main cap torque #2011291
02/13/16 08:05 PM
02/13/16 08:05 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What's the proper torque for: 440 block with aluminum main caps, ARP studs with ARP assembly lube? And while I'm asking 7/16 " 440 source rod bolts.
Re: main cap torque [Re: rowin4] #2011314
02/13/16 08:33 PM
02/13/16 08:33 PM
I would call ARP on Monday and ask them up I have some of the ARP instructions sheets from ARP in the shop but I'm not sure if those numbers apply to the aluminum main caps or iron caps onlyconfused On the rod bolts I would call 440 Source also to make sure to get the straight scoop on thier rod bolts, some of the rod companys have special ARP bolts made for thier rods so the general torque from another brand with 7/16 ARP bolts may or may not be correct work I like and use a rod stretch bolt gauge on all my race or Hi Po aftermarket rods with ARP bolts thumbs
Re: main cap torque [Re: Cab_Burge] #2011350
02/13/16 09:19 PM
02/13/16 09:19 PM
IN
ahy Offline
ahy  Offline
IN
Suggest you ask the machinist who did the line bore and hone what he used... in addition to checking with the supplier. In general assembly torque should match up with torque at machining so the cap and block distortion is the same for consistent bearing clearance.
Re: main cap torque [Re: rowin4] #2011360
02/13/16 09:31 PM
02/13/16 09:31 PM
rowin4 Offline OP
rowin4  Offline OP
Well I went through my garage cabinet and found a ARP box with a sheet in it. It states to torque the 1/2" studs in 3 steps to 110 ft. lbs. using ARP ultra lube. Now that box was supplied with my aluminum Hemi block . Would there be different part numbers [ studs ] for cast iron block?/ cast iron block , with aluminum caps with the same size studs? 110 ft. lbs. seems high but I built this engine 8 years ago, getting old and have CRS. Probably end up calling both places to get the straight scoop as you [ CAB ] said.
Re: main cap torque [Re: rowin4] #2011368
02/13/16 09:37 PM
02/13/16 09:37 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Took a while, but I found my build sheet for my 500. Used Best aluminum caps and ARP studs with supplied moly lube. Torqued to 90 lb ft. Spec was also 90 lb ft. Don't know about Source rod bolts. My rod bolts are torqued to 70 lb ft with moly.
[image][/image]
Re: main cap torque [Re: rowin4] #2011372
02/13/16 09:42 PM
02/13/16 09:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Mine were 90 ft lbs also on the mains
Re: main cap torque [Re: rowin4] #2012213
02/15/16 02:23 AM
02/15/16 02:23 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
using arp studs you should be at 110 ft lbs per their instructions. in order to maximize the clamping force of the stud you need to follow the manufacturers instructions.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: main cap torque [Re: rowin4] #2012227
02/15/16 02:51 AM
02/15/16 02:51 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Go on the ARP webpage and download the torque instructions based on part numbers. I think It is listed as Tech Info(??). It's all there, just look for It.
