Engine Masters #2014713
02/18/16 03:49 PM
02/18/16 03:49 PM
In a house near you
Street Monkies Offline OP
In a house near you
http://www.hotrod.com/how-to/engine/1504-this-chrysler-big-block-has-a-twist-windows-in/
Is it me or would you guys think of doing thing's differently with the combination of this engine?. I can understand the rules, and certain thing's, but they were plenty of things they could have done differently and still be within the rules. Is anyone else think they should have went more lift on the cam, touch more duration, bigger chamber in this case for better piston design, longer connecting rods, different intake manifold, more bore, different direction on head ports, especially helping that exhaust port out, and many more thing's to list. Very trick piece overall though. Let's hear your opinions.
Re: Engine Masters [Re: Street Monkies] #2014720
02/18/16 03:56 PM
02/18/16 03:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
In my opinion a lot of the engine master guys leave things on the table because they are entering an engine that is not built specially for the challenge, just something they thought would be fun to show case. That is the only way I can explain certain things I see in the contest, engines built to peak way past the cutoff RPM, not maxing out compression or quench or... tons of things, the winners/runners up do everything to win, maybe the firs 5 places, the others apear to just show up with an engine that is a hoge-podge of whatever is laying around the shop.
Re: Engine Masters [Re: HotRodDave] #2014731
02/18/16 04:16 PM
02/18/16 04:16 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Most of these engines make great power on the dyno but would never run the number at the track. That would be a real challenge. Run them on the dyno then put them in cars and run them.
Re: Engine Masters [Re: Street Monkies] #2014732
02/18/16 04:18 PM
02/18/16 04:18 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I would like to see dyno numbers before and after the windows in the block. To see if it made a difference.
Of course the responses here will always be "add 5000 more variables by putting in a car and taking it down a track....that's real numbers! instead of using the exact same dyno for a contest."
Re: Engine Masters [Re: Street Monkies] #2014742
02/18/16 04:45 PM
02/18/16 04:45 PM
In a house near you
In a house near you
I am going to guess a lot of these parts weren't just laying around. It just seems to me that this motor is way more trick then it needs to be to make that kind of power. The intake flow on the heads dictate it should be making over 700 hp. I'm sure a lot of it was lost trying to make as much torque as possible with different parts limiting hp out put, but it seems to me with some changes it could have made the torque, and made the hp it should have. That's great that they pulled off the Windows in the block, but I don't think that was needed, better parts matching was needed more.
Re: Engine Masters [Re: Street Monkies] #2014747
02/18/16 04:56 PM
02/18/16 04:56 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Remember the goal is to make the most from 3000 to 6500, yes the heads and such can be made to put down way more hp but it would be at the top, scores are calculated from torque and hp.
Re: Engine Masters [Re: Street Monkies] #2014773
02/18/16 05:29 PM
02/18/16 05:29 PM
In a house near you
In a house near you
Correct about the rpm window, but that motor ran out of smoke right at 6,000. Still had another 500 rpm which is plenty to make more torque, and power. If the torque curve carried a little higher so would the hp. I'm going to go with the cam mostly on that one. The heads can flow what ever, but if you can't get the valves to open/shut at the right time it's not going to work as good as it should.
Re: Engine Masters [Re: fbs63] #2014804
02/18/16 06:20 PM
02/18/16 06:20 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Hollis Page (HP Engines), Larry Smith (30 year NASCAR Head porter and Engine builder) and I are talking about teaming up for the 2016 EMC in the small block class using an R3 based block.
WIZE
In Car:
Re: Engine Masters [Re: Street Monkies] #2014842
02/18/16 07:01 PM
02/18/16 07:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah that particular engine, de-bored? HUh? Lets shroud the valves (in a mopar BB with crappy valve placement already) more and see if it makes more hp!
As for testing the windows, simple test it, pull the window cavern thingys and put a flat plate blocker back on it and test again.
