TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION #2006548
02/06/16 04:24 AM
02/06/16 04:24 AM
las vegas
70AARcuda Offline OP
las vegas
One of the challenges for bracket racer has always been what to do when both racers, with different dial-ins, go red.
K&N Spring Fling Million co-promoters, Peter Biondo and and Kyle Seipel were passionate about coming up with a solution and Bob Brockmeyer of Compulink, the most widely used timing system in the world, quickly agreed and started working hard into turning the idea into a reality. Simply put: in a handicapped race where both drivers go red, TruSTART will change the game by giving the win to the racer who red lights by the lesser amount. The worst red-light loses, period, regardless of if a driver leaves first or last.
“We actually tried this back in 1986,” says Brockmeyer, “but for whatever reason it didn’t take off. When Peter and Kyle talked to me about it last year, it just made sense now. Prior to TruSTART, the advantage in the red-light department went to the faster car. This helps to make it just that much fairer. Just like whoever breaks-out the most loses, so be it when it comes to a red-light.”
TruSTART, a product of Compulink and the Spring Fling, will be introduced to the bracket racing world at the K&N Spring Fling Million in Las Vegas on April 12-16.
https://www.youtube.com/watch?v=VpNXr5pGhhw
Tony
70 AARCuda Vitamin C
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006570
02/06/16 06:33 AM
02/06/16 06:33 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Let the crying begin.
I personally like the idea, but my junk is slow so it will benefit me.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: slantzilla] #2006594
02/06/16 10:13 AM
02/06/16 10:13 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
understandable, I believe that when one goes red, it can startle the other one to go red. good luck on this one.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: Deepockets] #2006660
02/06/16 12:53 PM
02/06/16 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I built my car quicker just to have the old way
benefit me.. most times I left last ... this is
a fairer way but its like changing in the middle
of the stream.. shruggy.. and it will piss off
some guys
wave
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: Deepockets] #2006672
02/06/16 01:09 PM
02/06/16 01:09 PM
gregsdart Offline
gregsdart  Offline
It has happened to me more than I want to admit. Being on average the faster car, I like the old system.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006705
02/06/16 01:41 PM
02/06/16 01:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Can't see why anybody would have a problem with this. You break out more you lose, so it makes sense you go red by more you lose.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006732
02/06/16 02:06 PM
02/06/16 02:06 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
You running the Spring Fling Tony? I hear it's a blast with lots of prizes and $$$ to be won. Heavy entry but heavy payouts. Looks like you have to be on your game. Has always looked interesting to me work
https://www.springflingmillion.com/prizes-2015.ph
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006763
02/06/16 03:03 PM
02/06/16 03:03 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
This has been an age old problem for the slower cars. Everyone understood the problem but NHRA. Several years ago I had considerable correspondence with NHRA on this subject but their minds were totally blocked. I even went to the extreme to build a simulation program with a fast car and a slow car with each driver red lighting the same percentage of time just to prove the advantage to the faster car. We ran the simulation 1 million times and as any sensible person would expect the advantage to the faster car was significant. If I remember correctly the advantage was 10% more wins. The written answer from NHRA was that they had reviewed the data from many races and it was not born out that the advantage went to the faster car. What a bunch of crap!!
The software change is so minor it's unbelievable that it has taken so long for the timing companies to finally address the issue. Years ago it did not impact me as much because there were a bunch of slower cars than mine in Super Pro. Now with me running 6.4-6.5 in the eigth I'm either the slowest car in the field or there may be one slower than me. Times have sure changed.
I am one who is elated to see the problem getting addressed if for no other reason but to level the playing field.
GLAD TO SEE THIS, HOPE IT IS IMPLEMENTED ACROSS THE BOARD!!!!!
Max
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006767
02/06/16 03:05 PM
02/06/16 03:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I like it!!!
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006789
02/06/16 03:33 PM
02/06/16 03:33 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
It is about f$&@ing time. The advantage has always been with the faster car!!!!! BUT this is one NON sanctioned bracket race! It is a start but unless Brockmier is willing to grease NHRA's pocket with mega cash and the evil empire is able to figure out a way to make the racers re certify their ability to red light every two years I personally don't see it happening. Money rules this sport and most rich guys don't run slow PERIOD!!!!!! Their ego will not allow it and the money men have NHRA 's ear. Don't see it happening unless Force thinks it is a good idea. Oh yah I forgot! That is already the rule in his class!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006797
02/06/16 03:54 PM
02/06/16 03:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yep, that's how it is in pro tree racing.
I'm OK with this change. Fast car still has advantages. May as well make them work for it on the starting line every pass. "Live by the sword, die by the sword" and all that.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: MoParFish] #2006799
02/06/16 04:00 PM
02/06/16 04:00 PM
las vegas
las vegas
I believe they are only running Super Pro this year...not sure ..have the delay box out of the car as of now.
Tony
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006841
02/06/16 05:34 PM
02/06/16 05:34 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Personally I dont see the need for the change. Been on both ends of the situation and never gave it a 2nd thought.
I dont think it will take off so right not worried about.
Ok
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006852
02/06/16 05:58 PM
02/06/16 05:58 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
They still call it a race. Shouldn't the faster car have some advantage?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006857
02/06/16 06:06 PM
02/06/16 06:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No........because its a "bracket race" meaning closer to the dial wins. Why shouldn't that apply to both ends of the track
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006878
02/06/16 06:51 PM
02/06/16 06:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
“The way TruSTART will function will be exactly how we imagined it thanks to all of Bob’s hard work. To keep things fair within TruSTART, the slower car lane will always show a green light until the faster driver launches. At that point Compulink will ‘show’ the worst red where applicable.”
So if the slow car red lights, the fast car's win light will come on as soon as he leaves and vice-versa. You still know you have a free pass as soon as you leave. Seems fine to me. Don't red light only thing I can tell you.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006881
02/06/16 06:57 PM
02/06/16 06:57 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This will be good, would like to see it in all classes esp stock & super stock. I agree, no money in it for NHRA. The faster car already has the advantage of not looking over the shoulder at the stripe.
Why should a faster car have more advantages? Entry fees and purse is the same for all within any class.
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: NANKET] #2006890
02/06/16 07:05 PM
02/06/16 07:05 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
So what's next? If one car goes red and the other breaks out, they going to figure who was the worst too?
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: Deepockets] #2006936
02/06/16 08:02 PM
02/06/16 08:02 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Let's compare Apples to Oranges!
Thanx 451 Guy
Re: TRUSTART SYSTEM TO DEBUT AT VEGAS SPRING FLING MILLION [Re: 70AARcuda] #2006949
02/06/16 08:22 PM
02/06/16 08:22 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When I started racing at US 30, if both cars went red or broke out, or if you went red or broke out on a bye, you lost. Both cars red /broke out in the finals, both got 2nd place money. You also had to race for 3rd and 4th place money.
I can't imagine the screaming if a track tried that now.
