What kind of fittings to use on aluminum fuel line #2011845
02/14/16 05:14 PM
02/14/16 05:14 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I am going to use 3/8 aluminum fuel line and I was wondering what type of fittings I should use.
The type that needs a flared end on the line or the fitting that uses the compression ring that slips over the line and compresses once you tighten it up.
I don't know how well a flare will hold up when it gets tightened down.
Thanks.
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2011872
02/14/16 06:00 PM
02/14/16 06:00 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
With aluminum tubing, you slide on the nut and then these sleeves before you flare the tube.
Sleeves http://www.summitracing.com/int/parts/sum-220634-2b/overview/
Nuts: http://www.summitracing.com/int/parts/sum-220633-2b/overview/
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2011874
02/14/16 06:01 PM
02/14/16 06:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I use flare nuts and sleeves on mine, no issues.. (With AN fittings and the correct flare angle)
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2012076
02/14/16 10:46 PM
02/14/16 10:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Earl's has fitting adapters as well; easy to use and never had a problem with them.
Re: What kind of fittings to use on aluminum fuel line [Re: topside] #2012084
02/14/16 10:55 PM
02/14/16 10:55 PM
with the flare nuts and sleeves you would need the somewhat pricey 37 deg flaring tool. I used speedway mtrs flare nuts/sleeves which give you an AN blue alum fitting. they have alot of fittings & there MIGHT be a compression fitting setup that is suitable. If I could do it correctly & not have to purchase the tool I would
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2012149
02/15/16 12:28 AM
02/15/16 12:28 AM
Using the 37 degree AN sleeves and nuts on aluminum lines requires a Parker Hannifin or another brand of a 37 degree flaring tool. I bought one when I owned maintained and flew my airplane years ago, those type tools are not cheap work I have used a regular 45 degrree flaring tool(single flare oly on aluminum, not double tsk) on alumimum lines for the race car and got away with it, the trick is to NOT flare it all the way to 37 degrees, stop and slide the sleeve and nut up onto the aluminum line and get it close to being at the right angle and use the male end of the other fitting to do the final seating thumbs scope You can use regular brass or steel automotive 45 degree fittings also work
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2012193
02/15/16 01:37 AM
02/15/16 01:37 AM
CA
crackedback Offline
crackedback  Offline
CA
A $30 tool is pricey or expensive? OK.
Summit has the 37* flaring tool as do others. I used one to do a few cars with aluminum line.
Re: What kind of fittings to use on aluminum fuel line [Re: crackedback] #2012205
02/15/16 02:11 AM
02/15/16 02:11 AM
$30 ain't pricey or expensive at all but I had no idea one was available that cheap & yes your price is correct. Thank you! I need a new one & I'll be calling or emailing them tomorrow.
Re: What kind of fittings to use on aluminum fuel line [Re: crackedback] #2012604
02/15/16 06:13 PM
02/15/16 06:13 PM
The only 37 degree flaring kits that where around when I bought mine in 1993 where north of $85.00 plus the shipping, the same outfit sold a tool to swell the end of the tubes up like stock steel lines have on them from the factory, that was expensive also. I wish I had bought one of them back then, in hindsight I should have realcrazy Very seldom do good tools get cheaper or better twocents
Re: What kind of fittings to use on aluminum fuel line [Re: Cab_Burge] #2012935
02/16/16 02:23 AM
02/16/16 02:23 AM
Thanks Cab & thats the way it (prices) was when I was searching. I just thought that maybe I didnt look far enough. EDIT summitt $24.97 + $9.95 ship/handling I believe. it'd be a cheapie but I dont flare that much & it is kind of a trouble free item just needs careful use to get a good flare
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2013009
02/16/16 09:50 AM
02/16/16 09:50 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have used brass flare fittings(no sleeves) from the hardware store on aluminum fuel and transmission lines on a few of my cars. One has been together for 16 years without any problems.
Re: What kind of fittings to use on aluminum fuel line [Re: 65rbdodge] #2013149
02/16/16 02:51 PM
02/16/16 02:51 PM
Could you post a pic of em so we will know what to look for?
Re: What kind of fittings to use on aluminum fuel line [Re: RapidRobert] #2021122
02/28/16 03:33 AM
02/28/16 03:33 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Hey, Robert! When i did my Chall racecar years ago(still outside here) I used weatherhead 1/2' comression fittings with the ferrules, just like the old plastic line oil fittings we hated, just huge. You can then go from that to NPT at the ends and into hose barb, AN or whatever blows your hair back.
Worked awesome and is still in service 16 years later.IMHO
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: What kind of fittings to use on aluminum fuel line [Re: Sixgun] #2021135
02/28/16 04:46 AM
02/28/16 04:46 AM
I ain't heard from you in a coons age, I thought maybe you moved back to Hawaii. (its 76 degrees there right now)
Re: What kind of fittings to use on aluminum fuel line [Re: RapidRobert] #2021352
02/28/16 04:02 PM
02/28/16 04:02 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Oh I just decided to do other things for awhile and take a well deserved pause, had a different job for awhile that took me to a few states, long hours etc. Had a bunch of my own tech problems to solve, not much interest in anyone else's issues...BTW Hawaii has internet, so even then I would still post :-)
Nope, still loving Washington, lots of good folks here, Car club is pretty cool, lots of respect even tho I'm like one of two Mopar guys...
Funny how people spend time getting to know you in the 'real world'
and are a lot less judgemental and arrogant than in cyber.
You? Still ripping it up in the Heartland?
Re: What kind of fittings to use on aluminum fuel line [Re: Sixgun] #2021359
02/28/16 04:11 PM
02/28/16 04:11 PM
Funny how people spend time getting to know you in the 'real world' and are a lot less judgemental and arrogant than in cyber.
Yeah I do (much) better in cyberspace than in real life. After 13 yrs on Moparts I am comfortable with my tech level but I ain't made a meal ticket out of it (no antique Mopar specific restoration shops locally but I might go back to work for Speedway mtrs & they're chebby heaven!) otherwise I just pass on what I can to members in need. Take care & we'll be in touch as needed. EDIT and I wanted to add that 99% of what I know came from Moparts and I am still learning (here) every day.
Re: What kind of fittings to use on aluminum fuel line [Re: patosmith] #2021415
02/28/16 05:32 PM
02/28/16 05:32 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I use the rigid ratcheting flaring tool for 3/4 stainless oil lines, Parker rolo flaring tool for everything else. I also have the parker beading tool....
I do have 2 of the rolo flaring tools now....picked one up in a collection of stuff in a friends estate sale....Tim
http://www.toolbarn.com/ridgid-41162.html
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
