Brake Backing Plate Coating #2001293
01/29/16 04:44 PM
01/29/16 04:44 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
Just got done bead blasting a couple of backing plates and powder coating the exposed side of them.
Not sure what to do with the inside surface to keep it from rusting, powder coating a wear surface doesn't seem practical. What do you guys do?
Re: Brake Backing Plate Coating [Re: John_Kunkel] #2001309
01/29/16 05:13 PM
01/29/16 05:13 PM
I just bought a pair of used ones that had been powder coated by a prior owner (both sides). I dont see a problem with that & the only wear areas that could make dust (I would assume) would be the (6) pad contact areas and the anchor pin at the top & I think that'd be minimal. You have access to PC & I'd go ahead & do the inside also
Re: Brake Backing Plate Coating [Re: John_Kunkel] #2001333
01/29/16 05:54 PM
01/29/16 05:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Maybe get em ceramic coated? The only problem would be the heat they hold in if you are getting em hot.
Re: Brake Backing Plate Coating [Re: John_Kunkel] #2001415
01/29/16 08:02 PM
01/29/16 08:02 PM
BDW Offline
BDW  Offline
I powder coated my rear backing plates over 10 years ago.
Just changed the pads recently and no wear what so ever on the contact points.
Re: Brake Backing Plate Coating [Re: BDW] #2001418
01/29/16 08:09 PM
01/29/16 08:09 PM
Rio Linda, CA
Rio Linda, CA
OK, you convinced me...they're cooking right now. thumbs
