B-1 users please step inside.....
#1997711
01/24/16 03:39 PM
01/24/16 03:39 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
It's been a long time in the making however, they are finally available, B-1 intake gaskets in .031", .047" and .062" thicknesses. After researching the available gaskets on the market and finding inconsistency's with bolt hole and port locations I believe we have come up with a very accurate and symmetrical layout for a proper fitting gasket made of the best material available, MicroPore-15 aka MP-15! More new products on the way but please be patient. We suffered a crippling virus last March that attacked our computer system and our back up drive that required us to rebuild our entire business again from the ground up. It's been a BUSY year with more still to do and many lesson's learned! As always, thanks for your support!
Re: B-1 users please step inside.....
[Re: a493demon]
#1997808
01/24/16 06:17 PM
01/24/16 06:17 PM
roadhazard
Akron, Ohio U.S.A.
Sweet I will be buying some in the future. 1 question , do you make a thick VC gasket for the B1's ? I have fabed sheet metal VC and the thin gaskets I had on it sucked in from the vacuum pump. Thanks! To answer your question about the valve cover gaskets..... No we do not offer a "thick" gasket, only .047", thicker is not necessarily "better". Are you having this issue with our valve cover gaskets?
[Re: roadhazard]
#1997988
01/24/16 10:34 PM
01/24/16 10:34 PM
Posts: 1,361 Wild West
M_D
Wild West
Are you 'gluing" the gasket to the valve covers? That's how I do it, then I grease or oil the other side. You may need to re-apply some more on occasion when you have the covers off. It will aid greatly in keeping the gasket from sticking. I can use gaskets for a long time that way, and it saves a lot of time and hassle in the long run.
[Re: roadhazard]
#1998078
01/25/16 12:34 AM
01/25/16 12:34 AM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
FWIW and not trying to take any business away but SCE makes a nice VC gasket for the B1 stuff. Used them for years with no issues.
[Re: sr4440]
#1998359
01/25/16 01:57 PM
01/25/16 01:57 PM
roadhazard
Akron, Ohio U.S.A.
Yes, I guess that would help a bit! B-1 intake gasket part numbers are..... #6420 .031" thick #6421 .047" thick #6422 .062" thick
[Re: roadhazard]
#1998526
01/25/16 05:30 PM
01/25/16 05:30 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Try Cometics also
