Re: At what horsepower do big blocks need a main girdle?
[Re: Joey Johnson]
#1990097
01/13/16 07:17 PM
01/13/16 07:17 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
No girdle here stock 400 block 12.1.1 comp. solid roller yada yada...........
[Re: Joey Johnson]
#1990115
01/13/16 07:42 PM
01/13/16 07:42 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
Welcome to the board, there is a lot of controversary about main girdle use on Mopar BB Wedge motors do to the perceptions and myths spread by the manufactuers, vendors and some users on here I've seen at least three or maybe one or two more RB and 383 B motors crack the main webbing between the bottom of the cylinder walls into the main webbing, a girdle can't and will not fix that I made a race gas stock 440 block 526 C.I.stroker motor using ductile iron main caps that made 845 HP on a DTS engine dyno in Klamath Falls OR at 4300 Ft altitude in the spring several years back. I used that motor as a dyno mule and sold it to a freind and customer who has not raced that motor yet due to going trough some rough family probelms and then changing living up here to moving to Lake Havasu and that new track not opening yet down there My message is don't waste your time and money on a girdle, put it towards a lot better race block with 4 bolt main caps already cast and machined into it On your deal I would buy and have either Ductile iron or aluminum main caps and ARP main studs installed and align hone for your block I do that on all the stock Mopar BB wedge blocks I build now, I do try to build 400 blocks instead of the 440 blocks now though for anything at or above the pwoer level your shooting for All the stock 400 block main webs are a lot thicker than any of the production 413, 426 W or 440 blocks where Good luck on your build
[Re: Joey Johnson]
#1990177
01/13/16 08:53 PM
01/13/16 08:53 PM
Thumperdart
State of confusion
Hmmm interesting. Well, the 650 horse is a rough guess because I'm going to use the new trick flow 240 head for the big blocks, and a 615/621 lift, 260/264 @.050 duration solid flat tappet from Hughes, at either 10.51 or 11-1 compression. I was reading a forum the other day on here and they had a 470 stroker with the same heads, not sure on cam, but 10.5-1 on pump gas and it made 675 horse @ 6,100 rpm. Im most likely going to use a factory forged crank unless a cast crank will hold up. Id like a forged one though. Can`t speak for a girdle but will say I`ve been runnin the same 413 forged crank for 15 years and looked good on last two freshen ups and I assume I make that much w/my 470. Sounds like a nice combo and welcome aboard.............
[Re: Thumperdart]
#1990220
01/13/16 09:49 PM
01/13/16 09:49 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Girdles for Big Blocks in my opinion are just Band-aids. The things that have helped me are Aluminum main caps and ARP studs everywhere. I have had great luck with BCR caps, I know they sell a girdle as well that ties it all together but I have no experience with them.
I don't know that that combo will make 650HP but it should make good power.
Be careful if you start getting close to 700Hp this is what will happen:
[Re: Joey Johnson]
#1990222
01/13/16 09:52 PM
01/13/16 09:52 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The short/stock stroke will help keep it alive longer, but at 600-650 hp I don't think you are in a dangerous place. I believe in aluminum caps and ARP studs, myself. Stock steel crank should give you decent life for a while. Find someone who can do a decent balance job. Don't skimp on the oiling system. Welcome to Moparts.
[image][/image]
[Re: Joey Johnson]
#1990242
01/13/16 10:26 PM
01/13/16 10:26 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I've seen major cap walk on stock stroke 440's in that power range WITH aluminum rods. It did get spun to 7800 a few times.
Mopar to the bone!!!
[Re: 506RR]
#1990267
01/13/16 11:03 PM
01/13/16 11:03 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
We are making right around 700hp at 512 cubes with ours and we see slight cap walk....We run a girdle, and would highly recommend it at +600hp....We limit rpm and keep a close eye on everything.
We have 335 passes on our combo, and the light cap walk has shown no change from any of the freshen ups. Its been very light, and the rotating assembly still looks like new.
In my mind, rpm is the big killer..so we keep it down at 6400rpm...Granted one day it will let go, but its our race engine and if you race, its just a matter of time until something lets go..
[Re: Dragula]
#1990277
01/13/16 11:15 PM
01/13/16 11:15 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
We are making right around 700hp at 512 cubes with ours and we see slight cap walk....We run a girdle, and would highly recommend it at +600hp....We limit rpm and keep a close eye on everything. Do you use stock caps with ARP studs?
[Re: Quicksilver440]
#1990283
01/13/16 11:20 PM
01/13/16 11:20 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Basically if you need more than studs and aluminum caps...you probably need an aftermarket block. I agree ^^ . At 650 hp with standard stroke it will be fine, buy some BCR ali cap and some ARP studs. I have a 446 LY rod, cast crank engine with stock caps(my first race motor) that has a lot of runs on it and over 150 nitrous passes, best pass 9.69, it has a sleeve due to a pin walking out and wearing through the bore and in that pot is a manley piston that I shaped myself with a grinder to look like the 7 other TRW's That engine is now semi retired running NA 11.00's in my sons Aussie A body .
1963 Plymouth Max Wedge 1971 Barracuda
