Camshaft lobe chamfering #2006889
02/06/16 07:05 PM
02/06/16 07:05 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
Regarding a topic I noticed earlier one day here, about someone noticing some ugly casting flesh besides a lobe, I did some searching on the net about this.
I noticed some Eurocar (VW/BMW) camshafts have nice chamfered lobes, while most, pretty much all US camshafts have sharp lobe edges.
Of course millions of cams never had any issues. But anyone see any benefit to this and ever carefully chamfered the lobes on a flat tappet camshaft before break in, for added security to prevent wiping a lobe/digging into a lifter?
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2006907
02/06/16 07:29 PM
02/06/16 07:29 PM
crabman173
crabman173
Racer Brown has always made his lobes and in between Nice like that--me likey
I have had some Comps that would scare you to death with all the casting crud on them--sure thing nobody looked at them or cared--does it matter? Maybe not but...get a Racer Brown in your hands and you can just see the workmanship/ detail/ and IMO quality of overall product Cam Motion also details cams --speaks to the overall quality IMO
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2006961
02/06/16 08:53 PM
02/06/16 08:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
billet cam in the pic? vs a cast iron? apples to apples?
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2006978
02/06/16 09:29 PM
02/06/16 09:29 PM
The Netherlands
The Netherlands
The above picture was mainly used as a nice example of chamfered lobes, but the cam in the pic is from a 2005ish VW/Audi TDI engine.
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2007186
02/07/16 02:41 AM
02/07/16 02:41 AM
I've seen camshafts out of a Roll Royce car engine and one out of a Rolls Royce Merlin WW2 aircaft engine that look like the one in your picture up bow No unmachine surface in view grin
I've also ran a bunch of flat tappet cams that look like stock production OEM cams that never had a problem at all shruggy I've had more than one after market flat tappet junky looking Hi Po cam go flat also work
Your choice on detailing it confused
Re: Camshaft lobe chamfering [Re: Cab_Burge] #2008117
02/08/16 07:34 PM
02/08/16 07:34 PM
dogdays Offline
dogdays  Offline
No digging in on the sides is possible unless your lifter geometry is waaaaay off. If anything is going to be digging in it would be the leading edge of the lifter which should be very nearly in the center of the lobe, just moved over slightly because of the lobe taper and lifter crown.
R.
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2008134
02/08/16 07:51 PM
02/08/16 07:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They look nice and does show quality.. but is it
needed.. I dont think so... I have never wiped a
lobe out(95% rollers)... now I probably just cut
my throat saying that... those little casting chunks
would hold oil(in between the lobes) but none of that
is needed there... maybe(I dont know)they can throw off
oil to the lifter bottoms shruggy
wave
Re: Camshaft lobe chamfering [Re: BigBlockMopar] #2008443
02/09/16 10:51 AM
02/09/16 10:51 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I was getting some proto cams made by LSM, for a DOHC application, and the slider follower would on occasion kick out and get chewed up. I took a small diamond hone to the edges, not to help with the issue, but to decrease the number of cuts on my hands from handling them...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
