8 3/4 sure grip #2005521
02/04/16 04:11 PM
02/04/16 04:11 PM
Western Pa
farmboy70 Offline OP
Western Pa
I recently picked this 489 case.
The owner said it was a Detroit locker and he hated it because of the binding when parking.
Can anyone identify if it is a Detroit locker from my pictures or let me know how to tell.
Thank
Re: 8 3/4 sure grip [Re: farmboy70] #2005523
02/04/16 04:17 PM
02/04/16 04:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Not a Detroit locker. It is a clutch type sure grip, used from 1958 - 1968. The clutches go in there in a specific order, outlined in the factory service manual. If not in the right order it will be to tight, snapping and binding on corners. This will break the spider gears if driven that way.
Re: 8 3/4 sure grip [Re: farmboy70] #2005526
02/04/16 04:20 PM
02/04/16 04:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a clutch type (power-lock) sure-grip.
Looks like it has been apart. The owner is most likely running an incorrect (Dana 44) clutch pack or he did not add a bottle of friction modifier to the gear lube.
Re: 8 3/4 sure grip [Re: farmboy70] #2005528
02/04/16 04:20 PM
02/04/16 04:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Was a clutch type sure grip ever used by the factory in a 489 case?
Re: 8 3/4 sure grip [Re: NANKET] #2005545
02/04/16 05:07 PM
02/04/16 05:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When the 489 was first introduced in late '68 I believe the clutch-type SG was used in it.
Re: 8 3/4 sure grip [Re: John_Kunkel] #2005550
02/04/16 05:26 PM
02/04/16 05:26 PM
dogdays Offline
dogdays  Offline
IMHO you lucked out as that is generally considered to be the cream of the limited slip crop for street cars that occasionally go to the dragstrip.
The blue color arc around the pin appears to be induction hardening of that area. Or is it heat transmitted through the pin? Enquiring minds want to know.
R.
Re: 8 3/4 sure grip [Re: farmboy70] #2005587
02/04/16 06:44 PM
02/04/16 06:44 PM
Western Pa
Western Pa
My mistake on the case number, I was working with three different axles this morning. It is a 742 case.
Re: 8 3/4 sure grip [Re: farmboy70] #2005714
02/04/16 10:12 PM
02/04/16 10:12 PM
Western Pa
Western Pa
Thanks everyone for the help. up
I will tear it apart and see if there is any obvious damage.
From what I have searched it looks like I could use this suregrip in a 489 case. Is that true? If so I could have the better suregrip with keeping my cars axle with the correct case numbers.
Thanks again
Re: 8 3/4 sure grip [Re: DoctorDiff] #2005717
02/04/16 10:21 PM
02/04/16 10:21 PM
Western Pa
Western Pa
The owner did say that when he bought the car ,the seller said it was rebuilt. He said other than that he has no info.
If it looks OK inside I will be in touch for parts to rebuild it.
Re: 8 3/4 sure grip [Re: dogdays] #2005720
02/04/16 10:23 PM
02/04/16 10:23 PM
Western Pa
Western Pa
R.
No idea, Dr Diff a little help here. LOL
Re: 8 3/4 sure grip [Re: farmboy70] #2005931
02/05/16 03:24 AM
02/05/16 03:24 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The heat signature around the V-ramps is due to induction hardening.
Re: 8 3/4 sure grip [Re: DoctorDiff] #2005945
02/05/16 04:06 AM
02/05/16 04:06 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Dr Diff, what is the difference between the 8.75 Power Lok and Dana 44 Power Lok 30 spline rebuild kit? I thought that most of the internal parts were interchangeable between the two?
Re: 8 3/4 sure grip [Re: dogdays] #2006072
02/05/16 02:26 PM
02/05/16 02:26 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
R.
Pretty sure it's hardening , everyone I have seen looks like that .
Re: 8 3/4 sure grip [Re: farmboy70] #2006100
02/05/16 03:03 PM
02/05/16 03:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
OEM 8.75" Power-locks used an odd-ball thin plate on the end of the clutch pack. Dana 44 Power-locks used all thick plates.
Re: 8 3/4 sure grip [Re: farmboy70] #2008093
02/08/16 06:49 PM
02/08/16 06:49 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Unless you have a specific reason for going with the 489 housing, I'd stick with the 742. No crush sleeve, or crush sleeve eliminator needed. Easier to set up IMO and less stuff to buy or replace.
