Page 1 of 3 1 2 3
Exhaust turndowns??? #2005373
02/04/16 11:47 AM
02/04/16 11:47 AM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
Thinking about taking off the tail pipes and mounting turndowns to the muffler ends. The turndowns would be in front of the rear axel.
My question is -Would this result in getting allot of exhaust fumes inside the cab and would the exhaust system become insanely louder???
Any one who done this mod, is it worth it?
Car has 3.5" X-pipe and Dynomax Ultra-Flo mufflers...
Thanks!
/Tom
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005376
02/04/16 11:53 AM
02/04/16 11:53 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Turn downs usually sound much louder in the car and can fume you up, too. Then there is the dust they kick up............
Master, again and still
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005380
02/04/16 11:58 AM
02/04/16 11:58 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine turn down in front of the axle and the noise is not bad. I don't notice the fumes either. It will blow dust everywhere though.
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005394
02/04/16 12:36 PM
02/04/16 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its in a truck(sounds like it is)the fumes
might not be bad since the bed is separate from
the cab... as to the noise.. the sound tends to
get bounched around under the car... the lower the
car is this tends to be more.. turn them out sideways
and it can lower that some... also on the fumes.. if
your cab is sealed up good it shouldnt be a issue
wave
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005406
02/04/16 01:03 PM
02/04/16 01:03 PM
Canada
onig Offline
onig  Offline
Canada
Yes louder.
More fumes as well, when sitting still.
69 Dart
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005413
02/04/16 01:15 PM
02/04/16 01:15 PM
Stockholm, Sweden
Stockholm, Sweden
This is for my street/strip 1970 Dodge Charger. I could live with a louder exhaust sound but I dont like the fumes part, so Ill probably skip this mod.
Thanks for the posts!
/Tom
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005433
02/04/16 02:05 PM
02/04/16 02:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The wife used to make me strip when I came in the door when I had turn downs,so I went the other way and sent the pipes out the back bumper whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005436
02/04/16 02:10 PM
02/04/16 02:10 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Had turndowns on my dart. Droned way more on the highway, fumes in traffic were noticeable, and could never back up on dusty/dirty road...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Exhaust turndowns??? [Re: OUTLAWD] #2005440
02/04/16 02:16 PM
02/04/16 02:16 PM
dogdays Offline
dogdays  Offline
It didn't happen for me. I ran 2 1/2" pipes with Turbo mufflers and turndowns in front of the rear axle back in my 350 chevelle days, I used an H-pipe. In the couple of years I drove the car like that I didn't notice any fumes and the sound was just right, no drone. That car made several long trips, like 500 miles, so we would have noticed.
It was the way we did things back then.
R.
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005476
02/04/16 03:15 PM
02/04/16 03:15 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I just took my turn downs off and put some 3 inch tailpipes on. Yes fumes come in the car, and yes the volume inside the car goes up.
I'm glade i put the tailpipes on.
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005518
02/04/16 04:07 PM
02/04/16 04:07 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Not worth it,unless you just have to make that litle wheight go away.
Re: Exhaust turndowns??? [Re: 1Fast340] #2005661
02/04/16 08:49 PM
02/04/16 08:49 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
All of mine have had turn downs and it is probably a little louder and have never had any fumes in car.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005677
02/04/16 09:07 PM
02/04/16 09:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Years ago at LACR(Desert),I had turndowns and pissed a LOT of people off in the pits blowing dust in their faces........don`t recommend it myself.
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005683
02/04/16 09:16 PM
02/04/16 09:16 PM
How about removing the tail pipes and adding extensions from the muffs to make side pipes exit in front of the rear tires like the T/A Cahllengers and AAR Cudas have work thumbs twocents
I had a set up like that on my BB Dart, short 2.5 O.D. pipe from the fenderwell headers to the early Corviar Turbo muffs and then around 20 inches of 2.5 tail pipes out of the muffs and bent out at 45 degrees to the rocker panels in front of the rear tires, that work well thumbsThey where easy to remove at the track and they didn't weigh a bunch either shruggy
Re: Exhaust turndowns??? [Re: Thumperdart] #2005685
02/04/16 09:19 PM
02/04/16 09:19 PM
Oklahoma
66 Belvedere Offline
Oklahoma
Hahaha you had to get there early to get a good spot!
Ray
Re: Exhaust turndowns??? [Re: 66 Belvedere] #2005697
02/04/16 09:34 PM
02/04/16 09:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ray
Usually drove there and back and was in line before most.........
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005721
02/04/16 10:25 PM
02/04/16 10:25 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Curious why you what to remove the tail pipes?
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005767
02/04/16 11:20 PM
02/04/16 11:20 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yep, I hate people with turn down's, nice clean car and then one of these dickheads pulls up next to you frown
1963 Plymouth Max Wedge
1971 Barracuda
Re: Exhaust turndowns??? [Re: racerx] #2005820
02/05/16 12:24 AM
02/05/16 12:24 AM
Stockholm, Sweden
Stockholm, Sweden
No real reason, it was just an idea I got stuck in my head.
As I wrote in my earlier post. I could live with a louder exhaust sound, but the exhaust fumes inside the cab I can be without, so I´m not gonna do this mod.. I did not even think about/consider the fact that turn downs blow dust all over everything and everybody you drive by...
/Tom
Re: Exhaust turndowns??? [Re: TomsCharger70] #2005823
02/05/16 12:28 AM
02/05/16 12:28 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like my car alot better with the full exh on it out the the rear bumper. No drone at idle and I think the car sounds better as you can hear more of the cam to me. Ron
Page 1 of 3 1 2 3
