B-1 users please step inside..... #1997711
01/24/16 03:39 PM
01/24/16 03:39 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
It's been a long time in the making however, they are finally available, B-1 intake gaskets in .031", .047" and .062" thicknesses.
After researching the available gaskets on the market and finding inconsistency's with bolt hole and port locations I believe we have come up with a very accurate and symmetrical layout for a proper fitting gasket made of the best material available, MicroPore-15 aka MP-15!
More new products on the way but please be patient. We suffered a crippling virus last March that attacked our computer system and our back up drive that required us to rebuild our entire business again from the ground up. It's been a BUSY year with more still to do and many lesson's learned!
As always, thanks for your support! thumbs
Re: B-1 users please step inside..... [Re: roadhazard] #1997757
01/24/16 04:40 PM
01/24/16 04:40 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Sweet I will be buying some in the future.
1 question , do you make a thick VC gasket for the B1's ?
I have fabed sheet metal VC and the thin gaskets I had on it sucked in from the vacuum pump.
Re: B-1 users please step inside..... [Re: a493demon] #1997808
01/24/16 06:17 PM
01/24/16 06:17 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Thanks!
To answer your question about the valve cover gaskets.....
No we do not offer a "thick" gasket, only .047", thicker is not necessarily "better".
Are you having this issue with our valve cover gaskets?
Re: B-1 users please step inside..... [Re: roadhazard] #1997881
01/24/16 07:55 PM
01/24/16 07:55 PM
a493demon Offline
a493demon  Offline
yes
Re: B-1 users please step inside..... [Re: roadhazard] #1997975
01/24/16 10:12 PM
01/24/16 10:12 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Part numbers?
Joe
Without Data, you’re just another guy with an opinion.
Re: B-1 users please step inside..... [Re: roadhazard] #1997988
01/24/16 10:34 PM
01/24/16 10:34 PM
Wild West
M_D Offline
M_D  Offline
Wild West
Are you 'gluing" the gasket to the valve covers? That's how I do it, then I grease or oil the other side. You may need to re-apply some more on occasion when you have the covers off. It will aid greatly in keeping the gasket from sticking. I can use gaskets for a long time that way, and it saves a lot of time and hassle in the long run.
Re: B-1 users please step inside..... [Re: roadhazard] #1998078
01/25/16 12:34 AM
01/25/16 12:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW and not trying to take any business away but SCE makes a nice VC gasket for the B1 stuff. Used them for years with no issues.
Re: B-1 users please step inside..... [Re: a493demon] #1998354
01/25/16 01:51 PM
01/25/16 01:51 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
yes
Check your valve cover for flat. If the clamp load is not evenly applied to the flange surface between the bolt holes this problem can occur. Next I would suggest bonding the gasket to the valve cover with 3M weatherstrip adhesive/gasket cement. Put the cover and gasket on, snug the bolts and allow to cure.
Keep me posted on your results thumbs
Re: B-1 users please step inside..... [Re: sr4440] #1998359
01/25/16 01:57 PM
01/25/16 01:57 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Originally Posted By sr4440
Part numbers?
Joe
Yes, I guess that would help a bit! laugh2
B-1 intake gasket part numbers are.....
#6420 .031" thick
#6421 .047" thick
#6422 .062" thick
Re: B-1 users please step inside..... [Re: roadhazard] #1998526
01/25/16 05:30 PM
01/25/16 05:30 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Try Cometics also
Re: B-1 users please step inside..... [Re: roadhazard] #1998528
01/25/16 05:31 PM
01/25/16 05:31 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
SCE has the best gasket period.
Thick and dont leak
Re: B-1 users please step inside..... [Re: roadhazard] #2000008
01/27/16 09:05 PM
01/27/16 09:05 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Good to know!!
Casey
