NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions.
#2010995
02/13/16 10:53 AM
02/13/16 10:53 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Finally ready to break down and do the belly pan thing, and all the rules quote you must use this material inside the belly pan, but when I search Summit, or even Google, I'm not finding what I need.
Who the heck sells this stuff, and what is easiest to use??
Also, I thought there were specific rules to the thickness of aluminum or steel used to construct the pan, but I'm not finding that either.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: NONFLAMMABLE OIL-ABSORBENT LINER? Belly Pan Questions.
[Re: MoparBilly]
#2011115
02/13/16 03:18 PM
02/13/16 03:18 PM
crabman173
crabman173
I really really like my DRE ( Dennis Ridgeway) blanket fits great--top quality hardware--he is the best IMO You can get ballistic cloth upgrade --worth it to keep things inside the blanket
[Re: MoparBilly]
#2011119
02/13/16 03:22 PM
02/13/16 03:22 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
No specific material or thickness requirement called out in the rulebook. RJ sells them made of carbon fiber.
[Re: CMcAllister]
#2011163
02/13/16 04:36 PM
02/13/16 04:36 PM
dartman366
Mt. Vernon, Ohio
If the pigmat is the grey, same thing as what is used to absorb oil on a floor then be careful not to get against anything hot like headers and such as it will melt and eventually catch fire, the ones we used at the shop was banned from use in the weld shop and around anything making extreme heat, they make several types, some for oil only and some for water only, I would call the manufacture and talk to them.lmo
