GP. I agree with Rock Auto, you can get some things on close out at killer dealers if you get lucky.
I used 1 PST kit years ago (as in 20), they bushings started falling apart in a year or so of driving. I promptly ripped it apart and isntalled Moog which are still good today, same storage and usage conditions.
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Here is a list of Moog part numbers I pick up from somewhere.
________________________________________
View: Balljoints
Control Arm Bushings
Strut Rod/Sway Bar Bushings
Pitman/Idler Arm and Bushing
Tie Rod Ends
Back To The Top
UPPER BALL JOINT P/N
HP STD.
57-64 All exc. A body K720A K772
65-73 C body " "
65-79 B body " "
70-74 E body " "
73-76 A body " "
76-80 F body " "
79-81 R body " "
77-89 M body " "
80-83 J body " "
60-62 Valiant/Lancer K706 K704
62-72 A body " "
60-75 Imperial K778
74-78 C body "
LOWER BALL JOINT P/N
L R
62-64 All exc. A body K781 K783
65-72 B body " "
70-74 E body " "
73-76 A body " "
65-73 C body K7003 K7005
62-72 A body w/o disk brakes K785 K787
65-72 A body w/ disk brakes K7021 K7023
60-62 Valiant/Lancer K701 K703
73 B body (Threaded Fit) K719 K719
73-79 B body (Press Fit) K7069 K7069
76-80 F body " "
79-81 R body " "
77-89 M body " "
80-83 J body " "
60-66 Imperial K727 K727
67-75 Imperial K7025 K7025
74-78 C body " "
Back To The Top
UPPER CONTROL ARM KIT P/N
Shafts Std Bushings Eccentric Bushings
62-64 All exc. A body K7030 K408 K7103
65-72 B body " " "
70-74 E body " " "
60-62 Valiant/Lancer " " "
62-76 A body " " "
65-73 C body K7036 K7006 K7104
60-66 Imperial K7028 K325
67-73 Imperial NR K7044
73-79 B body K7105 K7058
79-81 R body " "
74-78 C body NR K7070
74-75 Imperial NR "
76-80 F body K7091 K7084
77-89 M body " "
80-83 J body " "
LOWER ARM BUSHING KIT P/N
60-62 Valiant/Lancer K790
62-64 All exc A body K791
65-72 B body "
62-76 A body "
70-74 E body "
60-66 Imperial K318
57-62 Chrys. Saratoga, New Yorker "
63-64 Chrysler New Yorker K317
62-64 Chrysler Windsor, Newport, 300 "
67-73 Imperial K7043
65-73 C body K7007
74-78 C body K7071
74-75 Imperial "
73-79 B body K7059
79-81 R body "
76-80 F body K7097
77-89 M body "
80-83 J body "
Back To The Top
STRUT ROD KIT P/N
Improved Standard
57-65 B body K7039 K354
57-64 C body " "
57-66 Imperial " "
66-72 B body (+73-74 Police/Taxi) K7026 K7016A
70-74 E body " "
67-73 Imperial " "
65-73 C body K7027 K7019A
60-62 Valiant/Lancer K7040 K355
62-72 A body " "
73-76 A body K7068
73-74 B body (to 10-19-73) "
74-79 B body (from 10-19-73) K7085
74-79 C body "
SWAY BAR KIT P/N
Bushings End Link
66-69 B body K5110
65-72 A body "
70-72 B body K5241 K440
70-74 E body " "
73-76 A body " "
65-73 C body K7061, K7064 NR
73-74 B body (exc. 74 Police) " " "
74 B body Police K7062, K7064 "
75-79 B body " " "
67-75 Imperial (7/8" bar) K8258 K5110
74-78 C body (7/8" bar) " "
71-75 Imperial (1" bar) K7096 K5110
74-78 C body (1" bar) " "
76-80 F body (1-1/8" bar) K7108 K7087
80-89 M body (1-1/8" bar) " "
80-83 J body (1-1/8" bar) " "
77-79 M body K7092 "
76-80 F body (exc. 1-1/8" bar) " "
80-89 M body (exc. 1-1/8" bar) " "
80-83 J body (exc. 1-1/8" bar) " "
Back To The Top
PITMAN ARM
Manual Power
60-62 Valiant/Lancer K789 K789
62-64 All exc. A body K780 K780
65-70 B body " "
71-72 B body K7102 K7102
70-74 E body " "
62-66 A body K7020 K7020
67-72 A body (exc 383) K7074 K7074
73-76 A body K7075 K7076
73-79 B body " "
65-73 C body K7032 K7072
67-75 Imperial K7024 K7024
74-78 C body K7121 K7121
76-80 F body K7100 K7101
77-89 M body " "
80-83 J body " "
IDLER ARM & BUSHING
Arm Bushing
65-68 C body (thru 4-1-68) K7014 K7017
67-68 Imperial " "
63-66 Imperial (exc. 64-66 Convertible) K7009 "
68-73 C body (from 4-1-68) " K7046
69-75 Imperial " "
74-78 C body K7073 "
60-62 Valiant/Lancer K7012 NR
62-64 All exc. A body K779 NR
62-66 A body K414 NR
67 A body K7022 NR
65-67 B body " NR
68-70 B body K7041 K7045
70-74 E body " "
68-70 A body K7042 "
71-72 A body " K7049
73-76 A body K7086 "
76-80 F body " "
77-89 M body " "
80-83 J body " "
71-72 B body K7041 "
73-79 B body K7066 "
Back To The Top
TIE ROD ENDS
Size Sleeve Outers Inners
62-64 All 9/16" ES319S ES319R ES319L
62-69 B body " " " "
62-69 A body " " " "
60-62 Valiant/Lancer " " ES277RL ES278RL
70-72 B body " " ES401R ES401L
70-74 E body " " " "
70-76 A body " " " "
73-79 B body " ES430S " "
76 F body " " " "
77-80 F body " ES2016S " "
77-89 M body " " " "
80-83 J body " " " "
62-63 Imperial 11/16" ES500S ES321RL ES669, ES670
64-66 Imperial " " ES335R, ES335L ES693, ES694
67-73 Imperial " " " " ES372RL
65 C body (<3-1-65) " " ES352R ES352L
65-73 C body (>3-1-65) " ES355S " ES355RL
74-78 C body " ES440S " "
74-75 Imperial " " " "
advert
e-mail me and I can send you the list on a better format later. My member name at yahoo.
