Reinstalling B Body Quarter Glass - What's Needed? #2014103
02/17/16 06:31 PM
02/17/16 06:31 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
So are there bushings that mount the quarter glass on a 68-70 B hardtop? Anyone know where they would be available? The FSM is a little vague.
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2014503
02/18/16 05:34 AM
02/18/16 05:34 AM
Spokane Valley, WA
Spokane Valley, WA
Dang! No takers? Where are all my b body buddies today???
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2014557
02/18/16 11:13 AM
02/18/16 11:13 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.rtspecialties.net/search.asp
Roller parts available at R/T Specialties. Search "Window ".
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2014585
02/18/16 12:14 PM
02/18/16 12:14 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Be sure and get the rollers and the black washers used to cushion the glass between the aluminum frame and the washer of the attaching bolt. Use vacuum line to fill the hole in the glass or the edges of the bolt may break the glass. If you have not taken the windows out yet, be very carefully taking the bolts out. Steel and aluminum don't mix well so the bolt gets corroded and they easily break off in the aluminum.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: fastmark] #2015254
02/19/16 06:44 AM
02/19/16 06:44 AM
Spokane Valley, WA
Spokane Valley, WA
Oh boy. I bought the car with the glass out... I sure hope the bolts aren't busted off. Better add antisiese compound to those threads. I'll know what I'm facing tomorrow thanks much for the tips.
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2015284
02/19/16 10:22 AM
02/19/16 10:22 AM
North EAST
seventy Offline
seventy  Offline
North EAST
They sell the kits at vanns and on ebay, I seen hardware kits also in the past..
It has to be the worst part of assembling the car, lol, I would rather put 3 wiper assemblies together than mess with the 1/4 mechs...
good luck...
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: seventy] #2015565
02/19/16 05:47 PM
02/19/16 05:47 PM
Spokane Valley, WA
Spokane Valley, WA
good luck...
Looking at all the adjusting bolts I can see why it's a pain. The factory must have had a nice little jig to align it. The mechanisms are both still in the car and haven't been removed so it should be easy, but if I have to drill out a bolt, ugh. I WILL try to scribe around all of the bolts so that I can get it close when it goes back in. If you hear someone screaming this weekend, you'll know who it is...
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: seventy] #2015647
02/19/16 08:13 PM
02/19/16 08:13 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
good luck...
You HDTP guys have it easy, the convertibles are real handcutting, knuckle busting beatches......
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2015654
02/19/16 08:30 PM
02/19/16 08:30 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I would advise getting drunk before you start reassembly. That way, the pain will be dulled.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2015656
02/19/16 08:32 PM
02/19/16 08:32 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Yeah, on my 1970 Sport Satellite I took the assemblies out and re-installed them . . . the factory must have installed these BEFORE the rear quarter panels went on, would seem the easiest way to do it !!! . . . good luck !!
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: a12rag] #2016030
02/20/16 01:36 PM
02/20/16 01:36 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
No, they were installed afterwards...
I have been "told" by some oldtimers, when I was doing Auto Glass, that some Riviera's ( 60's era), you did have to remove the door skin to install the door glass.. Never had to do one, so I cant say for sure..
To the OP. Take your time and have another person help. They can hold it while you snake it back in. Crank the regulator one way or the other while installing to help get it back in and fastened.. If your painted, tape off the edges with some heavier blue masking tape..
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2016425
02/21/16 01:19 AM
02/21/16 01:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Josh's parts has the kits, plus a Moparts discount, setting up the rear qtr glass can be a challenge at times, just make sure the channel openings in the aluminum frames holding the glass are free from corrosion, nicks/gouges/etc, use a premium quality slick as dodo grease for the rollers/guides/regulators, make sure the door glass/vent frame is adjusted where you want it to be first, as the rear qtr glass has a lot more adjustment travel
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: DAYCLONA] #2016546
02/21/16 12:31 PM
02/21/16 12:31 PM
Spokane Valley, WA
Spokane Valley, WA
Well, I got in the garage today and took a look at the glass bolt locations and here's what I found.
It takes a real genius to break off ALL FOUR BOLTS before adding penetrating oil...
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2016832
02/21/16 09:17 PM
02/21/16 09:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
In Daytona's photo above of the install kit, the four top clips are the most difficult things to install in the world..
Another clip is made that sets on the shaft and then push it sideways to lock it. Much easier to use and works as good. Go to a local auto glass store, they should be able to help you..
I have spent HOURS trying to get the above clips to work and failed...
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: minivan] #2016975
02/21/16 11:46 PM
02/21/16 11:46 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
I agree.ended up re-using my old rusty ones,glad to know it wasn't just me!
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: minivan] #2017054
02/22/16 01:31 AM
02/22/16 01:31 AM
Spokane Valley, WA
Spokane Valley, WA
So are you talking C clips? I am going to have to pull it all out because all four glass bolts were snapped off so I will know soon what you are talking about. At this point, I don't even know if the little roller wheels need replaced. I guess this gives me a chance to clean it all real good and lube everything as Mike suggested.
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: DAYCLONA] #2017055
02/22/16 01:32 AM
02/22/16 01:32 AM
Spokane Valley, WA
Spokane Valley, WA
Thanks for the tip, Mike!
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: DAYCLONA] #2017059
02/22/16 01:35 AM
02/22/16 01:35 AM
Spokane Valley, WA
Spokane Valley, WA
Are some of the wheels pictured spacers/gaskets that go between the frame and the glass and the bolt and the glass?
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2017126
02/22/16 02:47 AM
02/22/16 02:47 AM
Spokane Valley, WA
Spokane Valley, WA
Well, I am having zero luck finding the window to frame attaching bolts online. Anyone know that thread, how long? what size washer? I am assuming it is like a body bolt with kept washer.
Thanks!
I’m listening.
Re: Reinstalling B Body Quarter Glass - What's Needed? [Re: Big Bad Bee] #2017280
02/22/16 11:42 AM
02/22/16 11:42 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
It's got a 7/16" hex and 1" washer. 1/4-20 thread. R/T Specialties has them.
They're also used to hold the headlight brackets to the fenders on a '70 Coronet.
http://www.rtspecialties.net/proddetail.asp?prod=0784857
