Brake Pad hanging up
#2006910
02/06/16 07:34 PM
02/06/16 07:34 PM
Posts: 16,160 Mesa, Arizona
dart4forte
Mesa, Arizona
Subject matter is a 2007250 4WD CTD.
Just got back from a 500 mile run and noticed I have an excessive amout of brake dust on the driver side front. My concern is the pads are hanging up or the caliper piston is not disengaging. Anyone else have a problem with this? I'll be taking it to the shop on Monday to have a look.
Abe Lincoln
Re: Brake Pad hanging up
[Re: dart4forte]
#2006974
02/06/16 09:22 PM
02/06/16 09:22 PM
Posts: 129 London Ontario Canada Eh
Dono
Yes over and over. My 06 1500 just had the front wheel bearing done and rotor because it got so hot the last time it hung, it warped the rotor. It took about four months before the wheel bearing went but I am expecting that was the cause of the premature failure.
Had one hang on the rear as well and it took out the rear axle seal on the passenger side.
Both times the brake caliper was warrantied but none of the other damage was.
I have gotten in a habit now spring and fall to pull them off put some anti seize on the two stainless rods.
Pop it off run some sand paper in them and on the rods then silver anti seize and your off.
Cheers Don.
[Re: dart4forte]
#2007242
02/07/16 10:14 AM
02/07/16 10:14 AM
Posts: 5,919 ohio
ruderunner
ohio
Antiseize on brake parts is evil. It WILL make the rubber seals and bushings for the pins swell and makes things stick worse.
Use caliper lube (siicone based)
Backyard mechanics that did antiseize have paid me well to fix their problems.
Angry white pureblood male
[Re: Dono]
#2007933
02/08/16 03:03 PM
02/08/16 03:03 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
I wouldn't use sand paper on the pins. Cleaners, fine steel wool etc. don't want any scratches on them. use a good caliber lube. I always clean the slides good. if u do your own work, a lot of new pads new to be ground down so they slide free when installed or they hang up.hope u get fixed
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: dart4forte]
#2007941
02/08/16 03:15 PM
02/08/16 03:15 PM
Posts: 5,919 ohio
ruderunner
ohio
Yes the boots on the pins, many vehicles have small bushings for the pins that will swell and stick the pins. Mule is right that sometimes pads need the backing clearanced. Also rust buildup on the support brackets need cleaned off.
[Re: dart4forte]
#2008253
02/08/16 11:09 PM
02/08/16 11:09 PM
Posts: 5,919 ohio
ruderunner
ohio
Neither am I.
Stock lube is too sparse IMHO.
Corrosion is a big deal in my area. Not yet set and salt, but the brine they spray is plain evil to anything metal. Keeping the brine out of moving parts is paramount to keeping things working right.
With properly lubed and cleaned slides my pplow truck hasn't needed brake attention in 3 years.
