2016 Stickshift Challenge @ The Nationals #2005071
02/03/16 09:34 PM
02/03/16 09:34 PM
MI
68shifter Offline OP
MI
The 2016 Stickshift Challenge will again be Aug 12-14 this year at the Mopar Nationals, as always. A big Thank You to Brewers Performance for stepping up again this year.
Similar to years past Aug 12(Fri) will be time trials, and the Challenge ran on Saturday.
Two time trials saturday morning and then into eliminations. Thank you to all those that came in years past and I look forward to seeing everyone again this year.
Payout:
Winner $1000
R/U $500
Semis $100
The winner will also receive a Brewers Performance $500 gift certificate.
The R/U will also receive a Brewers Performance $250 gift certificate.
All participants will get a free t-shirt, still working on this years design and color.
If a factory style 4/5/6 speed is in the final, thats a $100. (Each of the last two years has had a factory trans in the final).
A case of oil will also be given to best R/T in 1st round of elims.
I am also working on a number of other prizes/gift cards etc to other vendors that may be by drawing, best wheelstand or something-we'll figure em out.
So bring out your stickshift ride and have some fun. This is a laid back event, they'll be free t-shirts again for participants, a custom trophy and plenty of lies told
And two time defending champ:
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2005094
02/03/16 09:58 PM
02/03/16 09:58 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What kind of classes are there? I'm in the middle of setting up my car for brackets, hopefully running into the mid 8's. 2x3 chassis, cage, ladder bars, big tire, big block, N/A, hemi box.
[image][/image]
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2005339
02/04/16 08:33 AM
02/04/16 08:33 AM
MI
MI
Just has to have a stick and no electronics. Of course must pass tech for the ET it will run. National trail is one of the more thorough places.
You can run the stick race, then Pro, Nss, sportsman or whatever you like. Just have to pay the respective entry fee.
Hope to see you there.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2005346
02/04/16 09:53 AM
02/04/16 09:53 AM
sgcuda Offline
sgcuda  Offline
Something to aim at. Thanks.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2099332
06/27/16 03:26 PM
06/27/16 03:26 PM
MI
MI
Bump...
Mail in entries have to be postmarked by end of June.
Engines out of mine fixing an issue, haven't made a pass yet this year and hope I can get it back in before the Nats, otherwise talk about Suck.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2101614
07/01/16 03:09 AM
07/01/16 03:09 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Was just searching for this thread but saw it needed to be postmarked by he 30th. O well I'll pay the extra $15. Hopefully j figure out what the knock is coming from in my new build. Ran two years ago with old motor and had fun but car was apart last year. If I can't figure out the knock I may just drive up in my 2010 rt shaker 6 speed and be one of "those guys".
Hopefully I'll be in the bee, say hi if you see a tiger tail hanging out the trunk smile
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68KillerBee] #2115337
07/22/16 06:46 AM
07/22/16 06:46 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Any others joining in on the fun? My super bee is running now, but I need to figure out why it is cutting in and out when I'm driving. It stops after about 10 minutes/warms up. Plan is to trailer the bee and I might drive the challenger to sell and possibly race if I can't get the bee driving right and more miles on it. Only has 175ish miles on a new motor/trans/driveshaft/rearend. I just went around it and checked for loose bolts. Ugh, now I remember I need to put my new tires on it. And rewire my line lock for Heath smile . If only I had a junk set of wheels to put my almost worn out tires on, so I can fully wear them out at the cruise or burnout contest- then I can also test the rev limiter on the Rev-N-Nator.
drive drive
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68KillerBee] #2124355
08/03/16 10:07 PM
08/03/16 10:07 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Any reason I can't run my Dodge Ram CUMMINS 6 speed stick???
It's really slow, but so am I. ...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2124630
08/04/16 05:57 AM
08/04/16 05:57 AM
MI
MI
Yep as long as it passes the normal tech stuff you're good.
Initial weather looks HOT-go figure.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 6bblFLASH] #2125130
08/04/16 07:27 PM
08/04/16 07:27 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Hmmm, wind 3mph from west, diesel lines up in left lane, launches, makes lots of black smoke, car in rt lane waits for smoke to clear before seeing that the light is green and has been for 10 seconds, car launches cant see track, drives off into the wall
yep, sounds good drive
working on my car and trying to get it to launch. think I found a clutch problem. thought I was spinning the tires at Norwalk, was just spinning the flywheel. If all good, will see you there
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: 2016 Stickshift Challenge @ The Nationals [Re: oldiron] #2125241
08/04/16 10:09 PM
08/04/16 10:09 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
LOL.
Good luck getting the car back together.
Hope to see you there! !
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2126344
08/06/16 03:53 AM
08/06/16 03:53 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
If you guys want, pm me your phone numbers and I'll set up a group text to help us know when it's our turn Friday and Saturday. I think it would be beneficial to all. I'm usually over in the swap section and don't want to miss our turn on the track.
Devin
And thanks to Brewers for sponsoring. They also will be buying some NOS transmission gears I have off of me.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2126345
08/06/16 03:53 AM
08/06/16 03:53 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Does anybody know what the count is in our class? What has it been in previous years.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2126377
08/06/16 09:16 AM
08/06/16 09:16 AM
MI
MI
Usually high teens/low twenties. They usually don't give me pre registered numbers because a lot of people still buy at the gate.
The class has grown by a couple cars every year and hopefully that can continue.
Andre
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2128069
08/08/16 06:49 PM
08/08/16 06:49 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
What's the entry fee?
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2128098
08/08/16 07:19 PM
08/08/16 07:19 PM
MI
MI
I believe it was $100, they took their price stuff down from the website, or at least I couldn't find it. Drag race participants can now camp at the track as well. Thanks
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2128402
08/09/16 01:06 AM
08/09/16 01:06 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I was late to register and I think it was $115 because it was after June 31st or something like that, so it is now probably at least $115 at the gate.
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2130029
08/11/16 12:32 AM
08/11/16 12:32 AM
MI
MI
This years trophy.
Safe travels everyone.
Andre
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2130408
08/11/16 04:41 PM
08/11/16 04:41 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Originally Posted By 68shifter
This years trophy.
Andre
NICE! Wish I could compete for it. Everyone have fun... Thanks for all you do for this class, Andre. Wish it was at another venue....
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 2016 Stickshift Challenge @ The Nationals [Re: 68shifter] #2131767
08/13/16 04:13 AM
08/13/16 04:13 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
The trophy is killer!! Where is hour fearless leader pitted it?
Ekē
