NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. #2010995
02/13/16 10:53 AM
02/13/16 10:53 AM
Phoenix, AZ
MoparBilly Offline OP
Phoenix, AZ
Finally ready to break down and do the belly pan thing, and all the rules quote you must use this material inside the belly pan, but when I search Summit, or even Google, I'm not finding what I need.
Who the heck sells this stuff, and what is easiest to use??
Also, I thought there were specific rules to the thickness of aluminum or steel used to construct the pan, but I'm not finding that either.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011007
02/13/16 11:45 AM
02/13/16 11:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.newpig.com/pig/US/absorbents-...nt-mat-505/0/20
this is what is inside my engine blanket..... can't say that it isn't flammable or not.
I don't recall their being a "spec" for the pan.... Might get ahold of David Dean. He made one for his Duster
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011029
02/13/16 12:23 PM
02/13/16 12:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pigmat in ours as well...In the dragster Diaper and the Stratus pan
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011041
02/13/16 12:53 PM
02/13/16 12:53 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
pigmat here also
Without Data, you’re just another guy with an opinion.
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011084
02/13/16 02:39 PM
02/13/16 02:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Pig mat here to
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011108
02/13/16 03:09 PM
02/13/16 03:09 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Jegs sells the mat I use. I have a screen on top to hold it in place.
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011115
02/13/16 03:18 PM
02/13/16 03:18 PM
crabman173
crabman173
I really really like my DRE ( Dennis Ridgeway) blanket fits great--top quality hardware--he is the best IMO
You can get ballistic cloth upgrade --worth it to keep things inside the blanket
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011119
02/13/16 03:22 PM
02/13/16 03:22 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
No specific material or thickness requirement called out in the rulebook. RJ sells them made of carbon fiber.
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: CMcAllister] #2011163
02/13/16 04:36 PM
02/13/16 04:36 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If the pigmat is the grey, same thing as what is used to absorb oil on a floor then be careful not to get against anything hot like headers and such as it will melt and eventually catch fire, the ones we used at the shop was banned from use in the weld shop and around anything making extreme heat, they make several types, some for oil only and some for water only, I would call the manufacture and talk to them.lmo
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011257
02/13/16 06:48 PM
02/13/16 06:48 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Dartman is correct, my turbo exhaust will melt pig mat after a hard hit. I try to keep it away from the exhaust.
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: J_BODY] #2011627
02/14/16 10:33 AM
02/14/16 10:33 AM
moparx Offline
moparx  Offline
pig mat will burn. we had some catch fire around a piece of equipment in the machine shop i retired from. this fire was caused by a malfunctioning electric motor on a hydraulic pump catching fire. the pig mat was there because the hoses to the pump/tank connection leaked.
beer
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2011636
02/14/16 10:59 AM
02/14/16 10:59 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been wondering myself. I want to install a Moroso oil pan heater but I run a diaper. Anybody do this?
Doug
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions. [Re: MoparBilly] #2012014
02/14/16 09:55 PM
02/14/16 09:55 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
