W2 casting # 4532689 ( corrected - 4532693) #2007885
02/08/16 12:56 PM
02/08/16 12:56 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Is this a valid casting number? I think its a 48 degree head (47cc chamber) but cant find any intel on it.
Looking at a complete R block 365" asphalt circle track motor to maybe use as the foundation for a turbo motor devil
Thanks!!
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2007952
02/08/16 03:24 PM
02/08/16 03:24 PM
Smyrna, South Carolina
STEFF Online content
STEFF  Online Content
Not sure on the part number, but they did make a 48 degree version of the W2. The dead give away is the pushrod clearance hole cuts thru the intake face.
Re: W2 casting # 4532689 [Re: STEFF] #2007996
02/08/16 04:37 PM
02/08/16 04:37 PM
Weddington, N.C.
Weddington, N.C.
What can you tell from this pic? I havent laid eyes on it yet
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2008016
02/08/16 05:11 PM
02/08/16 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Like we talked about on the phone... those are
the race W-2 heads.. I think all the casting
numbers are the same(I'm down in Texas so I cant
look at either set of W-2 I have to see the casting
numbers).. I cant see in the pic if the intake wall
is notched for the PR.. I have a set of 59* that
have the notch in the intake wall for the PRs... the
race head and the econo are basically the same other
than the econo has the cast in shaft stands.. the race
head has them milled off... they make a long and short
valve for them also... the normal long valve uses a 2"
spring height.. as to the intake like we talked about..
a measurement would be needed to see if it would work
wave
Re: W2 casting # 4532689 [Re: MR_P_BODY] #2008045
02/08/16 05:50 PM
02/08/16 05:50 PM
Weddington, N.C.
Weddington, N.C.
Thanks again, Mike!!
BTW, we were talking about bridgeporting this bad boy to try to fit a 9.2" deck block
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2008048
02/08/16 05:54 PM
02/08/16 05:54 PM
Pull the intake. You'll know immediately.
Re: W2 casting # 4532689 [Re: Streetwize] #2008049
02/08/16 05:54 PM
02/08/16 05:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have one of those for W-2s.. pretty sure its
a 4500 type.. but not positive since its been a
while since I've looked at it
wave
Re: W2 casting # 4532689 [Re: MR_P_BODY] #2008050
02/08/16 05:56 PM
02/08/16 05:56 PM
Weddington, N.C.
Weddington, N.C.
Thinking Turbo/EFI with a custom sheetmetal Top...maybe
Stef,
Probably going to pull at least one head, more curious about the Chamber CC.
It's 365 cube and allegedly 11:1, that would infer (assuming flat top 'spec' pistons' it would have a small closed chamber head.
Allegedly the 48 degree heads flow better than the 59's, was that due to a smaller pushrod bulge or is it also a different (15 degree) valve angle?
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2008060
02/08/16 06:13 PM
02/08/16 06:13 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Jegs still lists a 48 and 59 degree W2 on their website. I was trying to find the PT number you had listed but no luck.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 casting # 4532689 [Re: pittsburghracer] #2008071
02/08/16 06:26 PM
02/08/16 06:26 PM
Weddington, N.C.
Weddington, N.C.
I'm wondering if there are 2 series of numbers and my buddy read "the other one" confused
WIZE
In Car:
Re: W2 casting # 4532689 [Re: pittsburghracer] #2008075
02/08/16 06:30 PM
02/08/16 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What he shows it the casting number... those arent
really what anyone shows normally... I think they
have the same casting numbers on a LOT of the W-2
stuff.. I had one econo and race head.. they both
had the same casting numbers... I cant say if both
the 48* and 59* start out as the same casting or not
but with the small changes they could
wave
Re: W2 casting # 4532689 [Re: MR_P_BODY] #2008113
02/08/16 07:29 PM
02/08/16 07:29 PM
Weddington, N.C.
Weddington, N.C.
We'll snap some pics once we get the head off.
Anybody got anything on the 48 vs 59 Head flow and why the 48's are better OOTB?
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2008119
02/08/16 07:36 PM
02/08/16 07:36 PM
dogdays Offline
dogdays  Offline
You mean besides the fact that the pushrods aren't going off in all directions?
R.
Re: W2 casting # 4532689 [Re: dogdays] #2008132
02/08/16 07:48 PM
02/08/16 07:48 PM
Weddington, N.C.
Weddington, N.C.
More in that I thought the 48's flowed better, believe me I know about the pushrod angles!! I never had 48's before, after seeing what 48 degree roller cam blanks can cost, I'm beginning to remember WHY!
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2008395
02/09/16 02:49 AM
02/09/16 02:49 AM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Sure thats not 4532693? My W2s are 48* and that's what they have on them. Tough to read of course
Re: W2 casting # 4532689 [Re: Belvedere2] #2008438
02/09/16 09:58 AM
02/09/16 09:58 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I recently got rid of a set of 47cc W2s that were for 48° with a 15° valve angle. Part number is P5007708AB but the casting number is P4532693. The latest version of W2s had revised ports (larger bowls and reduced pushrod pinch) but I do not know if the changes were across the board or only on the 15° valve angle heads.
Re: W2 casting # 4532689 [Re: 496 A-body] #2008444
02/09/16 10:52 AM
02/09/16 10:52 AM
Weddington, N.C.
Weddington, N.C.
That's probably them, it's easy to get 3's and 8's and even 9's confused with those castings, I haven't seen them but I'm sure the big Jesel baseplate doesn't help seeing it clearly either.
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2009210
02/10/16 01:48 PM
02/10/16 01:48 PM
Weddington, N.C.
Weddington, N.C.
Just a follow up, we pulled the head and it's a 693 48 degree and it's definitely a 48 degree R block. Looks like a steel crank 3.58" 340 main with H beam rods and the bores are 4.03". Good news, it has at least a couple overbores left in it and it may hone fine where it's at.
The bad news, the Heads are Open chamber frown but for some reason the chambers look smaller than the last pair of W2's I put on the 360 based 440. Were there 2 sizes of Open chamber W2's? May have been milled I suppose but we're still digging into it. Ports look untouched and the intake is the MP stock looking 4 bbl dual plane.
also for some reason (I suppose in an effort towards saving 2 1/2 whole oz on the 220 pound block), they chose to mill the top "extra" row of head bolt holes out of the block....why would anybody do that?
WIZE
In Car:
Re: W2 casting # 4532689 [Re: Streetwize] #2009404
02/10/16 06:13 PM
02/10/16 06:13 PM
Washington
madscientist Offline
Washington
That is my favorite chamber. I don't care for that closed chamber deal they have.
I don't know why every one gets all spun out on that chamber. It SHOULD make more HP than the closed one.
I'm not sure why they milled off the upper row of head bolts.
EDIT: do not mill the chamber down to close it. That is a sure HP killer.. And it makes the head weak.
Re: W2 casting # 4532689 [Re: madscientist] #2009600
02/11/16 12:27 AM
02/11/16 12:27 AM
Weddington, N.C.
Weddington, N.C.
Its really in good shape
The W2's are the same dual exhast pattern ones I have on the 440 stroker except 48 degrees
WIZE
In Car:
