Re: Hydrolock
[Re: twayne24365]
#1997956
01/24/16 09:52 PM
01/24/16 09:52 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I would check the oil to see how much fuel is in it.
"Just a Bracket car dressed up like a streetcar"
Re: Hydrolock
[Re: twayne24365]
#1997985
01/24/16 10:29 PM
01/24/16 10:29 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Change the oil if it smells like fuel (even if it doesn't if it was mine). Fix the carb, float heavy, trash in the needle/seat, fuel pressure, etc.
Did it hydraulic when you tried to start it? Did it turn over? I had epoxy fall out of an intake port and fill a cylinder with water one time and didn't know it. Engine hesitated and then started before I knew what had happened. Bent a rod. Something to keep in mind.
Re: Hydrolock
[Re: twayne24365]
#1998336
01/25/16 01:36 PM
01/25/16 01:36 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Hydro lock would be when you are trying to compress fuel and the engine won't turn over. Sounds like a bad float and it just flooded until it shut off.
Without Data, you’re just another guy with an opinion.
Re: Hydrolock
[Re: twayne24365]
#1998566
01/25/16 07:16 PM
01/25/16 07:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Also,could it be possible that those 2 cylinders were not firing? Causing those 2 cylinders to flood? It might add to it but those cylinders would keep pushing out the fuel during the non firing... you have a float, N/S issue and possible power valve gasket issue.. with the one bowl full it sounds like a N/S issue ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Hydrolock
[Re: twayne24365]
#1998579
01/25/16 07:40 PM
01/25/16 07:40 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Thanks guys, I'll pull the carb and check get it all cleaned and checked out, one other thing, when I pulled the coil wire to turn it over the coil was arching from the + terminal to the coil tower, its an msd 6al and blaster 2 coil ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif) PLEASE, disable the ignition if you are clearing a flooded engine by cranking it and spraying fuel around or dealing with a fuel leak, etc. Bad things can happen.
Re: Hydrolock
[Re: CMcAllister]
#1998586
01/25/16 07:47 PM
01/25/16 07:47 PM
Posts: 181 Maryland
twayne24365
Maryland
Thanks guys, I'll pull the carb and check get it all cleaned and checked out, one other thing, when I pulled the coil wire to turn it over the coil was arching from the + terminal to the coil tower, its an msd 6al and blaster 2 coil ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif) PLEASE, disable the ignition if you are clearing a flooded engine by cranking it and spraying fuel around or dealing with a fuel leak, etc. Bad things can happen. Yes! And I now kno why... No nothing caught fire thankfully, but with the cool wire in hooked when I hit the key I saw a spark from the cool + terminal to the cool tower... Then proceeded to completely unhook the ignition
