Page 14 of 48 1 2 12 13 14 15 16 47 48
Re: Modern Bullitt build [Re: rhamson] #1994390
01/19/16 10:07 PM
01/19/16 10:07 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By rhamson
Good work Pat. I love the way over the top" engineering you are doing on this project. Patience is your virtue.
Thank you Ralph, I hope you're well and move along with your challenge your project?
Pat
Re: Modern Bullitt build [Re: Keepat] #1994794
01/20/16 11:49 AM
01/20/16 11:49 AM
P
PasiR Offline
PasiR  Offline
P
Very nice driveshaft loop!
Re: Modern Bullitt build [Re: PasiR] #1995164
01/20/16 09:56 PM
01/20/16 09:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank You! I'm really happy with how it turned out.
Pat
Re: Modern Bullitt build [Re: Keepat] #1996211
01/22/16 12:23 PM
01/22/16 12:23 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Fit and tack welded the right front torque box. Had to bend the US Car Tool torque box on an angle and added ¼” along the floor side to get a good fit. Both sides will need the same alteration to fit correctly.
Pat
Re: Modern Bullitt build [Re: Keepat] #1996275
01/22/16 02:03 PM
01/22/16 02:03 PM
CJD AUTOMOTIVE Offline
Been watching this one, and it is really turning out nice. Your attention to detail and fab skills is what separates this car from the rest. Too bad most will never notice or appreciate the time and skills required. Keep it up!!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Modern Bullitt build [Re: Keepat] #1996288
01/22/16 02:25 PM
01/22/16 02:25 PM
mopar4don Offline
mopar4don  Offline
I know for one, I APPRECIATE the time you take to show your work! It sure helps guys like me with there build.
Say Pat, can you tell me why your putting the torq boxes in now without the weight of the motor?
Re: Modern Bullitt build [Re: Keepat] #1996328
01/22/16 03:33 PM
01/22/16 03:33 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
The driveshaft/extra crossmember is a fantastic idea and should help give your car roll cage like rigidity with all the extra supports you have installed to shore up the flimsy unibody! I also installed the subframe connectors/ torque boxes in my Challenger without any drivetrain installed. I'm not sure how the factory did this but I am sure it will lessen any amount of frame deflection and movement once the drivetrain is installed.... My car will be put on an alignment rack and setup for optimism performance so I am sure factory specs won't work for me......
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Modern Bullitt build [Re: CJD AUTOMOTIVE] #1996482
01/22/16 06:51 PM
01/22/16 06:51 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you Craig!
Re: Modern Bullitt build [Re: mopar4don] #1996489
01/22/16 06:56 PM
01/22/16 06:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Don, I did install the frame connectors when the car was complete and on the ground, and with the frame connectors installed I didn't see any problem with adding torque boxes when the car was on the rotisserie. It is so much nicer welding right side up instead of upside down ;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: tpabayflyer] #1996490
01/22/16 06:59 PM
01/22/16 06:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I am very happy with the way the crossmember driveshaft loop came out and considering the modification I made to the factory crossmember I think it added a lot more rigidity to the frame. Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2000361
01/28/16 12:06 PM
01/28/16 12:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the parking brake cable pass-through tube in the frame connector. I also remove the original floor mount for the parking cable as I’m going to install a small roller to redirect the cable along the frame.
Pat
Re: Modern Bullitt build [Re: Keepat] #2003881
02/02/16 12:37 AM
02/02/16 12:37 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I had a small section of the driver’s side floor with pin holes that needed to be replaced. I cut about 18” from a new left side floor pan and grafted it along the cross member so it would be hard to tell if it was repaired. Some high-build primer should make any imperfections disappear.
Re: Modern Bullitt build [Re: Keepat] #2004516
02/03/16 12:30 AM
02/03/16 12:30 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Pat:
I personally ignore this thread for periods of time so that I can spend more time looking at more pictures and updates. The work you do is amazing, your creativity and attention to detail are out of this world. I will be both happy and sad when this build is done!
Admiration For Multiple Carburetor Vehicles...
Re: Modern Bullitt build [Re: Stewpar] #2004728
02/03/16 12:08 PM
02/03/16 12:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Stewpar
Pat:
Funny my wife would like me to do the same thing with the build ;-)
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2004748
02/03/16 12:50 PM
02/03/16 12:50 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Cannot wait to see the finished product. This is one of the best threads Moparts has ever had, and the car is certainly going to be one of the nicest anywhere.
Earning every penny of that moderator paycheck.
DBAP
Re: Modern Bullitt build [Re: not_a_charger] #2004960
02/03/16 06:01 PM
02/03/16 06:01 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!!!
Pat
Re: Modern Bullitt build [Re: Keepat] #2004963
02/03/16 06:02 PM
02/03/16 06:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Fitted and welded the last torque box (left front) next up is welding the unused holes in the firewall.
Pat
Re: Modern Bullitt build [Re: Keepat] #2006661
02/06/16 12:53 PM
02/06/16 12:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The RMS suspension requires a few holes drill through the frame and they tell you not to over tighten these bolts so you don’t collapse the frame. So I welded in 2 reinforcements to help prevent that from happening. The 1/8” plate is welded on both sides.
Pat
Re: Modern Bullitt build [Re: Keepat] #2006819
02/06/16 04:34 PM
02/06/16 04:34 PM
USA
Hooligan Offline
Hooligan  Offline
USA
AMAZING work and imagination! What planet are you from???
Re: Modern Bullitt build [Re: Hooligan] #2006834
02/06/16 05:20 PM
02/06/16 05:20 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
LOL, I'm pretty sure earth but some of my friends think it's planet Uranus ;-)
Thank you!
Pat
