T&D Rocker Arm question #2012270
02/15/16 06:35 AM
02/15/16 06:35 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I'm in need if a rocker arm upgrade on my -1's & was considering T&D's, I think i read somewhere that they take Ball n Ball pushrods? Is this correct? Are they available Ball n Cup? I have multiple sets of different length ball n cup pushrods, i don't want to start a new collection of ball n ball ones as well.
Re: T&D Rocker Arm question [Re: rebel] #2012281
02/15/16 09:16 AM
02/15/16 09:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My paired T&D are ball/ball. Call and see if they have options. Nice stuff for sure.
Doug
Re: T&D Rocker Arm question [Re: rebel] #2012429
02/15/16 02:11 PM
02/15/16 02:11 PM
NC
440Jim Offline
440Jim  Offline
NC
T&D makes both rockers with one shaft per head using ball-cup pushrods, and the one shaft per cylinder, paired, rockers which use ball-ball pushrods and push rod fed oiling.
Re: T&D Rocker Arm question [Re: rebel] #2012436
02/15/16 02:23 PM
02/15/16 02:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
They can do them either way. It's simply an adjuster change
Re: T&D Rocker Arm question [Re: 440Jim] #2012437
02/15/16 02:23 PM
02/15/16 02:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All of the TD rockers I have owned(multiple
type, BB and SB, both single shaft and multi
shaft) have all been ball and ball type.. I
myself have never seen a ball and cup style
one
wave
Re: T&D Rocker Arm question [Re: MR_P_BODY] #2012447
02/15/16 02:38 PM
02/15/16 02:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I believe that the cup style adjuster is standard for T@D, I had called them last Friday about the single shaft system and was told they will oil both ways (shaft or pushrod) but I didn't think to ask about the ball style adjusters for shaft oiling, a quick call to Sheldon would confirm this, altho looking on their web site they don't show any ball style adjusters in their parts listing.
Re: T&D Rocker Arm question [Re: dartman366] #2012452
02/15/16 02:47 PM
02/15/16 02:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my SB stuff I have oiled both ways.. PR and
shaft.. both on single shaft type
wave
Re: T&D Rocker Arm question [Re: rebel] #2012487
02/15/16 03:46 PM
02/15/16 03:46 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Cup ends are very common these days on big inch motors with tree trunk sized pushrods, big lift and big ratio. Basically an insert pressed into the end of the tubing. Similar to what everyone thinks they look like, but the cup is not bigger than tubing, as in the past. This is similar to what we run in our 762. It's a .281 cup
But to answer Rebel's question.......if you want T&Ds with standard 5/16 ball ends to use your existing pushrods, they will gladly sell them to you that way. Some need to get past what is shown in a catalog, or they SEE online. Pick up the phone. Most of these companies can do anything you want them to do and you won't be the first to have asked
Re: T&D Rocker Arm question [Re: Monte_Smith] #2012502
02/15/16 04:02 PM
02/15/16 04:02 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Those look pretty nice, guess I will do some investigating as the Harlan Sharp rockers come standard with ball style adjusters. work
Re: T&D Rocker Arm question [Re: Monte_Smith] #2012544
02/15/16 05:02 PM
02/15/16 05:02 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
do you know if there is a part # for ball n cup style in the 1.6 ratio single shaft?
Re: T&D Rocker Arm question [Re: rebel] #2012634
02/15/16 07:03 PM
02/15/16 07:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Call them...........
Re: T&D Rocker Arm question [Re: rebel] #2012667
02/15/16 08:09 PM
02/15/16 08:09 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
3/4" pushrods... daaaang!
Re: T&D Rocker Arm question [Re: TRENDZ] #2012705
02/15/16 09:10 PM
02/15/16 09:10 PM
When your pushing north of 11,500 RPM with a BA blown alky hemiroid motor with north of 1200 lbs open pressures you need all the stabilty in the valve train you can get work shruggy I think the NASCAR cup guys might be using them also confused
Re: T&D Rocker Arm question [Re: rebel] #2012737
02/15/16 10:13 PM
02/15/16 10:13 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Valve train deflection KILLS parts and power.
Re: T&D Rocker Arm question [Re: rebel] #2012769
02/15/16 10:49 PM
02/15/16 10:49 PM
Earth
Rob C Offline
Rob C  Offline
Earth
And your wallet thickness.
Re: T&D Rocker Arm question [Re: Rob C] #2012837
02/15/16 11:57 PM
02/15/16 11:57 PM
It comes to a time, sometimes, that you pay once or more than once trying to save money, especially on race parts work
I've seen 8 HP gain and a 300 RPM increase on peak HP on changing the brand and wall thickness of pushrods on a relative cheap street solid roller cam pump gas motor work shruggy
Re: T&D Rocker Arm question [Re: Monte_Smith] #2012942
02/16/16 02:31 AM
02/16/16 02:31 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i've e-mailed them but they must have broken their keyboard finger. i'm down under & to some US citizens, my accent is a little too broad for them to understand what i'm asking for, either that or i'm dealing with an idiot.
Re: T&D Rocker Arm question [Re: rebel] #2012972
02/16/16 04:15 AM
02/16/16 04:15 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I deal with guys from New Zealand all the time and was just down there for 15 days. Accent is no problem. Pick up the phone. And the time diff is 20 hours, so not like you have to do it in the middle of the night either.
How hard can it be.....I want a set of big block Mopar rockers and I want to use my existing 5/16 cup end push rods. Send them to me.
If you are serious you call.......if you are kicking tires, you email and then complain if they don't answer fast enough to suit you. If calling is just not your thing. Have Mark Hayes at Rocket do it for you.
Re: T&D Rocker Arm question [Re: rebel] #2014468
02/18/16 03:04 AM
02/18/16 03:04 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
well i rang them, after repeating what i wanted a few times, it appears that they only come set up for ball n ball pushrods. So i guess this only leaves H&S rockers as my only choice. Anyone got a Summit code they dont need?
Re: T&D Rocker Arm question [Re: rebel] #2014475
02/18/16 03:47 AM
02/18/16 03:47 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So what is wrong with buying ball cup adjusters, they don't cost that much.
