1970 Ebody Heater Control Cable Routing - please help #1994374
01/19/16 09:51 PM
01/19/16 09:51 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I am ready to reinstall my assembled dash and I am concerned about the proper routing of the heater control cables (far lower left of dash) to the heat box. Should these cables go over the pedal assembly framework or under the framework? The service manual looks like it is telling me it goes above the pedal assembly (actually through the framework that reinforces the pedal assembly mounting area)but it is not totally clear. Can someone definitely tell me how these cables should be routed?
Thank you,
Re: 1970 Ebody Heater Control Cable Routing - please help [Re: Imrare] #1994386
01/19/16 10:03 PM
01/19/16 10:03 PM
NC
1970A66 Offline
1970A66  Offline
NC
Through the frame work like you described has worked best for me.
The cables "flow" best going through.
Took a quick photo to maybe help you:
[img:center]http://s991.photobucket.com/user/1rebmem/media/DSC00596.jpg.html[/img]
Re: 1970 Ebody Heater Control Cable Routing - please help [Re: 1970A66] #1995162
01/20/16 09:52 PM
01/20/16 09:52 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Thank you for the response. I wasn't able to view your pic as the site was "down" but I plan to go back later and see it. I took a picture of my Cuda to post here, but I don't see the option to post a picture anymore.
Re: 1970 Ebody Heater Control Cable Routing - please help [Re: 1970A66] #1995502
01/21/16 02:16 PM
01/21/16 02:16 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I was able to view your pic today and that is exactly how I thought it should be routed. Thank you.
Re: 1970 Ebody Heater Control Cable Routing - please help [Re: Imrare] #1996235
01/22/16 12:48 PM
01/22/16 12:48 PM
NC
1970A66 Offline
1970A66  Offline
NC
Glad I was able to help.
I think getting those cables routed and connected might be the hardest part of e body dash installation!
