Re: r block cam
[Re: Ian]
#2006599
02/06/16 10:54 AM
02/06/16 10:54 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would think cutting the cam down would go threw the hardening on it. Don't know but I would call Bullet, lsm or predator cams.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: r block cam
[Re: Ian]
#2006628
02/06/16 12:07 PM
02/06/16 12:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Get the right cam blank... if you have to go with the one you have, have the cam ground down and get it nitrited EDIT after thinking about it... bore the tunnel out and change it to a roller tunnel... the blank you have is it a flat tappet or roller blank.. they are diferent
Re: r block cam
[Re: rickraw]
#2007174
02/07/16 02:11 AM
02/07/16 02:11 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Durabond bearing would be fine. I had a 50mm cam ground for around 450. Indy ripped me for 750 to bore the tunnel since I already had a 500mm cam. Been running roller cam bearings for a few yrs now, no problems. are the cam cores the same size for the babbit bearing and the roller bearing
Re: r block cam
[Re: Ian]
#2007287
02/07/16 12:56 PM
02/07/16 12:56 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Thinking about picking up a 9.2" deck 48 degree R block. Is there anywhere I could bone up on the cam bore/bearing differences?
Was thinking about doing a short 3.7-ish inch ( for me, lol) stroke turbo motor.
Might not be up for a $500.00 cam core that's gonna be hard to come by...lol
Re: r block cam
[Re: Streetwize]
#2008080
02/08/16 06:36 PM
02/08/16 06:36 PM
1967dartgt
Hilltown Pa
Might not be up for a $500.00 cam core that's gonna be hard to come by...lol Then a r block might not be the right choice, as all came out their are designed for NA motors. You would have to run a custom core to get the proper cam for a power adder car. You can make something work like I did, but it won't be close to ideal.
Re: r block cam
[Re: 1967dartgt]
#2008427
02/09/16 07:41 AM
02/09/16 07:41 AM
Posts: 6,144 Melbourne , Australia
LA360
Bore the tunnel Ian, you will struggle finding 48* cam cores with factory bearing configuration. The babbit journal size is 1.998" or 50.75mm, so be mindful of that. I remember being told that a durabond bearing was available that fit into the 50mm roller bearing bore, but allowed a 55mm core to be used.
Alan Jones
Re: r block cam
[Re: LA360]
#2008445
02/09/16 10:56 AM
02/09/16 10:56 AM
Ian
Victoria, Australia
Bore the tunnel Ian, you will struggle finding 48* cam cores with factory bearing configuration. The babbit journal size is 1.998" or 50.75mm, so be mindful of that. I remember being told that a durabond bearing was available that fit into the 50mm roller bearing bore, but allowed a 55mm core to be used. i will mate,the cam i have is a 1,998 babbit bearing cam ,which is a better bearing the babbit or durobond and are they the same size as the front bearing on a la block .crankshaft rebuilders are going to bore it ,clive cams said you can turn the jurnells down and the do not need to be heat treated
Re: r block cam
[Re: Ian]
#2008728
02/09/16 07:04 PM
02/09/16 07:04 PM
1967dartgt
Hilltown Pa
Predator cams has Babbitt ugl cams in stock. It's where I got mine.
Re: r block cam
[Re: Ian]
#2009075
02/10/16 04:18 AM
02/10/16 04:18 AM
LA360
Bore the tunnel Ian, you will struggle finding 48* cam cores with factory bearing configuration. The babbit journal size is 1.998" or 50.75mm, so be mindful of that. I remember being told that a durabond bearing was available that fit into the 50mm roller bearing bore, but allowed a 55mm core to be used. i will mate,the cam i have is a 1,998 babbit bearing cam ,which is a better bearing the babbit or durobond and are they the same size as the front bearing on a la block .crankshaft rebuilders are going to bore it ,clive cams said you can turn the jurnells down and the do not need to be heat treated Have them quote you on doing the cam tunnel, it might be a wash when compared to grinding the journals on the cam down. Saliba's in Springvale can do the cam tunnel if Cranky's can't, but Charlie isn't quick.
Alan Jones
Re: r block cam
[Re: Ian]
#2012066
02/14/16 10:35 PM
02/14/16 10:35 PM
LA360
If you're going to go to 60mm, go with the roller bearings. Do you still have those 60mm cams your got off Craig?
Alan Jones
