Re: 68 Pickup six to 440 swap
[Re: 70mopes]
#2006639
02/06/16 12:21 PM
02/06/16 12:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
a 383 was an available option in that truck. So putting in a 440 isn't too far off the restoration aspect of your skill set.
Truck probably has an 8 3/4 in it anyway so that should be ok. Don't know what it has for a trans, but if it's a stick then it'll be the NP435 and that will handle the 440, with the right bell housing of course.
[Re: Supercuda]
#2006722
02/06/16 01:56 PM
02/06/16 01:56 PM
RapidRobert
I have a 65 D100 /6 3 speed on column 8&3/4. this is a hyd clutch setup. I have BB OE mtr mts for it and it takes a front sump pan and I am going to Iowa in several hours to pickup a granny 4 sp/hyd clutch BB bellhousing complete setup for it. If going with a 727 there is a bolt in OE crossmember available and speedway mtrs has aftermarket crossmembers that slip in to a bolt in end piece on each side for a pretty easy fab. I believe your truck needs a REAR sump BB pan. I have one for you & the pickup I believe is still with it.
[Re: 70mopes]
#2008136
02/08/16 07:59 PM
02/08/16 07:59 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
I was thinking of using the truck forum but there is so much knowledge in the General Q&A, I thought I'd give this a shot.
The truck is a 67 actually. He brought it over yesterday. 8 3/4 rear like SupeCuda said so that's good. It's an original slant six, auto with the shifter on the dash - which I believe is a cable setup straight back to the trans?
I would assume a driveshaft would have to be made for it when going with BB and 727?
It is a manual steering, drum brake truck. He asked me yesterday to make it into a power steering, disc brake setup. Man.... I have some 68-73 power steering gears in my shop, would those work? I have a 70 A-body power steering pump as well and was wondering about running that.
The Disc Brake mod.... I really don't know where to start there...
Rapid Robert, if you have that pan and pickup and it will also work on a 67, I would be happy to make a deal with you on them. Thanks for the offer.
[Re: 70mopes]
#2008191
02/08/16 10:01 PM
02/08/16 10:01 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Good Sweptline site http://www.sweptline.org/forums/index.phpPower steering is a challenge on these trucks. The factory setup used an assist cylinder with a control valve incorporated into the drag link. Hard to find, prone to leaks and costly and difficult to rebuild. There used to be a couple of kits that used either a Ford or Toyota 4x4 box but I think they're out of production. Scarebird has a bracket kit to put discs on the straight axle. https://scarebird.com/index.php?route=product/product&path=64&product_id=117Some guys swap the cab onto a 73-93 frame which will solve the problem but lots of work. Another way is to just use the 73-93 front clip. If I was doing one I would use an 04 and up cop spec Crown Vic clip. This gets you rack and pinion, big brakes and a suspension that is designed for a heavier vehicle that needs to handle well. Kevin
[Re: vdriver]
#2008256
02/08/16 11:12 PM
02/08/16 11:12 PM
RapidRobert
Yeah me too as I have a '65 and a rear sump on the shelf & if I got it straight (somewhere I recently read it) that I need to get a front sump for my 440 swap into it. if it does take a rear sumper I'm happy
[Re: 70mopes]
#2008329
02/09/16 12:41 AM
02/09/16 12:41 AM
RapidRobert
Rapid Robert, if you have that pan and pickup and it will also work on a 67, I would be happy to make a deal with you on them. Thanks for the offer. Yeah first we gotta find out which sump we both need (65 D100 here) & let me check if I have the pickup with it, I thought I did but let me check (too many projects going on at the same time OCD)
[Re: RapidRobert]
#2008512
02/09/16 01:15 PM
02/09/16 01:15 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
You def need rear sump pan, pickup and dip stick. I made my motor mounts but you can use factory ones if you can find. I have a picture, but can't seem to find how to add attachments?
2008 Challenger SRT8 1940 Chrysler Royal coupe
[Re: dogdays]
#2008637
02/09/16 04:29 PM
02/09/16 04:29 PM
shaker340
Eastern Ontario
Just to clarify, my 64 truck has Rod Weimer mustang 2 style front K frame and suspension, requiring any front sump pan to be converted to rear. If the truck still has solid axle, there may be room for front sump on BB engines.
[Re: 70mopes]
#2008665
02/09/16 05:10 PM
02/09/16 05:10 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
CPP makes a bolt in power steering kit. Scarebird and a few other sources have a disc brake kit. You will probably have room to use either a front or rear sump pan. They were all front originally.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2008830
02/09/16 09:57 PM
02/09/16 09:57 PM
RapidRobert
I found mine today & it is a front sump, not sure if any of the several pickups I have is the right one for it. If it turns out you need the front sumper (& I dont) then I will mock em up & see if one of em is the correct one for that front sump pan (I'm drilled/tapped to 1/2 NPT so I wouldn't need/use an OE front sump pickup IF I have one). 65 D100 451
[Re: vdriver]
#2009215
02/10/16 02:02 PM
02/10/16 02:02 PM
RapidRobert
Vdriver thank you! I'll do some more checkin today
