69 hemi orange paint where to get? #2001357
01/29/16 06:26 PM
01/29/16 06:26 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Looking to see who has the best 69 hemi orange engine paint. Do they make any that will hold up on exhaust manifolds like the factory did them in the over spray?
Contact Me about AMD Prices
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2001400
01/29/16 07:23 PM
01/29/16 07:23 PM
Nanuet, NY
johntpr Offline
johntpr  Offline
Nanuet, NY
Frank Badalson's paint is the most accurate.
69 Daytona 4 speed
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2001407
01/29/16 07:45 PM
01/29/16 07:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I second Badelsons paint......There is no paint that won't burn off, it's SUPPOSED to burn off, some will typically remain around the flanges and heat riser, painting the entire manifold is a way to get the correct pattern coverage after most has burned off.
Re: 69 hemi orange paint where to get? [Re: ScottSmith_Harms] #2001559
01/29/16 11:30 PM
01/29/16 11:30 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Agree iagree
Re: 69 hemi orange paint where to get? [Re: ScottSmith_Harms] #2001707
01/30/16 02:28 AM
01/30/16 02:28 AM
South Dakota
South Dakota
Thanks scott! Can't wait to see the hemi carbs you did too!
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2001990
01/30/16 04:06 PM
01/30/16 04:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Either go with Frank's paint as mentioned, or if you have access to Dupont Centari Acrylic Enamel, have a batch of EV2 Hemi Orange mixed, just tell the mixer to NOT add the metallic paste, do use the Enamel gloss hardner, your spray technique will determine how much gloss you want the engine to have, generally I spray them so they are glossed to the max with very minimal orange peel, the heat from engine operation will slowly age the paint hue/sheen so that it has that slight sheen to it, yet a smooth surface for easy cleaning down the road, I find trying to spray the engine "dry" to emulate the factory sheen, results in a "dry" paint surface that traps grease/oil/etc making it harder to clean, prevent stains...
FYI, I've never had any issues using Dupont Centari for engine painting, it will burn off the main body of the exhaust manifolds, but the rest of the engine should have no issues if PREPPED PROPERLY....Frank's paint, depending on your application/coverage on the exhaust manifolds may leave the manifolds with a "yellowish flat patina" that won't burn off
mike
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2002803
01/31/16 06:06 PM
01/31/16 06:06 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Please be careful and cognizant of when your 69 hemi car was built. Early hemi cars have the lighter shade of hemi orange (similar to the race hemi color) while the later cars have the deeper hemi orange color. Talk to Frank B. before you buy your paint.
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2002825
01/31/16 06:55 PM
01/31/16 06:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Agreed, it is possible that some early 69 Hemi's got the same lighter "Race Hemi Orange" - Which all Max Wedges 62-64 and typically all Street & Race Hemi's 64-68 got. Early 69 would have been a rare exception before the switch to The reddish Street Hemi Orange typical of 69-71 Street Hemis.
First pic, Street Hemi Orange on a 1970 Engine, Second pic, Race Hemi Orange on a 68 Street Hemi.
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2002933
01/31/16 09:46 PM
01/31/16 09:46 PM
maxfield303H1E
maxfield303H1E
Those are some nice looking engines ! Did you restore them Scott? Where did you find that NOS filter?
I always thought the motor mounts were put on after the engine was painted.
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2002955
01/31/16 10:13 PM
01/31/16 10:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks, I restored the first one and helped on the second one, the 68 has a few incorrect detil parts but it's pretty close overall. The mounts were painted with the engine on all Street Hemis. The filter is a modern filter with "custom" decorating wink
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2003546
02/01/16 05:10 PM
02/01/16 05:10 PM
Canada
Maxwellwedge Offline
Canada
Yes - The early 69 (and earlier) is not quite as bright as Race Hemi orange but is close. My survivor '68 late October built 69 GTX had the lighter shade.
Frank sells both shades. And - I never use primer on an engine.
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2003565
02/01/16 05:36 PM
02/01/16 05:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Be careful when comparing photos, lighting conditions can vary the colors a lot. It is my belief that there were only two colors. Race Hemi Orange and Street Hemi Orange, and that any small variables you observe in shading would be attributed to batch variables. .02
Re: 69 hemi orange paint where to get? [Re: hotairballoonpilot] #2003826
02/01/16 11:27 PM
02/01/16 11:27 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I bought a quart from PPG per the paint code, it was almost $269 and its a nice single stage paint, just use a self etching primer. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
