stealth heads #2012665
02/15/16 08:08 PM
02/15/16 08:08 PM
central new york
pettyblue440 Offline OP
central new york
Considering buying stealth heads for my 383. I remember reading some people switch out the retainers and wanted to refresh my memory on that. I should be fine using my stock rockers, ect correct?
I know this has been talked about a ton on here. I tried search and had no luck, so if someone saved an old thread please link to it. thanks, jon
Re: stealth heads [Re: pettyblue440] #2012668
02/15/16 08:09 PM
02/15/16 08:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
They come with Comp locks and retainers now, 7 degree. IMO its not necessary, if your cam works with stock rockers it should work with the stock stealth springs and 7 degree locks and retainers should be adequate.
Re: stealth heads [Re: GTX MATT] #2012688
02/15/16 08:36 PM
02/15/16 08:36 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
http://www.440source.com/headfaq.htm
Re: stealth heads [Re: 440sourcedotcom] #2012692
02/15/16 08:40 PM
02/15/16 08:40 PM
IN
ahy Offline
ahy  Offline
IN
Agree the as supplied 7 degree locks should be fine for a moderate hydraulic flat tappet. Upgrade is usually recommended for a high po hydraulic or flat tappet.
Re: stealth heads [Re: pettyblue440] #2012698
02/15/16 08:49 PM
02/15/16 08:49 PM
central new york
central new york
sounds good, I am just running a basic 484 cam.
Re: stealth heads [Re: ahy] #2012745
02/15/16 10:22 PM
02/15/16 10:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pretty hard to imagine that the 7° stuff would not work those as well.
Re: stealth heads [Re: BSB67] #2012851
02/16/16 12:26 AM
02/16/16 12:26 AM
I bought a pair of the super stealths (bare) & they were on sale for iirc $399 ea & I got valves (Sources' iirc) & their required offset intake rockers (the whole shebang). Been sitting untouched for awhile now. they do look nice & a straighter port shape but even Source recommends the regular stealths to alot of people, not sure why
Re: stealth heads [Re: pettyblue440] #2012932
02/16/16 02:21 AM
02/16/16 02:21 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Mine are going strong after 5 years, and I consider them to have been a great purchase. Don't see how I could have gotten more for $900. I would recommend them for a street / mild strip build without hesitation.
Re: stealth heads [Re: pettyblue440] #2013014
02/16/16 10:05 AM
02/16/16 10:05 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine are one of the first sets made.Been on and no problems after lots of miles.I did change springs retainers and keepers as well as my shop cleanded them up and back cut the valves.i run a .588 solid cam so changing theparts was a no brainer.My machinist said the rest was decent but he likes to make stuff perfect.Im happy with mine.Rocky
Chrysler Firepower
