Quarter mile times and setup. #2004727
02/03/16 12:01 PM
02/03/16 12:01 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
I think it would be interesting to start a post on your GenIII builds in older muscle cars. And your ETs. Post away smile
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2004904
02/03/16 04:27 PM
02/03/16 04:27 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
09 Jeep GC... 5.7 13.76@99mph.... Mods are K&N intake, Diablosport 93 tune, full SRT8 factory headers and exhaust with cat delete..... 2WD with factory 3.73 rear gear sure grip weighs 4400LBS.... I would not build a gen3 with any heads heads earlier than the Eagles. Anybody still building an LA based engine is spending more money and leaving power on the table compared to the new small block Hemi.....
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Quarter mile times and setup. [Re: tpabayflyer] #2004989
02/03/16 07:14 PM
02/03/16 07:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
67 barracuda 3150lbs
6.1 block 4.08 x 4.09 bore
11-1. 600 lift 250@50
Ported eagles
Short 4150 intake with some porting.
2" dom adapter and thumpercarb
2" tti headers
Best 1.41, 6.25, 9.88 @ 134
9" conveter and 3.55 gears
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2005005
02/03/16 07:51 PM
02/03/16 07:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
72 Dart 3700lbs
6.1 4.05x4.065 bore
11.1 600 lift 247/255/114
ported 6.1 heads 2.10 intake valves
ported 6.1 intake
EFI
1 3/4 TTI headers
Viper 6 spd Mcleod RXT clutch, 3.91 gears
street tires, road race setup no changes
12.09@122mph 2.0 60ft tire spin into 3rd gear, 2800 ft elev.
Mopar to the bone!!!
Re: Quarter mile times and setup. [Re: tpabayflyer] #2005131
02/03/16 11:09 PM
02/03/16 11:09 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Tpabayflyer: Were you able to get away from a check engine light when you deleted your cats?
Mo' Farts
Moderated by "tbagger".
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2005300
02/04/16 02:40 AM
02/04/16 02:40 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I am still using the factory SRT8 cats so no problem there..... I did delete the resonators out back for a more angry rumble! TBF
Re: Quarter mile times and setup. [Re: tpabayflyer] #2006822
02/06/16 04:41 PM
02/06/16 04:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2007498
02/07/16 06:44 PM
02/07/16 06:44 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Here's a thread from for a bodies forum with some
http://www.forabodiesonly.com/mopar/showthread.php?t=325478
Re: Quarter mile times and setup. [Re: pittsburghracer] #2007525
02/07/16 07:28 PM
02/07/16 07:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Steff and 340 Rick both have stout combos.
Re: Quarter mile times and setup. [Re: 72Swinger] #2007615
02/07/16 10:44 PM
02/07/16 10:44 PM
PA.
"Little"John
"Little"John
PA.
I'll keep checking in. I didn't really see anything on A bodies only that was NA and running well enough to twist my arm yet.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2007616
02/07/16 10:45 PM
02/07/16 10:45 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
66 Coronet sedan full interior 3750# wih me in it
6.1 4.080x4.080
Indy Modman with 2 500 eddys
11-1 comp
580 lift 250@.050
1 3/4 TTI headers with full 3" exhaust to the bumper
4.10 gears 275 drag radial
11.25 @ 124 mph
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2007697
02/08/16 12:51 AM
02/08/16 12:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
^^^ That is pretty dang impressive right there! I will probably never make a "good" pass in mine but I couldnt be happier with its performance on pump gas and 0 maintenance and ability to drive it anywhere.
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2007878
02/08/16 12:34 PM
02/08/16 12:34 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
68 barracuda 3675lbs with driver, full interior, roll bar
5.7L .020 over with a 6.1L steel crank. 3.937" x 3.58"
OCP dual plane with an 850 Holley DP.
11-1 compression
CNC ported early 5.7L heads with large valves 2.02" x 1.57"
Custom comp cam .540 lift 247 253 @ .050 107lsa
4.88 gear
27"x 11.5 QTP Hoosier tires
11.26@120.1mph
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: Quarter mile times and setup. [Re: 72Swinger] #2008471
02/09/16 12:13 PM
02/09/16 12:13 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Could not agree more! More with less. Matt
Re: Quarter mile times and setup. [Re: pittsburghracer] #2008486
02/09/16 12:40 PM
02/09/16 12:40 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
[quote=pittsburghracer]Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast [/quote
Me and my brother are looking to build one for late next year/early 2018. We picked up a 5.7 complete for cheap so we've been selling off parts we don't need. Trying to get rid of some early 5.7L heads right now. We will do a half fill on the block for added rigidity. I've located some 6.1 heads that I'll have CNC'd at some point as well as getting some other parts purchased. We're just going to take our time with it so its done right. We want to do something different so we're going to wind ours up quite a bit to make peak power up in the rpms.
If anyone wants some early 5.7 heads:
http://www.ebay.com/itm/182013277708?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Adriel Paradise
Substation Design Engineer III
Re: Quarter mile times and setup. [Re: Adrielp] #2008565
02/09/16 02:35 PM
02/09/16 02:35 PM
PA.
"Little"John
"Little"John
PA.
Seems like almost everyone I read about is in a "heavy weight" car. I do the math and still come up with numbers short of the good old fashion LA small blocks. If I'm going to spend double the money I want to see ET on the table. My LA stuff is available dirt cheap so I keep stocking up.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2008601
02/09/16 03:51 PM
02/09/16 03:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am not sure the value is 100% there for people wanting to switch from LA to gen III just yet. But if your starting with nothing there is no question that gen III is the way to go.
68 Barracuda Formula S 340
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2008656
02/09/16 04:57 PM
02/09/16 04:57 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Agreed, and a nice roller rocker arm setup under $1200 would be great too for those wanting to run higher lifts and taller springs!
Adriel Paradise
Re: Quarter mile times and setup. [Re: 70VcodeCoronetRT] #2008659
02/09/16 05:05 PM
02/09/16 05:05 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
There's a guy on the LXForums that's run a 9.4 @ 144 mph in a 3200 lb Magnum. It's a pretty decent build, 468" and Thitek heads. I'm sure a similar time could be run at less cubes and Apache heads, just have to twist it harder.
Re: Quarter mile times and setup. [Re: WO23Coronet] #2009552
02/10/16 11:06 PM
02/10/16 11:06 PM
houston texas
gremlinsteve Offline
houston texas
You should wait till we get the small cam out of that monster and the new one in
A lil more head and get that stock intake worked on some and we're hoping for a much better number
if You Like Gremlinsteve. Gremlinsteve Likes You.
