Page 3 of 3 1 2 3
Re: At what horsepower do big blocks need a main girdle? [Re: Joey Johnson] #1993787
01/19/16 12:34 AM
01/19/16 12:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I'd say just before this catfight Might have stayed more together
Re: At what horsepower do big blocks need a main girdle? [Re: Al_Alguire] #1993795
01/19/16 12:42 AM
01/19/16 12:42 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ouch!! look's like it turned the oil pan into a garbage can,,,RB block too
Re: At what horsepower do big blocks need a main girdle? [Re: dartman366] #1993803
01/19/16 12:48 AM
01/19/16 12:48 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
B1 heads on a 1977 (440) block would not be something I would do on anything I planned on racing often.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: At what horsepower do big blocks need a main girdle? [Re: Al_Alguire] #1993919
01/19/16 08:57 AM
01/19/16 08:57 AM
Mo.
racerx Offline
racerx  Offline
Mo.
ouch eek.....that hurts to just look at that.
Re: At what horsepower do big blocks need a main girdle? [Re: Joey Johnson] #1994021
01/19/16 12:57 PM
01/19/16 12:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Hope there was a diaper, for both, you and the engine!
Looked at it again and it looks like a mechanical monster vomiting.
Re: At what horsepower do big blocks need a main girdle? [Re: sgcuda] #1994024
01/19/16 01:02 PM
01/19/16 01:02 PM
an8sec70cuda Offline
Originally Posted By sgcuda
Originally Posted By an8sec70cuda
I'm going to test the limits soon of a stock block 440 w/ a stock crank and caps, ARP bolts. The motor is in the 680-700 hp range. Once I get it dialed in N/A, I'll turn on the plate.
Hey Chip
Stock crank and main caps on a 700 hp piece? Plus nitrous? You, yourself, magged my crank at the 600 hp level and said it looked like cracked crystal. And you have to know that the main caps won't live at that power level with spray. Don't you think a set of aluminum caps should be added? We've all seen pics of those #4 caps.
Yep, it will be tough on it I'm sure, but it's gonna happen. Some people have luck with them living...guess we'll see how this one does.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: At what horsepower do big blocks need a main girdle? [Re: TRENDZ] #1994054
01/19/16 01:53 PM
01/19/16 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Answer: They wont hurt at any level.
The question should be, how much power can a bb make without a girdle?
Mine made around 1100hp with modified factory caps and a modified factory crank. No girdle. That engine was a 400 based 470 with turbos. There was a challenger with a procharged 383 making about 1200 with a factory block running around back then also. I can't speak for his internals, cause I simply don't know.
If I weren't so cheap, I would have put a girdle on mine. Here's what it takes to hold up to that power.... (yeah it's ghetto)
I like this idea and was wondering if it could work on an 8 3/4 dr. side kinda like a billet cap............ work
Re: At what horsepower do big blocks need a main girdle? [Re: Thumperdart] #1994056
01/19/16 01:59 PM
01/19/16 01:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you aint making enough power to destroy a stock block you are doing it wrong stirthepot
Re: At what horsepower do big blocks need a main girdle? [Re: Al_Alguire] #1994062
01/19/16 02:06 PM
01/19/16 02:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Obviously I`m not.............Based on some opinions here, I`m probably in the 550 hp range so we`re good for a while.......... beer
Re: At what horsepower do big blocks need a main girdle? [Re: Al_Alguire] #1994214
01/19/16 05:49 PM
01/19/16 05:49 PM
Is that the building, tuning or operating them stock block motors work whistling
Re: At what horsepower do big blocks need a main girdle? [Re: Al_Alguire] #1994499
01/19/16 11:43 PM
01/19/16 11:43 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I think its more like... You're doing something wrong if you're breaking stock blocks at that power level.
I don't deny that given the choice, I would use a "race built block". But then you're using all good internals. Beyond reach for many. The more serious guys on here traveling cross country, with a lot invested in the entire race "infrastructure" would be foolish to use old factory stuff. I totally agree, buuuttttt.... there is a lot to be said for the nobody that can rip off somewhat serious ETs with absolute junk under the hood.
We all play with what we can afford. The so called "bandaids" (don't we all buy and use bandaids? When did they become a bad thing?)help the low budget guys with some ingenuity hang with those better funded. To me, that is satisfying.
Re: At what horsepower do big blocks need a main girdle? [Re: Joey Johnson] #1994511
01/20/16 12:04 AM
01/20/16 12:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If I played with "what I could afford" there would be a bow tie under the hood! laugh2
Re: At what horsepower do big blocks need a main girdle? [Re: Joey Johnson] #1994524
01/20/16 12:18 AM
01/20/16 12:18 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It was not the Hp as much as the added HP from the blue bottle that did that one in. Even moreso the detonation combined with the very large amount of stuff added to it. Was doomed from day 1, but as you say ran what he could afford smile
Re: At what horsepower do big blocks need a main girdle? [Re: Joey Johnson] #1994554
01/20/16 12:34 AM
01/20/16 12:34 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Al, that picture would have been more honest with the last description attached!
I also would suggest that there are better ways to remove the transmission.
Re: At what horsepower do big blocks need a main girdle? [Re: racerx] #2576550
11/09/18 09:25 PM
11/09/18 09:25 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I know a guy that blew up a B motor like that, there was just enough left of the block to support the heads and intake. Even broke the cam out of the block!
Have a great day
Iowan
"obsolete is neat"
Page 3 of 3 1 2 3
