Re: Quarter mile times and setup.
[Re: 70VcodeCoronetRT]
#2004904
02/03/16 04:27 PM
02/03/16 04:27 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
09 Jeep GC... 5.7 13.76@99mph.... Mods are K&N intake, Diablosport 93 tune, full SRT8 factory headers and exhaust with cat delete..... 2WD with factory 3.73 rear gear sure grip weighs 4400LBS.... I would not build a gen3 with any heads heads earlier than the Eagles. Anybody still building an LA based engine is spending more money and leaving power on the table compared to the new small block Hemi.....
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: tpabayflyer]
#2004989
02/03/16 07:14 PM
02/03/16 07:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
67 barracuda 3150lbs
6.1 block 4.08 x 4.09 bore 11-1. 600 lift 250@50 Ported eagles Short 4150 intake with some porting. 2" dom adapter and thumpercarb 2" tti headers
Best 1.41, 6.25, 9.88 @ 134
9" conveter and 3.55 gears
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#2005005
02/03/16 07:51 PM
02/03/16 07:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
72 Dart 3700lbs 6.1 4.05x4.065 bore 11.1 600 lift 247/255/114 ported 6.1 heads 2.10 intake valves ported 6.1 intake EFI 1 3/4 TTI headers Viper 6 spd Mcleod RXT clutch, 3.91 gears street tires, road race setup no changes 12.09@122mph 2.0 60ft tire spin into 3rd gear, 2800 ft elev.
Mopar to the bone!!!
[Re: tpabayflyer]
#2005131
02/03/16 11:09 PM
02/03/16 11:09 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
Tpabayflyer: Were you able to get away from a check engine light when you deleted your cats?
Mo' Farts
Moderated by "tbagger".
#2005300
02/04/16 02:40 AM
02/04/16 02:40 AM
tpabayflyer
Tampa, FL
I am still using the factory SRT8 cats so no problem there..... I did delete the resonators out back for a more angry rumble! TBF
[Re: tpabayflyer]
#2006822
02/06/16 04:41 PM
02/06/16 04:41 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast
[Re: pittsburghracer]
#2007525
02/07/16 07:28 PM
02/07/16 07:28 PM
72Swinger
Nebraska
Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast Steff and 340 Rick both have stout combos.
[Re: 72Swinger]
#2007615
02/07/16 10:44 PM
02/07/16 10:44 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast Steff and 340 Rick both have stout combos. I'll keep checking in. I didn't really see anything on A bodies only that was NA and running well enough to twist my arm yet.
#2007697
02/08/16 12:51 AM
02/08/16 12:51 AM
72Swinger
Nebraska
^^^ That is pretty dang impressive right there! I will probably never make a "good" pass in mine but I couldnt be happier with its performance on pump gas and 0 maintenance and ability to drive it anywhere.
#2007878
02/08/16 12:34 PM
02/08/16 12:34 PM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
68 barracuda 3675lbs with driver, full interior, roll bar 5.7L .020 over with a 6.1L steel crank. 3.937" x 3.58" OCP dual plane with an 850 Holley DP. 11-1 compression CNC ported early 5.7L heads with large valves 2.02" x 1.57" Custom comp cam .540 lift 247 253 @ .050 107lsa 4.88 gear 27"x 11.5 QTP Hoosier tires 11.26@120.1mph
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
[Re: 72Swinger]
#2008471
02/09/16 12:13 PM
02/09/16 12:13 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
^^^ That is pretty dang impressive right there! I will probably never make a "good" pass in mine but I couldnt be happier with its performance on pump gas and 0 maintenance and ability to drive it anywhere. Could not agree more! More with less. Matt
#2008486
02/09/16 12:40 PM
02/09/16 12:40 PM
Posts: 577 Arkansas
Adrielp
Arkansas
[quote=pittsburghracer]Man I keep coming back to this one to see some nice combos and fast times but it kinda fizzeled out real fast [/quote Me and my brother are looking to build one for late next year/early 2018. We picked up a 5.7 complete for cheap so we've been selling off parts we don't need. Trying to get rid of some early 5.7L heads right now. We will do a half fill on the block for added rigidity. I've located some 6.1 heads that I'll have CNC'd at some point as well as getting some other parts purchased. We're just going to take our time with it so its done right. We want to do something different so we're going to wind ours up quite a bit to make peak power up in the rpms.
If anyone wants some early 5.7 heads: http://www.ebay.com/itm/182013277708?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#2008565
02/09/16 02:35 PM
02/09/16 02:35 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Seems like almost everyone I read about is in a "heavy weight" car. I do the math and still come up with numbers short of the good old fashion LA small blocks. If I'm going to spend double the money I want to see ET on the table. My LA stuff is available dirt cheap so I keep stocking up.
#2008601
02/09/16 03:51 PM
02/09/16 03:51 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I am not sure the value is 100% there for people wanting to switch from LA to gen III just yet. But if your starting with nothing there is no question that gen III is the way to go.
68 Barracuda Formula S 340
#2008656
02/09/16 04:57 PM
02/09/16 04:57 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Agreed, and a nice roller rocker arm setup under $1200 would be great too for those wanting to run higher lifts and taller springs!
[Re: WO23Coronet]
#2009552
02/10/16 11:06 PM
02/10/16 11:06 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
There's a guy on the LXForums that's run a 9.4 @ 144 mph in a 3200 lb Magnum. It's a pretty decent build, 468" and Thitek heads. I'm sure a similar time could be run at less cubes and Apache heads, just have to twist it harder. You should wait till we get the small cam out of that monster and the new one in A lil more head and get that stock intake worked on some and we're hoping for a much better number
if You Like Gremlinsteve. Gremlinsteve Likes You.
