Re: What kind of fittings to use on aluminum fuel line
[Re: patosmith]
#2011872
02/14/16 06:00 PM
02/14/16 06:00 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
[Re: topside]
#2012084
02/14/16 10:55 PM
02/14/16 10:55 PM
RapidRobert
with the flare nuts and sleeves you would need the somewhat pricey 37 deg flaring tool. I used speedway mtrs flare nuts/sleeves which give you an AN blue alum fitting. they have alot of fittings & there MIGHT be a compression fitting setup that is suitable. If I could do it correctly & not have to purchase the tool I would
[Re: crackedback]
#2012205
02/15/16 02:11 AM
02/15/16 02:11 AM
RapidRobert
A $30 tool is pricey or expensive? OK. Summit has the 37* flaring tool as do others. $30 ain't pricey or expensive at all but I had no idea one was available that cheap & yes your price is correct. Thank you! I need a new one & I'll be calling or emailing them tomorrow.
[Re: crackedback]
#2012604
02/15/16 06:13 PM
02/15/16 06:13 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Summit has the 37* flaring tool as do others. I used one to do a few cars with aluminum line. The only 37 degree flaring kits that where around when I bought mine in 1993 where north of $85.00 plus the shipping, the same outfit sold a tool to swell the end of the tubes up like stock steel lines have on them from the factory, that was expensive also. I wish I had bought one of them back then, in hindsight I should have Very seldom do good tools get cheaper or better
[Re: Cab_Burge]
#2012935
02/16/16 02:23 AM
02/16/16 02:23 AM
RapidRobert
The only 37 degree flaring kits that where around when I bought mine in 1993 where north of $85.00 plus the shipping, Thanks Cab & thats the way it (prices) was when I was searching. I just thought that maybe I didnt look far enough. EDIT summitt $24.97 + $9.95 ship/handling I believe. it'd be a cheapie but I dont flare that much & it is kind of a trouble free item just needs careful use to get a good flare
[Re: 65rbdodge]
#2013149
02/16/16 02:51 PM
02/16/16 02:51 PM
RapidRobert
I have used brass flare fittings(no sleeves) from the hardware store on aluminum fuel and transmission lines on a few of my cars. One has been together for 16 years without any problems. Could you post a pic of em so we will know what to look for?
[Re: RapidRobert]
#2021122
02/28/16 03:33 AM
02/28/16 03:33 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Hey, Robert! When i did my Chall racecar years ago(still outside here) I used weatherhead 1/2' comression fittings with the ferrules, just like the old plastic line oil fittings we hated, just huge. You can then go from that to NPT at the ends and into hose barb, AN or whatever blows your hair back. Worked awesome and is still in service 16 years later.IMHO
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: Sixgun]
#2021135
02/28/16 04:46 AM
02/28/16 04:46 AM
RapidRobert
I ain't heard from you in a coons age, I thought maybe you moved back to Hawaii. (its 76 degrees there right now)
[Re: RapidRobert]
#2021352
02/28/16 04:02 PM
02/28/16 04:02 PM
Sixgun
Western Washington
Oh I just decided to do other things for awhile and take a well deserved pause, had a different job for awhile that took me to a few states, long hours etc. Had a bunch of my own tech problems to solve, not much interest in anyone else's issues...BTW Hawaii has internet, so even then I would still post :-) Nope, still loving Washington, lots of good folks here, Car club is pretty cool, lots of respect even tho I'm like one of two Mopar guys... Funny how people spend time getting to know you in the 'real world' and are a lot less judgemental and arrogant than in cyber. You? Still ripping it up in the Heartland?
[Re: Sixgun]
#2021359
02/28/16 04:11 PM
02/28/16 04:11 PM
RapidRobert
Funny how people spend time getting to know you in the 'real world' and are a lot less judgemental and arrogant than in cyber. You? Still ripping it up in the Heartland? Yeah I do (much) better in cyberspace than in real life. After 13 yrs on Moparts I am comfortable with my tech level but I ain't made a meal ticket out of it (no antique Mopar specific restoration shops locally but I might go back to work for Speedway mtrs & they're chebby heaven!) otherwise I just pass on what I can to members in need. Take care & we'll be in touch as needed. EDIT and I wanted to add that 99% of what I know came from Moparts and I am still learning (here) every day.
[Re: patosmith]
#2021415
02/28/16 05:32 PM
02/28/16 05:32 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I use the rigid ratcheting flaring tool for 3/4 stainless oil lines, Parker rolo flaring tool for everything else. I also have the parker beading tool.... I do have 2 of the rolo flaring tools now....picked one up in a collection of stuff in a friends estate sale....Tim http://www.toolbarn.com/ridgid-41162.html
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
