Better headlights #2006887
02/06/16 07:02 PM
02/06/16 07:02 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I have a 67 Coronet that has T-3 style headlights that I would like to upgrade as they are more yellow than white even when relayed. I also have a gm 140 amp altinator so I have plenty of juice.
Is there a nice bright lowbeam light that doesn't cost a lot. Seems like there are a lot of choices and I want to make the right one.
Re: Better headlights [Re: rapom] #2006899
02/06/16 07:18 PM
02/06/16 07:18 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Go to www.rockauto.com and go through the drill of selecting the year, make & model, then select the headlight button. You will get a selection of headlights that will bolt in all the way from stock to the latest and greatest. I went through the drill and found that the cheapest high performance are the Halogen lights, but if I wanted to stepup to the ludicrous I could go for a LED conversion at $250+ per side on my '87 D100.
When you order use this discount code 4095595737193261 in the "How did you hear about us?" and don't put anything else in there and you will get an additional 5% discount. They said I could share, so I am.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Better headlights [Re: rapom] #2006902
02/06/16 07:22 PM
02/06/16 07:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Simple halogens will make a world of difference, especially since you already have the relay setup. I equate the old T3 incandescent bulbs to holding a Bic lighter out the window and trying to see with that.
Don't be the exception.
Re: Better headlights [Re: Supercuda] #2006920
02/06/16 07:47 PM
02/06/16 07:47 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thanks for the tips and the Rockauto code. I'll check them out.
Re: Better headlights [Re: rapom] #2006957
02/06/16 08:47 PM
02/06/16 08:47 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Sell the t3 on eBay to a GM guy. Can be worth a few bucks.
Angry white pureblood male
Re: Better headlights [Re: rapom] #2007074
02/07/16 12:09 AM
02/07/16 12:09 AM
CA
crackedback Offline
crackedback  Offline
CA
A good H5001 and H5006 would be a good upgrade. Less than $20 a side from rockauto.
Re: Better headlights [Re: rapom] #2009619
02/11/16 12:56 AM
02/11/16 12:56 AM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Did you do the headlight relay? With that big of an alternator by pass the amp gauge and update the wires. I did headlight relay on both my 69 bee and 84 ramcharger. It made a big difference
Re: Better headlights [Re: rapom] #2009651
02/11/16 01:37 AM
02/11/16 01:37 AM
CA
crackedback Offline
crackedback  Offline
CA
skajm makes a couple of good points.
Where are you pulling power for the relays?
With that large of an alternator, have you done a wire around solution?
Wire sizing for the relay kit? If you used 14ga, you really didn't do yourself much benefit except to sidestep the bulkhead and headlight switch/dimmer.
Every person that has put my relay kit on a car, even with old style bulbs, can't believe the difference in light output and quality.
Re: Better headlights [Re: Supercuda] #2009671
02/11/16 02:07 AM
02/11/16 02:07 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Rockauto codes [Re: TJP] #2009899
02/11/16 03:48 PM
02/11/16 03:48 PM
dogdays Offline
dogdays  Offline
Rockauto discount codes are best and easiest found at
www.retailmenot.com
There are normally a dozen or more codes working.
R.
Re: Rockauto codes [Re: rapom] #2010685
02/12/16 08:07 PM
02/12/16 08:07 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Any suggestions for an E Body that lights up as well as halogens and still maintaining stock seal beam appearance? Forgetting for the moment the suggestions on installing relays.
Non stock looking headlights can look out of place on a more factory like car.
Re: Rockauto codes [Re: Sxrxrnr] #2010758
02/12/16 09:46 PM
02/12/16 09:46 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had a '64 Polara hardtop from 1997 to 2010 and one of the first things I did to it was to change all the headlights to Halogen units, because I actually drove it and wanted see where I was going at night. I also changed the drum brakes to the disc brakes because I wanted to be able to stop it. Now if your goal is to have a mantle piece, more power to you.
2008 Honda Element
Re: Rockauto codes [Re: Sxrxrnr] #2011111
02/13/16 03:14 PM
02/13/16 03:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Standard sealed beam halogens are as close to original looking as you will find without actually running the crappy incandescent headlights.
You must be thinking of E codes that have a replaceable bulb in a lense housing.
Since you don't say what E body here's an example for a 70 Challenger
http://www.rockauto.com/en/moreinfo.php?pk=319003&cc=1078433&jsn=484
Re: Rockauto codes [Re: Supercuda] #2011124
02/13/16 03:42 PM
02/13/16 03:42 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Look great. These and relays would be the ticket. Our E Body is a 70 Challenger.
Re: Rockauto codes [Re: rapom] #2011134
02/13/16 03:55 PM
02/13/16 03:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Lucky guess for me, lol.
Re: Rockauto codes [Re: Polarapete] #2011136
02/13/16 04:00 PM
02/13/16 04:00 PM
None
71rm23 Offline
71rm23  Offline
None
Polarapete...that's SWEEET!
Re: Rockauto codes [Re: 71rm23] #2011611
02/14/16 06:27 AM
02/14/16 06:27 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I sold it on E-bay in 2010 and last I heard it was in the Chicago area. I boxed up all of my spare parts (10 big boxes) and shipped them all to the new owner, it was not part of the original deal...I wanted the break to be complete and if I had those parts laying around my garage it would just make the sellers remorse harder to bear.
2008 Honda Element
