Part # Strange double adjustable coilover rear shocks
#201258
01/22/09 06:11 PM
01/22/09 06:11 PM
i need the part # for the Strange double adjustable coilover shocks for a ladder bar 65 plymouth belvedere and a 63 plymouth max wedge savoy. also what rear spring weight do you recommend? cars weigh around 3450 lb with driver. thanks
Re: Part # Strange double adjustable coilover rear shoc
#201259
01/22/09 06:28 PM
01/22/09 06:28 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
Provide the length of the shock. compressed and extended and I can provide part #s.
Jeff
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
[Re: MagnumExpress]
#201260
01/22/09 06:51 PM
01/22/09 06:51 PM
im in the process of ladder barring the 2 cars so i dont know what length yet? i need input on what shocks you guys are running and what spring pressure.
[Re: MagnumExpress]
#201261
01/22/09 09:27 PM
01/22/09 09:27 PM
Jeff
I checked my 65 dodge and the relaxed height of the shock is 14-1/4" eye hole to eyehole center, spring is at almost 3/4" of the way down on the adjustment. what shock would i need?
#201262
01/23/09 05:20 PM
01/23/09 05:20 PM
anyone please!!!!! BG where are you?
[Re: DRAGRCR632]
#201264
01/23/09 07:43 PM
01/23/09 07:43 PM
2 most common stange shocks are 5006 6 inch travel shock 13.875-14.500 installed length or
5007 which is 7 inch travel shock 15.25-16.00 installed length
both are double adjustable i stay with the longers ones just depends on room you have
LRT
thanks but....what spring weight would you go with on a 65 plymouth 3445 lb w/ driver.thanks
[Re: DRAGRCR632]
#201267
01/24/09 09:50 AM
01/24/09 09:50 AM
im getting the hypercoils . i far down do you run them on the adjuster and how do you know where to set them? 1st time with coilovers thanks
#201268
01/24/09 10:48 AM
01/24/09 10:48 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
It might be on my invoice from the chassis shop what i use. Probably will be close to what you are doing. I can look on monday. I used alston doubles on mine.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
#201269
01/24/09 11:23 AM
01/24/09 11:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The spring weight will depend on what the rear of the car weighs but 130 should be in the ball park, set the lower adjuster at 1" up from the bottom, the shock should drop down to the working height (about mid height of the travel), if its too high you need a lighter spring. If it drops lower than the working height you can dial up the adjuster about 1" or so. I like long shocks,being longer you wont run out of travel length but if they are short and bottom out you will have big problems. You can adjust the height of the car if you have adjustable shock mounts on the rearend
Re: Part # Strange double adjustable coilover rear shocks
[Re: 65dragnet]
#201271
01/24/09 11:39 AM
01/24/09 11:39 AM
it looks like my 65 dodge has S5006 strange double adustable shocks. i want to duplicate the same suspension for my 65 plymouth for this year. i got the Chassis engineering outlaw triple adjustable setup and need to get the right shocks. thanks Raff, i got adjustable rear lower shock mounts as well. i think these hyper coils should be color coded for spring pressure. you have no way of telling what you have.
[Re: SB412DUSTER]
#201273
01/24/09 12:06 PM
01/24/09 12:06 PM
Hypercoils have their rate engraved on one of the ends
is it visible when the springs are installed?
[Re: Cab_Burge]
#201276
01/24/09 12:33 PM
01/24/09 12:33 PM
Call Strange and talk to them when you order them, tey come with instructions on how to set the ride hieght and they will help you select the correct spring. I have three sets of springs, brands unknown to me , they all have a thin metal tag wrapped around a coil with the rate embossed on it
cab, i called strange, they are impossible to deal with. arrogant .thats why i want the correct information and buy them through a strange dealer. i had problems with their S60 dana rear, impossible to buy from them. made a call to moser and got exactly what i wanted and needed.
#201277
01/24/09 12:35 PM
01/24/09 12:35 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Sorry to hear that, I have called them twice on the springs and had good contact on both occasions
