09 Ram Tire Wear #2000567
01/28/16 05:49 PM
01/28/16 05:49 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
My son has an 09 Ram (4WD, Hemi,w/30" tires, after market rims). He's having trouble with tire wear on just the driver's side tire. He's gone through the alignment thing several times, had the suspension inspected, tires checked, wheels checked, etc.
Nothing found out of specs but the tire continues to wear. It wears only on one side (I can't remember if it's inside or outside). The other side of that same tire is fine and all the other tires are just fine. Any ideas?
I've heard that there is a suspension problem with some of the Rams but never have been able to pin the problem down.
Re: 09 Ram Tire Wear [Re: attaboy] #2000616
01/28/16 07:00 PM
01/28/16 07:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Dumb question but how much does he weigh?
Re: 09 Ram Tire Wear [Re: attaboy] #2000706
01/28/16 09:18 PM
01/28/16 09:18 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Weak tie rods are the problem you heard of but that's on the straight axle trucks.
His weight may be a cause. I had a customer that weighed 500 lbs (no joke) I had to align his truck by chaining down the left front to get the "normal" ride height.
That said, many alignment techs don't know what caster and camber do. If they can't just turn a tie rod "it can't be fixed"
Got a printout of the specs?
Angry white pureblood male
Re: 09 Ram Tire Wear [Re: ruderunner] #2000761
01/28/16 10:51 PM
01/28/16 10:51 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
He's only about 180. So I don't think weight is the problem. I've also heard of Ram trucks with 20" wheels wear the tires down VERY QUICKLY but I believe that's only on the newer ones from 2013/2014 on. His truck had 20" but he now has 30" or so. None of the other tires are wearing like that one.
Re: 09 Ram Tire Wear [Re: attaboy] #2000772
01/28/16 11:08 PM
01/28/16 11:08 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
You said aftermarket rims, but what about the tires? What brand are they? How many miles are on them?
Mo' Farts
Moderated by "tbagger".
Re: 09 Ram Tire Wear [Re: attaboy] #2000845
01/29/16 12:47 AM
01/29/16 12:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you looked at the steering gear box and see if it is tight and the frame not cracked around the bolts?
Re: 09 Ram Tire Wear [Re: attaboy] #2000954
01/29/16 02:48 AM
01/29/16 02:48 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What about the wheel hub being excessively worn?
Re: 09 Ram Tire Wear [Re: Kern Dog] #2001055
01/29/16 11:07 AM
01/29/16 11:07 AM
moparx Offline
moparx  Offline
what does the "worn" pattern look like ? edge down to nothing ? feathered ? cupped ? center bald ? both edges worn down ? pics would help a bunch.
beer
Re: 09 Ram Tire Wear [Re: attaboy] #2001677
01/30/16 01:39 AM
01/30/16 01:39 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Um, well anyway..............it's a pooched tire. Most likely a Goodyear or bridgestone/firestone. Take 'em all off and get some Michelins or Walmart tires on there.
Mo' Farts
Re: 09 Ram Tire Wear [Re: Grizzly] #2002017
01/30/16 04:40 PM
01/30/16 04:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well if its only wearing one front tire its a chamber related issue to that tire which you said is the left front. Of course you have to make sure no parts are worn and the bearings are good so nothing can throw the chamber off driving down the road. Some guys will set the front end with the driver in the car if they want to compinsate for the drivers weight. Myself if there are no bad parts in the front end and all looks good I want want to see which edge of the tire is wearing and I would change the chamber a tad to make the tire wear less and see what that does. Good luck , Ron
