purpose of foam gasket between dust shield/spindle? #201490
01/22/09 09:35 PM
01/22/09 09:35 PM
USA
Suregrip391 Offline OP
USA
Hi Guys, whats the purpose of that foam gasket between the disc brake dust shield and the spindle on say a 73-76 A-body setup? Are they available or are most guys using RTV or the 'right stuff" in place of it? Thank you!
Re: purpose of foam gasket between dust shield/spindle? [Re: Suregrip391] #201491
01/22/09 09:40 PM
01/22/09 09:40 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: purpose of foam gasket between dust shield/spindle? [Re: Suregrip391] #201492
01/22/09 09:45 PM
01/22/09 09:45 PM
NY NY
3
340duster340 Offline
NY NY
pretty sure you can still get them new, i bought a set a few years back.
if i had to guess they are probably to prevent squeaks and rattles. otherwise, with out the gaskets it would be metal to metal.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: purpose of foam gasket between dust shield/spindle? [Re: 340duster340] #201493
01/22/09 09:54 PM
01/22/09 09:54 PM
BDW Offline
BDW  Offline
I wasn't going to use it, but once you start putting it together you'll notice there will be a gap that would allow dirt to enter.
The gasket covers the space.
Re: purpose of foam gasket between dust shield/spindle? [Re: Suregrip391] #201494
01/22/09 10:13 PM
01/22/09 10:13 PM
to keep dirt/debris out
Re: purpose of foam gasket between dust shield/spindle? [Re: RapidRobert] #201495
01/22/09 10:29 PM
01/22/09 10:29 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I was able to get some from NAPA last year.
Re: purpose of foam gasket between dust shield/spindle? [Re: GoodysGotaCuda] #201496
01/22/09 10:37 PM
01/22/09 10:37 PM
Houma, Louisiana
twister360 Offline
twister360  Offline
Houma, Louisiana
They are probably available through
http://shop.detroitmuscletechnologies.co...57.qscstrfrnt04
:iagree
I got mine from Detroit Muscle.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: purpose of foam gasket between dust shield/spindle? [Re: twister360] #201497
01/22/09 10:49 PM
01/22/09 10:49 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Leave the foam gasket on the bench with the dust shield where it belongs.
You'll get better cooling, etc, and not have to worry about gravel/etc.. getting stuck between the rotor, and the sheild again.
FWIW I've done at least a dozen brake swaps with no dust shields, and never had a problem.
Most modern applications do not have a dust shield on the rotor, as they are useless .
Re: purpose of foam gasket between dust shield/spindle? [Re: dave571] #201498
01/23/09 12:19 AM
01/23/09 12:19 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I actually will be doing that whenever I mess with my brakes again. I have a problem with rocks getting stuck on my ford ranger while off road. extremely annoying!
2020 RAM 1500
Re: purpose of foam gasket between dust shield/spindle? [Re: GoodysGotaCuda] #201499
01/23/09 10:15 AM
01/23/09 10:15 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And if you are so inclined to use the seals,go to any craft store and buy a 8 1/2 x 11 sheet of foam for a buck and make your own and you'll have some left over to use somewhere else.
Re: purpose of foam gasket between dust shield/spindle? [Re: 62maxwgn] #201500
01/23/09 08:13 PM
01/23/09 08:13 PM
USA
USA
Thanks guys! I just made my own this evening from some foam type packaging material I had laying around. Looks like the same material as the original stuff I took off so that worked well! Thanks again for the tip.. musta had brain freeze as I never thought to make my own...duh!
Re: purpose of foam gasket between dust shield/spindle? [Re: Suregrip391] #201501
01/23/09 08:15 PM
01/23/09 08:15 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I am 100% sure it was put there for you to ask why....????
Re: purpose of foam gasket between dust shield/spindle? [Re: 340dart4spd ] #201502
01/23/09 08:17 PM
01/23/09 08:17 PM
USA
USA
Yeah, sure seems that way at times....
