Re: Connecting Electrical Choke to Engine Bay harness
[Re: BigAg]
#2001103
01/29/16 12:33 PM
01/29/16 12:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Whomever told you to hook it to the coil is wrong.
The choke wants 12V, the coil doesn't get 12V. Hook it to the ballast feed side.
Read Edelbrock's instructions on proper voltage for the choke and you'll see.
[Re: 71rm23]
#2001176
01/29/16 02:37 PM
01/29/16 02:37 PM
RapidRobert
What Supercuda said & easiest/neatest is to drop a short line down from the choke several inches & T into the blue alt field wire in the loom that is running alongside the inside edge of the pass valve cover
[Re: BigAg]
#2001249
01/29/16 04:02 PM
01/29/16 04:02 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The double blue wire on the ballast resistor is the most convenient source for the electric choke. Just use one of these to piggyback the spade terminals.
[Re: John_Kunkel]
#2001261
01/29/16 04:14 PM
01/29/16 04:14 PM
BigAg
That sounds like a pretty simple solution. Any idea where to pick one of those up?
[Re: BigAg]
#2001271
01/29/16 04:23 PM
01/29/16 04:23 PM
RapidRobert
NAPA has em, I'd call your favorite parts house & give em a descrip (brass electrical tap, double male/single female 1/4" terminals) might not be the exact definition but close enough
[Re: John_Kunkel]
#2001675
01/30/16 01:38 AM
01/30/16 01:38 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yep I agree with all these guys and this is a nice Idea John posted. And as Supercuda said you dont ever want to hook the electric choke to the coil. Good luck to you.
[Re: RapidRobert]
#2002072
01/30/16 06:04 PM
01/30/16 06:04 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
What Supercuda said & easiest/neatest is to drop a short line down from the choke several inches & T into the blue alt field wire in the loom that is running alongside the inside edge of the pass valve cover I did the field wire (switched 12 volt) trick on mine and so far no problem. E-brock does not want you to tap into the battery wire off the alternator because the voltage can be too high when charging.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#2002084
01/30/16 06:14 PM
01/30/16 06:14 PM
John_Kunkel
Rio Linda, CA
Plus the battery wire on the alternator is hot all the time.
[Re: John_Kunkel]
#2002088
01/30/16 06:25 PM
01/30/16 06:25 PM
RapidRobert
The triple tap works but is very unsightly. A short line T'd down into the loom is aesthetically pleasing (& looks OE). Yes it'd be better to relay any and all add ons (& even the existing headlights/AC/heater) to the alt batt stud (my preference/keeps the ammeter honest) but barring that (addition) I'd just clean every terminal/connection expecially the bulkhead & do Nachos bulkhead parallel bypass & call it good.
[Re: RapidRobert]
#2002108
01/30/16 06:46 PM
01/30/16 06:46 PM
John_Kunkel
Rio Linda, CA
The triple tap works but is very unsightly. Not so bad if you bend it 90°. I don't see the running current draw of the choke coil (around 1.5 amps) as a big issue, not high enough to overload the wire.
