dana 60 and 4 speed #1999790
01/27/16 03:18 PM
01/27/16 03:18 PM
central il.
second 70 Offline OP
central il.
I got under my cuda yesterday to check the numbers on my dana and found out it was a 71-b body 9-15-0A1, 9-15-70 B7, 603222-1, 3:54 I didn't find any serial #. It is longer than an e body. Now I know why my tires rubbed.
The transmission is OA139303 and #99129HA3 any info on these numbers? I'm guessing it's 18 spline out of a 70 b-body?
Thanks Mike
Re: dana 60 and 4 speed [Re: second 70] #1999824
01/27/16 03:51 PM
01/27/16 03:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You won't find a S/N on a rear end. The '71 B-body Dana is 63" overall width, the E-body is 61 5/8". Somebody moved the perches or the springs because the E and B spring pad centers are different.
Re: dana 60 and 4 speed [Re: John_Kunkel] #1999841
01/27/16 04:12 PM
01/27/16 04:12 PM
central il.
central il.
must have moved perches the springs are in stock location.
Re: dana 60 and 4 speed [Re: second 70] #1999893
01/27/16 06:21 PM
01/27/16 06:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks Mike
OA139303 is the last 6 digits of the 1970 B body that transmission came from.
0 = 1970
A= Lynch rd. assembly plant, they only built Satellite and Coronet B bodies there B bodies there.
139303 is the VIN sequence.
99129HA3 I'm pretty sure that is the casting number on the maincase , basically a useless number.
Re: dana 60 and 4 speed [Re: second 70] #1999901
01/27/16 06:33 PM
01/27/16 06:33 PM
AndyF Offline
AndyF  Offline
A long time ago a kid down the street wrapped his Charger around a tree. I bought the four speed and Dana 60 for a few hundred bucks and put them in my '65 Coronet. Sounds like the same thing happened here.
Re: dana 60 and 4 speed [Re: AndyF] #1999978
01/27/16 08:19 PM
01/27/16 08:19 PM
central il.
central il.
I thought about that but the transmission is a 1970 and rear end is a 71. How rare are these since they didn't make chargers or roadrunners at Lynch rd.?
Re: dana 60 and 4 speed [Re: second 70] #2000023
01/27/16 09:24 PM
01/27/16 09:24 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Fwiw, the RR Superbird was made at Lynch,Rd.,...but the lowest VIN I've seen listed is 149xxx.
Re: dana 60 and 4 speed [Re: second 70] #2000195
01/28/16 12:46 AM
01/28/16 12:46 AM
North EAST
seventy Offline
seventy  Offline
North EAST
Sorry to hear this, I will take this car off your hands, it sounds like a real night mare smile , lol, just kidding, I seen many cars with the dana's out of different models and years, changed to fit, and the trannys done the same way, did you buy it as a numbers matching car?
Re: dana 60 and 4 speed [Re: seventy] #2000240
01/28/16 01:47 AM
01/28/16 01:47 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yeah the Dana under my Savoy is a real different unit laugh2 It started life as a B-body unit that ended up in a 68 Camaro with 2 short side axles and re-drilled with a Chevy pattern work I've since installed some 35 spline axles from an 8 3/4.
Sometimes I wish I wouldn't have cut the ladder bar brackets off of it when I think about adding more tire to the car shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: dana 60 and 4 speed [Re: seventy] #2000410
01/28/16 01:39 PM
01/28/16 01:39 PM
central il.
central il.
No I knew all the drive train had been replaced. It started life as a 383 4 speed 8 3/4. That was all gone when I bought it. Now it's just an old 426 hemi with a dana. Lol
Re: dana 60 and 4 speed [Re: second 70] #2000501
01/28/16 03:45 PM
01/28/16 03:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Road runner is Satellite based and they were made at Lynch rd in 1970.
The rear came from a different car than the transmission.
Re: dana 60 and 4 speed [Re: second 70] #2000508
01/28/16 03:51 PM
01/28/16 03:51 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Ya - there was lots of rear axle swapping going on back in the day. My '72 Cuda started out as a 340, Automatic, open diff 8-3/4. As I broke things, I upgraded. A friend of a friend had a wicked fast GTX (when it ran) that went off-roading late one night when he was going too fast and couldn't make it through a sharp turn. That poor GTX hit a tree stump and bent the unibody pretty bad. The car sat in the towing yard lot for a year and I bought it for $750. $500 went right to the towing company to release the car and I handed the other $250 to the owner. I kept the Dana, 440 and the Torqueflight and parted the rest of the car out. I broke the 8-3/4" and swapped in the Dana. That was all back in 1983ish timeframe. Many years later, I back halved the car and narrowed that Dana.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: dana 60 and 4 speed [Re: fourgearsavoy] #2000757
01/28/16 10:45 PM
01/28/16 10:45 PM
BDW Offline
BDW  Offline
Gus beer
Interesting, my Dana (e-body) came out of my buddy's 68 Camero race car.
He gave me a deal for $300, but it had 5.13s and ladder bars too.
Re: dana 60 and 4 speed [Re: second 70] #2000762
01/28/16 10:55 PM
01/28/16 10:55 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
MY BUDDY IN CENTRAL ILL HAS A 70 CUDA DANA IN HIS 71 SATELLITE+
Re: dana 60 and 4 speed [Re: BDW] #2000922
01/29/16 02:10 AM
01/29/16 02:10 AM
Rittman Ohio
Rittman Ohio
Gus beer
I was pitting next to my buddy and I was running a 9" Ford with 4.56 gears under my Savoy and he was looking into swapping into a 9" for the Camaro so we just traded even up beer that's your win win except the Dana needed work and the 9" was fresh.
Gus
64 Plymouth Savoy
Dana 60
Re: dana 60 and 4 speed [Re: ragin sonny] #2001149
01/29/16 02:04 PM
01/29/16 02:04 PM
central il.
central il.
Now that's funny since I live in central Il. I could care less about #s matching on this car since all the drivetrain has been replaced. I just was getting ready to change it to a 4:10. Just didn't know how rare they are and thought I would put it out there ahead of time just in case some #s matching car needed it.
