Re: dana 60 and 4 speed
[Re: second 70]
#1999824
01/27/16 03:51 PM
01/27/16 03:51 PM
Posts: 25,914 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You won't find a S/N on a rear end. The '71 B-body Dana is 63" overall width, the E-body is 61 5/8". Somebody moved the perches or the springs because the E and B spring pad centers are different.
[Re: second 70]
#1999893
01/27/16 06:21 PM
01/27/16 06:21 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I got under my cuda yesterday to check the numbers on my dana and found out it was a 71-b body 9-15-0A1, 9-15-70 B7, 603222-1, 3:54 I didn't find any serial #. It is longer than an e body. Now I know why my tires rubbed.
The transmission is OA139303 and #99129HA3 any info on these numbers? I'm guessing it's 18 spline out of a 70 b-body?
Thanks Mike
OA139303 is the last 6 digits of the 1970 B body that transmission came from. 0 = 1970 A= Lynch rd. assembly plant, they only built Satellite and Coronet B bodies there B bodies there. 139303 is the VIN sequence. 99129HA3 I'm pretty sure that is the casting number on the maincase , basically a useless number.
[Re: seventy]
#2000240
01/28/16 01:47 AM
01/28/16 01:47 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yeah the Dana under my Savoy is a real different unit It started life as a B-body unit that ended up in a 68 Camaro with 2 short side axles and re-drilled with a Chevy pattern I've since installed some 35 spline axles from an 8 3/4. Sometimes I wish I wouldn't have cut the ladder bar brackets off of it when I think about adding more tire to the car Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: second 70]
#2000501
01/28/16 03:45 PM
01/28/16 03:45 PM
JohnRR
U.S.S.A.
I thought about that but the transmission is a 1970 and rear end is a 71. How rare are these since they didn't make chargers or roadrunners at Lynch rd.? Road runner is Satellite based and they were made at Lynch rd in 1970. The rear came from a different car than the transmission.
[Re: second 70]
#2000508
01/28/16 03:51 PM
01/28/16 03:51 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Ya - there was lots of rear axle swapping going on back in the day. My '72 Cuda started out as a 340, Automatic, open diff 8-3/4. As I broke things, I upgraded. A friend of a friend had a wicked fast GTX (when it ran) that went off-roading late one night when he was going too fast and couldn't make it through a sharp turn. That poor GTX hit a tree stump and bent the unibody pretty bad. The car sat in the towing yard lot for a year and I bought it for $750. $500 went right to the towing company to release the car and I handed the other $250 to the owner. I kept the Dana, 440 and the Torqueflight and parted the rest of the car out. I broke the 8-3/4" and swapped in the Dana. That was all back in 1983ish timeframe. Many years later, I back halved the car and narrowed that Dana.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: fourgearsavoy]
#2000757
01/28/16 10:45 PM
01/28/16 10:45 PM
Posts: 4,748 Florida
BDW
Yeah the Dana under my Savoy is a real different unit It started life as a B-body unit that ended up in a 68 Camaro with 2 short side axles and re-drilled with a Chevy pattern I've since installed some 35 spline axles from an 8 3/4. Sometimes I wish I wouldn't have cut the ladder bar brackets off of it when I think about adding more tire to the car Gus Interesting, my Dana (e-body) came out of my buddy's 68 Camero race car. He gave me a deal for $300, but it had 5.13s and ladder bars too.
[Re: BDW]
#2000922
01/29/16 02:10 AM
01/29/16 02:10 AM
fourgearsavoy
Rittman Ohio
Yeah the Dana under my Savoy is a real different unit It started life as a B-body unit that ended up in a 68 Camaro with 2 short side axles and re-drilled with a Chevy pattern I've since installed some 35 spline axles from an 8 3/4. Sometimes I wish I wouldn't have cut the ladder bar brackets off of it when I think about adding more tire to the car Gus Interesting, my Dana (e-body) came out of my buddy's 68 Camero race car. He gave me a deal for $300, but it had 5.13s and ladder bars too. I was pitting next to my buddy and I was running a 9" Ford with 4.56 gears under my Savoy and he was looking into swapping into a 9" for the Camaro so we just traded even up that's your win win except the Dana needed work and the 9" was fresh. Gus
[Re: ragin sonny]
#2001149
01/29/16 02:04 PM
01/29/16 02:04 PM
Posts: 1,710 central il.
second 70
central il.
MY BUDDY IN CENTRAL ILL HAS A 70 CUDA DANA IN HIS 71 SATELLITE+ Now that's funny since I live in central Il. I could care less about #s matching on this car since all the drivetrain has been replaced. I just was getting ready to change it to a 4:10. Just didn't know how rare they are and thought I would put it out there ahead of time just in case some #s matching car needed it.
