Made Some Chassis Tie Downs #2011492
02/14/16 12:38 AM
02/14/16 12:38 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Well due to some miscommunication, did not weld chassis tie downs on the k member of my GTX build before the k frame got powder coated.
So I had to make some. Pretty happy with the results. Each bolt is god for just under 2500 lbs in shear (for a total just under 10,000 lbs) so I should be good. In addition I got the tab in the back to help just in case.
Re: Made Some Chassis Tie Downs [Re: markz528] #2011523
02/14/16 01:10 AM
02/14/16 01:10 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Nice powder coat. blush grin
Kidding. Good job on the tie downs! up
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Made Some Chassis Tie Downs [Re: markz528] #2011553
02/14/16 01:48 AM
02/14/16 01:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If those are 3/8" grade 8 bolts you wont have
any issue.. even that you are gonna apply some
tensile load to them
EDIT
Unless you have a huge hole in the plate.. take
off the flat washer and use a lock washer.. or
use a longer bolt with both a flat and lock
wave
Re: Made Some Chassis Tie Downs [Re: markz528] #2011582
02/14/16 03:01 AM
02/14/16 03:01 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That is overkill!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Made Some Chassis Tie Downs [Re: MR_P_BODY] #2011675
02/14/16 12:40 PM
02/14/16 12:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
EDIT
wave
Exactly on the forces on the bolt - there will be a significant portion of the load that will be in tension (tensile load) which is a higher rating than the shear rating so I ignored it. I will be using grade 8 hardware.
Unfortunately I had to slot the hole by .200" because I located the hole too far forward and did not have enough material left in the k frame to maintain the sheer strength. So I need to use washers. Not exactly sure what I will end up with for actual hardware but it will all be grade 8 hardware.
Re: Made Some Chassis Tie Downs [Re: markz528] #2011931
02/14/16 07:32 PM
02/14/16 07:32 PM
hemi-itis Offline
hemi-itis  Offline
You could hang the car from the rafters with those plates!!
Re: Made Some Chassis Tie Downs [Re: markz528] #2011948
02/14/16 07:58 PM
02/14/16 07:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks good!
Re: Made Some Chassis Tie Downs [Re: markz528] #2011998
02/14/16 09:39 PM
02/14/16 09:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
And guys wonder why their cars are heavy..................LOL!!!
Re: Made Some Chassis Tie Downs [Re: Monte_Smith] #2012070
02/14/16 10:39 PM
02/14/16 10:39 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Yup, Yup, Yup! grin
But its got weight reduction holes! laugh
Re: Made Some Chassis Tie Downs [Re: markz528] #2012979
02/16/16 04:40 AM
02/16/16 04:40 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I bought some that mount to the rear from a local guy. His name is bluescuda on here. Have yet to install though.
Re: Made Some Chassis Tie Downs [Re: markz528] #2013005
02/16/16 09:21 AM
02/16/16 09:21 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
On the rear I just drilled a hole through the shock plate. Then inserted a thread together chain link. Then you just hook to the link.
Doug
