flowbench follies
#200393
01/21/09 08:32 PM
01/21/09 08:32 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Ran across a flowbench forum while surfing today. Had an interesting thread. Test plates run on Ford's in-house flow bench vs. some Superflows vs. some home made ones. http://www.tractorsport.com/cgi-bin/foru...ct=ST;f=1;t=230Let the (flow)bench racing begin! -bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: flowbench follies
[Re: S/ST 3040]
#200395
01/21/09 09:22 PM
01/21/09 09:22 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
that is a really interesting forum. Cool
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: S/ST 3040]
#200396
01/22/09 08:43 PM
01/22/09 08:43 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I don't think anybody cares. If your bench reads lower than most others, it just means the bench isn't accurate or the heads are garbage......depending on who did the heads.
Well, I thought it was interesting that a number of home made benches flowed within a similar point spread of a number of name brand flow benches. With the tests being done on different days, in different parts of the country, with changes in altitude, baro pressure, etc.
-bill
[Re: vcummins]
#200400
01/23/09 12:01 AM
01/23/09 12:01 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
A flow bench is A static testing instrument. they DO NOT make horse power
No, but someone who knows HOW to use them and WHAT to look for can make HP by applying what is learned from testing.
[Re: S/ST 3040]
#200401
01/23/09 12:13 AM
01/23/09 12:13 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
ive owned a flow bench(2 different ones) since 1992.
after i had that first one about 2 years i decided that while it could be interesting to read about flow results gleaned from other shops using other benches.......the only numbers i really put any stock into were the ones i got from my own bench.
when i bought the second bench about a year and a half ago, i kept the first one on hand while i got used to the new one, and to be able to compare some heads in the event that the new bench showed numbers that didnt seem right.
once i got used to what to expect from the new bench, the old one got sold.......and now i'm at the point where i'm only concerned with the results that come off the new bench.
i still like reading the results that other people get, but i dont really consider their numbers and mine something that can be compared as truely "apples to apples".
on the other hand......even with as much variation as ive seen between flow benches.......it doesnt hold a candle to how much variation ive seen between different dynos......but thats really a whole 'nuther topic.
[Re: S/ST 3040]
#200403
01/23/09 01:00 PM
01/23/09 01:00 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always flow a head befor and after porting a head and if it is a head I never played with befor I probably have it on the bench 6-10 times. Its only another tool but if you have the time its time well spent. Instead of posting posting flow numbers I would rather see how many cfm you picked up on any given head on your bench. example(head flowed 267cfm@28 befor and 298cfm@28 after.
[Re: pittsburghracer]
#200404
01/23/09 09:53 PM
01/23/09 09:53 PM
pittsburghracer hit the nail on the head.a flowbench is nothing more than a tool.i've worked at a major speed shop for 20yrs,and can tell you that it's easy to get caught up in flow numbers.you can make a head flow what ever you want buy just changing the inches of h2o or cfm. even the type of stand you use can effect your outcome. benches are going to read different. the most important thing is to flow it before and after any work using the same settings and fixtures.i've worked on heads that flow great but wouldn't go down the track.the bench just lets you know if your going in the right direction.
[Re: fast68plymouth]
#200405
01/24/09 03:39 PM
01/24/09 03:39 PM
BradH
I know your old bench and mine were very close when we tested the same heads on both benches. However, your new "high powered" bench probably changes that now.
Ya' mean like two different "600 HP" engines tested on two different dynos and one ran 11.0 @ 121 and the other 10.5 @ 126 in the same car?
