Brake Backing Plate Coating
#2001293
01/29/16 04:44 PM
01/29/16 04:44 PM
Posts: 25,811 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just got done bead blasting a couple of backing plates and powder coating the exposed side of them.
Not sure what to do with the inside surface to keep it from rusting, powder coating a wear surface doesn't seem practical. What do you guys do?
Re: Brake Backing Plate Coating
[Re: John_Kunkel]
#2001309
01/29/16 05:13 PM
01/29/16 05:13 PM
RapidRobert
I just bought a pair of used ones that had been powder coated by a prior owner (both sides). I dont see a problem with that & the only wear areas that could make dust (I would assume) would be the (6) pad contact areas and the anchor pin at the top & I think that'd be minimal. You have access to PC & I'd go ahead & do the inside also
[Re: John_Kunkel]
#2001333
01/29/16 05:54 PM
01/29/16 05:54 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Maybe get em ceramic coated? The only problem would be the heat they hold in if you are getting em hot.