Re: Engine Masters [Re: Streetwize] #2014874
02/18/16 07:36 PM
02/18/16 07:36 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Thumbs up!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Engine Masters [Re: Street Monkies] #2014961
02/18/16 09:19 PM
02/18/16 09:19 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is some very "Smokey Yunick-esque" rule interpretation there. Didnt they build a 361 B based engine a couple years back too?
Mopar to the bone!!!
Re: Engine Masters [Re: Streetwize] #2014981
02/18/16 09:50 PM
02/18/16 09:50 PM
In a house near you
In a house near you
Cool I'd like to do something like that some day. Small or big block mopar. You get a handful of knowledgeable people together with some ideas, and it might just get you famous. Should be able
To make some good power. I know i have a lot of ideas on something's. I hope you guys are able to do it. That would be way cool!
Re: Engine Masters [Re: 72Swinger] #2015017
02/18/16 10:53 PM
02/18/16 10:53 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Different builder but yes someone did.
http://www.hotrod.com/how-to/engine/1401-mopar-412-big-block/
It's interesting to see what these guys come up with, and whether it works or not.
Re: Engine Masters [Re: tsanchez] #2015028
02/18/16 11:08 PM
02/18/16 11:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So they no longer factor in price of build like they used to?
Re: Engine Masters [Re: Street Monkies] #2015102
02/19/16 12:40 AM
02/19/16 12:40 AM
The Great White North
RAMM Online happy
RAMM  Online Happy
The name of the game is small bore/big stroke and forget peak power its all about the average, oh and try to stay around 400 cubes. Check out Kaase's 404 cube Boss, had a 3.695" bore x 4.700" stroke but benefitted from the Hemi heads obviously. As far as doing things differently of course there are tons of things to try and do differently but these things take $$$ and time. October comes up pretty fast for the average shop and I am an average shop. Jump in and give it a try. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Engine Masters [Re: fbs63] #2015113
02/19/16 12:45 AM
02/19/16 12:45 AM
RAMM Online happy
RAMM  Online Happy
There is a member here that has a 318 build that was used in the EMC 2010 contest that runs quite well. Also our 2009 471 engine which made 683 hp on our dyno with a single 4150 went into a customers Pro-touring '69 Charger and put down 587 HP at the hubs--runs slow at the track though with no 60' and a TKO tranny that you cant grab 3rd with--runs mid 11's @ some stupid MPH.
Also might ask Brett Miller also a member here what his 2011 EMC engine ran at the track in his car.
J.Rob
Re: Engine Masters [Re: CTD5.9] #2015119
02/19/16 12:48 AM
02/19/16 12:48 AM
RAMM Online happy
RAMM  Online Happy
Working on it for Spec Bigblock class this year, I want to know too. J.Rob
Re: Engine Masters [Re: Street Monkies] #2015129
02/19/16 12:55 AM
02/19/16 12:55 AM
RAMM Online happy
RAMM  Online Happy
The cross section of the port was 2.850" which was the target for maximum torque over the entire RPM range. I could have installed a larger cam and come very close to 700hp or more but the score would have sucked. I could have executed the port work better and should have spent way more time on the headers. I also burned up too much time on the EFI when the carb scored better. Its always the goal to make "the HP" along with "the TQ" but actually doing it is something else all together. J.Rob
Re: Engine Masters [Re: Streetwize] #2015136
02/19/16 01:00 AM
02/19/16 01:00 AM
RAMM Online happy
RAMM  Online Happy
That's awesome! Obviously you are eyeballing the Smallblock Shootout class? Hope you bring a beast of a 350 or larger R3. J.Rob
Re: Engine Masters [Re: RAMM] #2015140
02/19/16 01:04 AM
02/19/16 01:04 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Two questions:
1. Are you talking about your super modified Victors, or the Procomps you also used?
2. Is the 2.85" measurement the Average CSA, or the Minimum CSA?
