1978 Ramcharger with tilt wheel. need turn signal parts #1996547
01/22/16 08:27 PM
01/22/16 08:27 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Trying to fix my 78 Ramcharger steering column turn signal switch . Looking on line and reading reviews cant seem to find parts. need some help. looks like rock auto has the switch that has switch/ flasher. but cant find the cam( looks like a cup). they call it the return cam. Where is everyone buying parts ? poor reviews on replacement parts. thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1996567
01/22/16 08:55 PM
01/22/16 08:55 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Look for the same parts for a 78 Chevy truck with tilt.
Worst case you may have to go to a Chevy dealer.
Angry white pureblood male
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: ruderunner] #1996569
01/22/16 08:57 PM
01/22/16 08:57 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
ok i'll check
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1996858
01/23/16 08:46 AM
01/23/16 08:46 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Dodge trucks used the Saginaw tilt column till about 1990 or so.
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: ruderunner] #1996892
01/23/16 11:45 AM
01/23/16 11:45 AM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
the guts in the 78 and the way it was built is sure different than the 2 I rebuilt on my 84 and 86 Ramcharger. Need to try and find that cam return piece. I guess ill try rock auto parts.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1996964
01/23/16 01:36 PM
01/23/16 01:36 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
There is a used one on ebay or there was 2 days ago.
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: 52savoy] #1997221
01/23/16 08:09 PM
01/23/16 08:09 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
still missing this part. cant find. my book calls it the cam assembly. basically it the horn contact ring. Not a lot off parts out their.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1997298
01/23/16 10:00 PM
01/23/16 10:00 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'll check my stash
White socks? You Pollack. No offense, I got my white socks on now...
Looks like someone got happy with a hammer
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: ruderunner] #1997537
01/24/16 06:41 AM
01/24/16 06:41 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
http://www.summitracing.com/parts/rnb-83232
http://www.steeringcolumnservices.com/gm...el-cam-tilt.php
I know NAPA and Carquest and probably most parts stores that have that part and it will usually be in a Help section or where there is a lot of blister packs of common items that need replaced like door hinges, power window switches etc.
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1997681
01/24/16 02:52 PM
01/24/16 02:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take the Dorman number from the Summit site to the local parts store and see if they couldn't get it for you. Most parts stores deal with Dorman products.
Re: 1978 Ramcharger with tilt wheel. need turn signal parts [Re: hulmule] #1997953
01/24/16 09:49 PM
01/24/16 09:49 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
thanks ! appreciate all the help. on to the next problem
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
