Connecting Electrical Choke to Engine Bay harness #2001097
01/29/16 12:24 PM
01/29/16 12:24 PM
BigAg Offline OP
BigAg  Offline OP
I am finally getting around to hooking up the wiring on my electrical choke on my Edelbrock 1407. There seem to be two schools of thought on how to hook it up. One hook it to the coil. Two hook it to the Ballast. I was curious to get the boards thoughts on where the best place to wire this into? Is there a more logical place that I am missing?
Re: Connecting Electrical Choke to Engine Bay harness [Re: BigAg] #2001103
01/29/16 12:33 PM
01/29/16 12:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Whomever told you to hook it to the coil is wrong.
The choke wants 12V, the coil doesn't get 12V. Hook it to the ballast feed side.
Read Edelbrock's instructions on proper voltage for the choke and you'll see.
Don't be the exception.
Re: Connecting Electrical Choke to Engine Bay harness [Re: Supercuda] #2001122
01/29/16 01:24 PM
01/29/16 01:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer
Re: Connecting Electrical Choke to Engine Bay harness [Re: TJP] #2001160
01/29/16 02:10 PM
01/29/16 02:10 PM
None
71rm23 Offline
71rm23  Offline
None
iagree beer
I'm assuming it's the same on any electric choke? I'm almost sure. I ask because I'll be doing the same soon with mine as the OP
Re: Connecting Electrical Choke to Engine Bay harness [Re: 71rm23] #2001176
01/29/16 02:37 PM
01/29/16 02:37 PM
What Supercuda said & easiest/neatest is to drop a short line down from the choke several inches & T into the blue alt field wire in the loom that is running alongside the inside edge of the pass valve cover
Re: Connecting Electrical Choke to Engine Bay harness [Re: BigAg] #2001249
01/29/16 04:02 PM
01/29/16 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The double blue wire on the ballast resistor is the most convenient source for the electric choke. Just use one of these to piggyback the spade terminals.
Re: Connecting Electrical Choke to Engine Bay harness [Re: John_Kunkel] #2001261
01/29/16 04:14 PM
01/29/16 04:14 PM
BigAg Offline OP
BigAg  Offline OP
That sounds like a pretty simple solution. Any idea where to pick one of those up?
Re: Connecting Electrical Choke to Engine Bay harness [Re: BigAg] #2001271
01/29/16 04:23 PM
01/29/16 04:23 PM
NAPA has em, I'd call your favorite parts house & give em a descrip (brass electrical tap, double male/single female 1/4" terminals) might not be the exact definition but close enough
Re: Connecting Electrical Choke to Engine Bay harness [Re: John_Kunkel] #2001675
01/30/16 01:38 AM
01/30/16 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep I agree with all these guys and this is a nice Idea John posted. And as Supercuda said you dont ever want to hook the electric choke to the coil. Good luck to you.
Re: Connecting Electrical Choke to Engine Bay harness [Re: BigAg] #2001761
01/30/16 05:21 AM
01/30/16 05:21 AM
CA
crackedback Offline
crackedback  Offline
CA
None of the above...
Power it through a relay triggered off the 12v line at ballast.
Seen too many brown or dark blue wires burned up in the under dash harness.
Re: Connecting Electrical Choke to Engine Bay harness [Re: RapidRobert] #2002072
01/30/16 06:04 PM
01/30/16 06:04 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I did the field wire (switched 12 volt) trick on mine and so far no problem. E-brock does not want you to tap into the battery wire off the alternator because the voltage can be too high when charging.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Connecting Electrical Choke to Engine Bay harness [Re: Polarapete] #2002084
01/30/16 06:14 PM
01/30/16 06:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Plus the battery wire on the alternator is hot all the time.
Re: Connecting Electrical Choke to Engine Bay harness [Re: John_Kunkel] #2002088
01/30/16 06:25 PM
01/30/16 06:25 PM
The triple tap works but is very unsightly. A short line T'd down into the loom is aesthetically pleasing (& looks OE). Yes it'd be better to relay any and all add ons (& even the existing headlights/AC/heater) to the alt batt stud (my preference/keeps the ammeter honest) but barring that (addition) I'd just clean every terminal/connection expecially the bulkhead & do Nachos bulkhead parallel bypass & call it good.
Re: Connecting Electrical Choke to Engine Bay harness [Re: RapidRobert] #2002108
01/30/16 06:46 PM
01/30/16 06:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not so bad if you bend it 90°.
I don't see the running current draw of the choke coil (around 1.5 amps) as a big issue, not high enough to overload the wire.
Re: Connecting Electrical Choke to Engine Bay harness [Re: BigAg] #2002191
01/30/16 08:47 PM
01/30/16 08:47 PM
BigAg Offline OP
BigAg  Offline OP
They had to order the part from the warehouse at orielly but I got it all plugged up this afternoon. Still have a couple more things to hookup before I get to start the engine so I will have to wait a while to verify everything is working. Thanks for the help guys.
