Valve spring swap #2008957
02/10/16 12:20 AM
02/10/16 12:20 AM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Trying to swap out valve springs on edelbrock heads, engine in car. The compressor I have won't work with the dual valve springs, any ideas on one that will?
Re: Valve spring swap [Re: Hotlumpy] #2009010
02/10/16 01:23 AM
02/10/16 01:23 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Valve spring swap [Re: GomangoCuda] #2009047
02/10/16 02:20 AM
02/10/16 02:20 AM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Looks like it bolts into the shaft mounting holes and uses a cheater handle with a fork? Wonder if I could build one......damn budget. Thanks for the link!
Re: Valve spring swap [Re: Hotlumpy] #2009064
02/10/16 03:01 AM
02/10/16 03:01 AM
Yes just weld a pair of ears to a plumbing "T" with a pipe nipple screwed into it for a handle. Use a short/stout dummy horizontle shaft & bolt it to 2 saddles at a time. EDIT A small telescoping magnet works VG for snatching the keepers
Re: Valve spring swap [Re: Hotlumpy] #2009442
02/10/16 07:35 PM
02/10/16 07:35 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
If you build your own, just make sure the handle doesn't hit the master cylinder on #7 when you compress the springs.
