r block cam #2006588
02/06/16 10:01 AM
02/06/16 10:01 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i have a r block 48 degree std la cam tunnel ,and i have a cam 48 degree with the same journals all the way threw ,is it best to grind the cam down or bore the cam tunnel to size
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: r block cam [Re: Ian] #2006599
02/06/16 10:54 AM
02/06/16 10:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would think cutting the cam down would go threw the hardening on it. Don't know but I would call Bullet, lsm or predator cams.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: r block cam [Re: Ian] #2006621
02/06/16 11:49 AM
02/06/16 11:49 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
I would bore the cam tunnel out and put roller cam bearings in it. up
Re: r block cam [Re: Ian] #2006628
02/06/16 12:07 PM
02/06/16 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get the right cam blank... if you have to go
with the one you have, have the cam ground down
and get it nitrited
EDIT
after thinking about it... bore the tunnel out and
change it to a roller tunnel... the blank you have
is it a flat tappet or roller blank.. they are diferent
wave
Re: r block cam [Re: MR_P_BODY] #2006683
02/06/16 01:20 PM
02/06/16 01:20 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Big cam core+less cam deflection ====more HP
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: r block cam [Re: WHITEDART] #2006988
02/06/16 09:47 PM
02/06/16 09:47 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
cam is a callies cam core 1.988 babbit bearing .is there a good aftermarket cam bearing that will last with solid roller spring pressure 280 on the seat 650 open ,i will see on boring the cam tunnel .what are the pros and cons of turning it in to a roller tunnel ,is that a different cam again
Re: r block cam [Re: Ian] #2007106
02/07/16 12:45 AM
02/07/16 12:45 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Durabond bearing would be fine. I had a 50mm cam ground for around 450. Indy ripped me for 750 to bore the tunnel since I already had a 500mm cam. Been running roller cam bearings for a few yrs now, no problems.
Re: r block cam [Re: rickraw] #2007174
02/07/16 02:11 AM
02/07/16 02:11 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
are the cam cores the same size for the babbit bearing and the roller bearing
Re: r block cam [Re: Ian] #2007252
02/07/16 11:14 AM
02/07/16 11:14 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
No. Roller bearings have a bigger diameter. I don't remember the size.
Re: r block cam [Re: rickraw] #2007282
02/07/16 12:46 PM
02/07/16 12:46 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Plain bearing is larger than roller bearing cam.
So plain bearing mains can be ground to run on roller bearings.
Can't use roller cam 50mm in plain bearing block.
Re: r block cam [Re: Ian] #2007287
02/07/16 12:56 PM
02/07/16 12:56 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Thinking about picking up a 9.2" deck 48 degree R block. Is there anywhere I could bone up on the cam bore/bearing differences?
Was thinking about doing a short 3.7-ish inch ( for me, lol) stroke turbo motor.
Might not be up for a $500.00 cam core that's gonna be hard to come by...lol
WIZE
In Car:
Re: r block cam [Re: Streetwize] #2008080
02/08/16 06:36 PM
02/08/16 06:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Then a r block might not be the right choice, as all came out their are designed for NA motors. You would have to run a custom core to get the proper cam for a power adder car. You can make something work like I did, but it won't be close to ideal.
Re: r block cam [Re: 1967dartgt] #2008427
02/09/16 07:41 AM
02/09/16 07:41 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Bore the tunnel Ian, you will struggle finding 48* cam cores with factory bearing configuration. The babbit journal size is 1.998" or 50.75mm, so be mindful of that. I remember being told that a durabond bearing was available that fit into the 50mm roller bearing bore, but allowed a 55mm core to be used.
Alan Jones
Re: r block cam [Re: LA360] #2008445
02/09/16 10:56 AM
02/09/16 10:56 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i will mate,the cam i have is a 1,998 babbit bearing cam ,which is a better bearing the babbit or durobond and are they the same size as the front bearing on a la block .crankshaft rebuilders are going to bore it ,clive cams said you can turn the jurnells down and the do not need to be heat treated
Re: r block cam [Re: Ian] #2008728
02/09/16 07:04 PM
02/09/16 07:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Predator cams has Babbitt ugl cams in stock. It's where I got mine.
Re: r block cam [Re: Ian] #2009075
02/10/16 04:18 AM
02/10/16 04:18 AM
LA360 Offline
LA360  Offline
Have them quote you on doing the cam tunnel, it might be a wash when compared to grinding the journals on the cam down. Saliba's in Springvale can do the cam tunnel if Cranky's can't, but Charlie isn't quick.
Alan Jones
Re: r block cam [Re: LA360] #2009717
02/11/16 05:25 AM
02/11/16 05:25 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
can the r block tunnel be bored out to handle 60 mm roller cam .i have sitting here too
Re: r block cam [Re: Ian] #2010046
02/11/16 07:48 PM
02/11/16 07:48 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Yes.
Re: r block cam [Re: rickraw] #2010983
02/13/16 09:53 AM
02/13/16 09:53 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
anyone ,have a part number on the babbit bearings or durobond thanks
Re: r block cam [Re: Ian] #2012066
02/14/16 10:35 PM
02/14/16 10:35 PM
LA360 Offline
LA360  Offline
If you're going to go to 60mm, go with the roller bearings. Do you still have those 60mm cams your got off Craig?
Alan Jones
