Re: Urethane shackle bushings.
[Re: Dons Dart]
#2000473
01/28/16 03:18 PM
01/28/16 03:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Poly shackle bushings can be tough to install, first if you didn't use a grease specified for poly bushings, the petroleum that your using may degrade the bushing, so it may fail later on?
put a slight bevel on the end of the bushing end that will be going/pushed into the frame tube, install the bushings on the shackle, put the whole assy in the freezer overnight, then upon assembly, lube the frame tube and the bushing entirely with a light film, assemble quickly while still frozen
the second alternative, is to freeze just the bushing, then install that in the frame tube first, let it thaw to room temp, then install the shackle, either method will work, I generally prefer to install the bushing in the frame first
[Re: Dons Dart]
#2000476
01/28/16 03:21 PM
01/28/16 03:21 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
If you have a large enough vise or a shop press - you can get press them in. Lots of lube helps too, (That's what she said!)
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: Dons Dart]
#2000541
01/28/16 04:57 PM
01/28/16 04:57 PM
19swinger70
Richmond, Indiana
The shackle will move fine- trying to move them with your hand or arm v.s. the mechanical advantage of the suspension is totally different. I have the poly bushings on my Dart - and there are no problems. Had them for 10 years or so.
[Re: mikemee1331]
#2000612
01/28/16 06:58 PM
01/28/16 06:58 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
calm down Michael Scott LMAO... (Urethrathane in the back of a '71 Ply B-body... No issues in 20 years...)
[Re: Dons Dart]
#2000628
01/28/16 07:10 PM
01/28/16 07:10 PM
Posts: 4,457 Washington
madscientist
Washington
I think at some point I'm just going to make some bushings from aluminum. Seems like a better idea to me.
[Re: Dons Dart]
#2000664
01/28/16 08:01 PM
01/28/16 08:01 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Put a bolt/nut through the bushings and tighten nut to pull them into the frame.
[Re: Dons Dart]
#2000715
01/28/16 09:36 PM
01/28/16 09:36 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
no problem with the ones in my 65 B body.been in for years.Didnt have any problems installing them either.Rocky
Chrysler Firepower
[Re: 19swinger70]
#2000941
01/29/16 02:37 AM
01/29/16 02:37 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Lots of lube helps too, (That's what she said!) Funny! These bushings do squeak too! I greased mine years ago but it is sounding like I need to redo it.
[Re: Kern Dog]
#2000956
01/29/16 02:49 AM
01/29/16 02:49 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Lots of lube helps too, (That's what she said!) Funny! These bushings do squeak too! I greased mine years ago but it is sounding like I need to redo it. Usually the only reason I find that poly bushings squeak, is that the wrong lubricant (most petroleum products are harmful to the longevity of poly bushings) was used installing them, or the components/bushing were tightened with the suspension at any angle other than at ride height, not tightening the bushings/components at ride height will either result in a bushing with a severe torsion twist to it, or a torn/fractured bushing, either way...squeaks (can happen with OEM rubber components as well) Mike
