Urethane shackle bushings. #2000404
01/28/16 01:25 PM
01/28/16 01:25 PM
Canada
Dons Dart Offline OP
Canada
Just got my urethane shackle bushings for the 74 Duster.Having a [censored] of a time getting them in the upper mount,in the past rubber ones i did not have as much of a problim.Also when i tried to slide the shackle into the urethane had to beat to get it in,am i doing something wrong,or is it that much of a tight fit.I have used grease to help but that had very little help.Thoughts.
Re: Urethane shackle bushings. [Re: Dons Dart] #2000473
01/28/16 03:18 PM
01/28/16 03:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Poly shackle bushings can be tough to install, first if you didn't use a grease specified for poly bushings, the petroleum that your using may degrade the bushing, so it may fail later on?
put a slight bevel on the end of the bushing end that will be going/pushed into the frame tube, install the bushings on the shackle, put the whole assy in the freezer overnight, then upon assembly, lube the frame tube and the bushing entirely with a light film, assemble quickly while still frozen
the second alternative, is to freeze just the bushing, then install that in the frame tube first, let it thaw to room temp, then install the shackle, either method will work, I generally prefer to install the bushing in the frame first
Re: Urethane shackle bushings. [Re: Dons Dart] #2000476
01/28/16 03:21 PM
01/28/16 03:21 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
If you have a large enough vise or a shop press - you can get press them in. Lots of lube helps too, (That's what she said!)
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Urethane shackle bushings. [Re: Dons Dart] #2000517
01/28/16 04:08 PM
01/28/16 04:08 PM
Canada
Canada
Ok very helpfull guys.Next is the shackle going to move freely back and fourth? I tryed a test fit it did not want to swing with ease.
Re: Urethane shackle bushings. [Re: Dons Dart] #2000541
01/28/16 04:57 PM
01/28/16 04:57 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
The shackle will move fine- trying to move them with your hand or arm v.s. the mechanical advantage of the suspension is totally different. I have the poly bushings on my Dart - and there are no problems. Had them for 10 years or so.
55 Plymouth Project
Re: Urethane shackle bushings. [Re: 19swinger70] #2000563
01/28/16 05:32 PM
01/28/16 05:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
calm down Michael Scott laugh2
Re: Urethane shackle bushings. [Re: mikemee1331] #2000612
01/28/16 06:58 PM
01/28/16 06:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
LMAO...
(Urethrathane in the back of a '71 Ply B-body...
No issues in 20 years...)
Re: Urethane shackle bushings. [Re: Dons Dart] #2000628
01/28/16 07:10 PM
01/28/16 07:10 PM
Washington
madscientist Offline
Washington
I think at some point I'm just going to make some bushings from aluminum. Seems like a better idea to me.
Re: Urethane shackle bushings. [Re: Dons Dart] #2000634
01/28/16 07:15 PM
01/28/16 07:15 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Any scaly rust on the insides of the bushing tube or the shackle bolts? A bench vise can be used in lieu of a press to press the bushings in. Heck, I use a bench vise to press upper control arm bushings in.
Re: Urethane shackle bushings. [Re: Dons Dart] #2000664
01/28/16 08:01 PM
01/28/16 08:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Put a bolt/nut through the bushings and tighten nut to pull them into the frame.
Re: Urethane shackle bushings. [Re: Dons Dart] #2000715
01/28/16 09:36 PM
01/28/16 09:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
no problem with the ones in my 65 B body.been in for years.Didnt have any problems installing them either.Rocky
Chrysler Firepower
Re: Urethane shackle bushings. [Re: 19swinger70] #2000941
01/29/16 02:37 AM
01/29/16 02:37 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
boogie
Funny!
These bushings do squeak too! I greased mine years ago but it is sounding like I need to redo it.
Re: Urethane shackle bushings. [Re: Kern Dog] #2000956
01/29/16 02:49 AM
01/29/16 02:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
boogie
Funny!
Usually the only reason I find that poly bushings squeak, is that the wrong lubricant (most petroleum products are harmful to the longevity of poly bushings) was used installing them, or the components/bushing were tightened with the suspension at any angle other than at ride height, not tightening the bushings/components at ride height will either result in a bushing with a severe torsion twist to it, or a torn/fractured bushing, either way...squeaks (can happen with OEM rubber components as well)
Mike
Re: Urethane shackle bushings. [Re: DAYCLONA] #2000957
01/29/16 02:51 AM
01/29/16 02:51 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Great points, Dayclona. I may have done all of those things!
Re: Urethane shackle bushings. [Re: Kern Dog] #2001056
01/29/16 11:11 AM
01/29/16 11:11 AM
moparx Offline
moparx  Offline
any suspension's pivot points need to be tightened at ride height with full weight upon it.
beer
Re: Urethane shackle bushings. [Re: Dons Dart] #2001073
01/29/16 11:42 AM
01/29/16 11:42 AM
Canada
Canada
All comments are food for thought.The thing i had had no experience with that kind of bushing.Thanks all.
Re: Urethane shackle bushings. [Re: Dons Dart] #2002244
01/30/16 09:58 PM
01/30/16 09:58 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Had a customer complain that there M.B. C-class didn't feel the same after having front end bushings replaced so I pulled the car onto a drive on lift & resettled all the bushings you could see them snap back into there correct positions & the car felt & drove normal again.too many mechanics don't tighten bushings @ the proper ride height.
Re: Urethane shackle bushings. [Re: Dons Dart] #2002529
01/31/16 09:46 AM
01/31/16 09:46 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
The difference with poly and rubber bushings is that poly bushings slide (hence the thick silicon grease) while rubber bushings twist/deform in operation.
That's why rubber bushings need to be tightened at rideheight.
