Hydrolock #1997912
01/24/16 08:53 PM
01/24/16 08:53 PM
Maryland
twayne24365 Offline OP
Maryland
What can cause hydrolock with fuel? Bad carb, Stuck float?
Re: Hydrolock [Re: twayne24365] #1997916
01/24/16 08:59 PM
01/24/16 08:59 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Yes and yes. Also, plugged air bleeds causing fuel to keep syphoning in after shutdown. Maybe metering block gasket sealing issues.
[image][/image]
Re: Hydrolock [Re: twayne24365] #1997925
01/24/16 09:06 PM
01/24/16 09:06 PM
Maryland
Maryland
Ok, cyl 5&7 had gas come out when I pulled the plugs, so I turned it over a few times to get any leftover gas out. I noticed the rear float bowl was completely full, other than check over the carb Anything else I should do?
Re: Hydrolock [Re: twayne24365] #1997956
01/24/16 09:52 PM
01/24/16 09:52 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I would check the oil to see how much fuel is in it.
"Just a Bracket car dressed up like a streetcar"
Re: Hydrolock [Re: twayne24365] #1997985
01/24/16 10:29 PM
01/24/16 10:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Change the oil if it smells like fuel (even if it doesn't if it was mine). Fix the carb, float heavy, trash in the needle/seat, fuel pressure, etc.
Did it hydraulic when you tried to start it? Did it turn over? I had epoxy fall out of an intake port and fill a cylinder with water one time and didn't know it. Engine hesitated and then started before I knew what had happened. Bent a rod. Something to keep in mind.
Re: Hydrolock [Re: twayne24365] #1998031
01/24/16 11:23 PM
01/24/16 11:23 PM
Maryland
Maryland
It was idling then slowly started to die, like you turned off the key. It didn't like abruplty stop, more just died out, after I drained it it turned over freely with no binding, nice and smooth. The oil looks good but does have a slight gas smell, I will definitely change it.
Re: Hydrolock [Re: twayne24365] #1998083
01/25/16 12:39 AM
01/25/16 12:39 AM
Maryland
Maryland
Also,could it be possible that those 2 cylinders were not firing? Causing those 2 cylinders to flood?
Re: Hydrolock [Re: twayne24365] #1998336
01/25/16 01:36 PM
01/25/16 01:36 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Hydro lock would be when you are trying to compress fuel and the engine won't turn over. Sounds like a bad float and it just flooded until it shut off.
Without Data, you’re just another guy with an opinion.
Re: Hydrolock [Re: twayne24365] #1998344
01/25/16 01:40 PM
01/25/16 01:40 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
if you have power valves I have seen the gasket push out and fill the engine.
Re: Hydrolock [Re: twayne24365] #1998392
01/25/16 02:38 PM
01/25/16 02:38 PM
Maryland
Maryland
Thanks guys, I'll pull the carb and check get it all cleaned and checked out, one other thing, when I pulled the coil wire to turn it over the coil was arching from the + terminal to the coil tower, its an msd 6al and blaster 2 coil
Re: Hydrolock [Re: twayne24365] #1998394
01/25/16 02:45 PM
01/25/16 02:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Pull the plugs and turn it over but be prepared!
The gas shoots out with some force.
Re: Hydrolock [Re: GY3] #1998444
01/25/16 03:51 PM
01/25/16 03:51 PM
Maryland
Maryland
I did that part as soon as I pulled the plugs and the gas ran out, I just hope it didn't mess up the cylinder walls or something
Re: Hydrolock [Re: twayne24365] #1998502
01/25/16 04:54 PM
01/25/16 04:54 PM
dogdays Offline
dogdays  Offline
The cylinder walls damaged? No. You didn't run it, what could have been damaged?
The fuel came from the carb. Remember that on top of the fuel in the bowl, all the fuel in the mechanical fuel pump is going to be pushed into the carb because it's the spring in the fuel pump that actually pumps the fuel.
If the engine was misfiring on those two cylinders the fuel would come in and go out with the airflow, at least most of it. It wouldn't have built up to the point of hydrolock.
R.
Re: Hydrolock [Re: twayne24365] #1998566
01/25/16 07:16 PM
01/25/16 07:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It might add to it but those cylinders would keep pushing
out the fuel during the non firing... you have a float,
N/S issue and possible power valve gasket issue.. with the
one bowl full it sounds like a N/S issue
wave
Re: Hydrolock [Re: twayne24365] #1998579
01/25/16 07:40 PM
01/25/16 07:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
panic PLEASE, disable the ignition if you are clearing a flooded engine by cranking it and spraying fuel around or dealing with a fuel leak, etc. Bad things can happen.
Re: Hydrolock [Re: CMcAllister] #1998586
01/25/16 07:47 PM
01/25/16 07:47 PM
Maryland
Maryland
Yes! And I now kno why... No nothing caught fire thankfully, but with the cool wire in hooked when I hit the key I saw a spark from the cool + terminal to the cool tower... Then proceeded to completely unhook the ignition
Re: Hydrolock [Re: twayne24365] #1998587
01/25/16 07:48 PM
01/25/16 07:48 PM
Maryland
Maryland
Coil*
Re: Hydrolock [Re: twayne24365] #1998707
01/25/16 10:49 PM
01/25/16 10:49 PM
IN
ahy Offline
ahy  Offline
IN
One other thing to check is fuel pressure. It may be more than your float/needle valve can handle (~7 psi for Holly, ~5 psi for Edelbrock).
Re: Hydrolock [Re: twayne24365] #1999151
01/26/16 06:12 PM
01/26/16 06:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
All good advice,but check if the throttle plates are open too far uncovering the slots.If they are too far open they can pull fuel from all the circuts in the carb causing flooding.Be careful not to try turning the engine against a flood cylinder,you can roll the rings and damage the ring land or even bend a rod.
Re: Hydrolock [Re: twayne24365] #1999951
01/27/16 07:56 PM
01/27/16 07:56 PM
Maryland
Maryland
Well I cleaned the gunk out of the bowls, replaced the needles and seats, let the oil drain over night. Put new oil and filter in, also a new fuel filter. Fired right up and ran like a top!, that is guys!
