Part # Strange double adjustable coilover rear shocks #201258
01/22/09 06:11 PM
01/22/09 06:11 PM
Anonymous OP
Anonymous OP
i need the part # for the Strange double adjustable coilover shocks for a ladder bar 65 plymouth belvedere and a 63 plymouth max wedge savoy.
also what rear spring weight do you recommend?
cars weigh around 3450 lb with driver. thanks
Re: Part # Strange double adjustable coilover rear shoc #201259
01/22/09 06:28 PM
01/22/09 06:28 PM
Wisconsin
MagnumExpress Offline
Wisconsin
Provide the length of the shock. compressed and extended and I can provide part #s.
Jeff
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: Part # Strange double adjustable coilover rear shoc [Re: MagnumExpress] #201260
01/22/09 06:51 PM
01/22/09 06:51 PM
Anonymous OP
Anonymous OP
im in the process of ladder barring the 2 cars so i dont know what length yet? i need input on what shocks you guys are running and what spring pressure.
Re: Part # Strange double adjustable coilover rear shoc [Re: MagnumExpress] #201261
01/22/09 09:27 PM
01/22/09 09:27 PM
Anonymous OP
Anonymous OP
Jeff
I checked my 65 dodge and the relaxed height of the shock is 14-1/4" eye hole to eyehole center,
spring is at almost 3/4" of the way down on the adjustment.
what shock would i need?
Re: Part # Strange double adjustable coilover rear shoc #201262
01/23/09 05:20 PM
01/23/09 05:20 PM
Anonymous OP
Anonymous OP
anyone please!!!!!
BG where are you?
Re: Part # Strange double adjustable coilover rear shoc #201263
01/23/09 05:57 PM
01/23/09 05:57 PM
IL
DRAGRCR632 Offline
super street
DRAGRCR632  Offline
super street
IL
2 most common stange shocks are
5006 6 inch travel shock
13.875-14.500 installed length
or
5007 which is 7 inch travel shock
15.25-16.00 installed length
both are double adjustable
i stay with the longers ones just depends
on room you have
LRT
Re: Part # Strange double adjustable coilover rear shoc [Re: DRAGRCR632] #201264
01/23/09 07:43 PM
01/23/09 07:43 PM
Anonymous OP
Anonymous OP
or
on room you have
LRT
thanks but....what spring weight would you go with on a 65 plymouth 3445 lb w/ driver.thanks
Re: Part # Strange double adjustable coilover rear shoc #201265
01/23/09 08:43 PM
01/23/09 08:43 PM
Penna
70satelliteguy Offline
Penna
I run 130's with my 70 B body at 3550 lbs, with driver.
Mike
Re: Part # Strange double adjustable coilover rear shoc [Re: 70satelliteguy] #201266
01/24/09 12:00 AM
01/24/09 12:00 AM
IL
DRAGRCR632 Offline
super street
DRAGRCR632  Offline
super street
IL
depends on the spring
if they are cheapies 150 ish
hyper coils 130
LRT
Re: Part # Strange double adjustable coilover rear shoc [Re: DRAGRCR632] #201267
01/24/09 09:50 AM
01/24/09 09:50 AM
Anonymous OP
Anonymous OP
im getting the hypercoils . i far down do you run them on the adjuster and how do you know where to set them?
1st time with coilovers thanks
Re: Part # Strange double adjustable coilover rear shoc #201268
01/24/09 10:48 AM
01/24/09 10:48 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
It might be on my invoice from the chassis shop what i use. Probably will be close to what you are doing. I can look on monday. I used alston doubles on mine.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Part # Strange double adjustable coilover rear shoc #201269
01/24/09 11:23 AM
01/24/09 11:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The spring weight will depend on what the rear of the
car weighs but 130 should be in the ball park, set
the lower adjuster at 1" up from the bottom, the
shock should drop down to the working height (about
mid height of the travel), if its too high you need
a lighter spring. If it drops lower than the working
height you can dial up the adjuster about 1" or so.
I like long shocks,being longer you wont run out
of travel length but if they are short and bottom
out you will have big problems. You can adjust the
height of the car if you have adjustable shock mounts
on the rearend
Re: Part # Strange double adjustable coilover rear shocks #201270
01/24/09 11:33 AM
01/24/09 11:33 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Don't know the part # for the shocks ,but for springs you really need to scale the car and pick your springs according to weight. My 65 Coronet weighs 1524lbs on the rear tires and I've ran a130lb spring and I've used a 150 lb spring either one you can adjust to your liking
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Part # Strange double adjustable coilover rear shocks [Re: 65dragnet] #201271
01/24/09 11:39 AM
01/24/09 11:39 AM
Anonymous OP
Anonymous OP
it looks like my 65 dodge has S5006 strange double adustable shocks. i want to duplicate the same suspension for my 65 plymouth for this year.
i got the Chassis engineering outlaw triple adjustable setup and need to get the right shocks.
thanks
Raff, i got adjustable rear lower shock mounts as well.
i think these hyper coils should be color coded for spring pressure. you have no way of telling what you have.
Re: Part # Strange double adjustable coilover rear shocks #201272
01/24/09 11:55 AM
01/24/09 11:55 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Hypercoils have their rate engraved on one of the ends
Re: Part # Strange double adjustable coilover rear shocks [Re: SB412DUSTER] #201273
01/24/09 12:06 PM
01/24/09 12:06 PM
Anonymous OP
Anonymous OP
is it visible when the springs are installed?
Re: Part # Strange double adjustable coilover rear shocks #201274
01/24/09 12:12 PM
01/24/09 12:12 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
No it's not
Re: Part # Strange double adjustable coilover rear shocks #201275
01/24/09 12:26 PM
01/24/09 12:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call Strange and talk to them when you order them, tey come with instructions on how to set the ride hieght and they will help you select the correct spring. I have three sets of springs, brands unknown to me , they all have a thin metal tag wrapped around a coil with the rate embossed on it
Re: Part # Strange double adjustable coilover rear shocks [Re: Cab_Burge] #201276
01/24/09 12:33 PM
01/24/09 12:33 PM
Anonymous OP
Anonymous OP
cab, i called strange, they are impossible to deal with. arrogant .thats why i want the correct information and buy them through a strange dealer.
i had problems with their S60 dana rear, impossible to buy from them. made a call to moser and got exactly what i wanted and needed.
Re: Part # Strange double adjustable coilover rear shocks #201277
01/24/09 12:35 PM
01/24/09 12:35 PM
Sorry to hear that, I have called them twice on the springs and had good contact on both occasions
