Page 82 of 180 1 2 80 81 82 83 84 179 180
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #1992088
01/16/16 05:59 PM
01/16/16 05:59 PM
fullmetaljacket Offline
LOL.
Once he gets some decent weight off that pup, he's gonna wish those were rolls of toilet paper while going through the traps at a buck55.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1992308
01/16/16 11:54 PM
01/16/16 11:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
There is plenty of meat on them old bones.Pullies get smaller,ET's go down,MPH goes up.I will be adding some weight soon with parachute,engine limiters & "J" bars.Easy diet is the aluminum master with the plasic tank,Aluminum rad and bumper brackets. Been 145mph so this season I will need the chute to keep tech hushed.
I have had this car well over 25 years. Has always been a street car 1st.Still on leafs & torsion whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #1992320
01/17/16 12:06 AM
01/17/16 12:06 AM
Replace some of those bolts holding stuff together and you'll lose more then you think.
Wow, we got our cars at about the same time. 1989 here.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1992590
01/17/16 02:38 PM
01/17/16 02:38 PM
Parts unknown
590 Challenger Offline
Parts unknown
Removal of the inner kick panel structure turned out to be just shy of 2 lbs. Still a long way from the 100 pounds Iā€™m looking to chop by spring
Re: Real world weight loss program and it` cost.......... [Re: 590 Challenger] #1992616
01/17/16 03:00 PM
01/17/16 03:00 PM
Is your car fully roll caged or roll bar?
Be weary of some panels that act as structural.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1992627
01/17/16 03:09 PM
01/17/16 03:09 PM
Parts unknown
Parts unknown
25.3, good for 6.5's, I'll tie some small tubes to cage for support
Re: Real world weight loss program and it` cost.......... [Re: 590 Challenger] #1992894
01/17/16 07:59 PM
01/17/16 07:59 PM
You're good to go.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1993400
01/18/16 04:28 PM
01/18/16 04:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Made another mold. Drivers side 1/4. It weighs 25 pounds like it is. Hope to loose that much over the steel 1/4
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1993540
01/18/16 08:20 PM
01/18/16 08:20 PM
Parts unknown
Parts unknown
Nice, I would be interested to see how much weight is lost, are you going fiberglass or carbon fiber?
Re: Real world weight loss program and it` cost.......... [Re: 590 Challenger] #1993545
01/18/16 08:32 PM
01/18/16 08:32 PM
You surgeons are taking this to a whole other level.
Will it hold up good under wind and speed?
Nice pieces.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1993600
01/18/16 09:41 PM
01/18/16 09:41 PM
Wish I could stamp out pieces like that out of Titanium or aluminum without the expense.
Molded female/male stamps are pretty interesting and a dark art in the home built sense.
Those fiberglass parts are cool to see right out of the pealing off process.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1993610
01/18/16 09:48 PM
01/18/16 09:48 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The mold is stiff as heck. Wind should be no problem.
I use to stamp steal. Aluminum should be doable once or twice in a mold like this.
I would build it a little different if I knew I was going to try and stamp a part in it.
I built a wood die, do my Trans tunnel. Used the tractor bucket as a press lmao šŸ˜
Re: Real world weight loss program and it` cost.......... [Re: FastmOp] #1993675
01/18/16 10:32 PM
01/18/16 10:32 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
How do you make that happen?
What would be different?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #1994079
01/19/16 02:29 PM
01/19/16 02:29 PM
State of confusion
Thumperdart Offline OP
State of confusion
Here`s something I discovered on an 08 328-i BMW.......The alum. bolt holding on the serp belt tensioner is made out of some crazy light alum. and weights maybe a few grams compared to a grade 8 equivalent and is torqued to 25 ft lbs plus a 90 degree turn so MAYBE just maybe we can use alum. after all is some semi-stress areas............ shruggy
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1994370
01/19/16 09:45 PM
01/19/16 09:45 PM
I could see such a bolt and its technology being used as a fastener for a tension pulley with all the advancements in heat treating and fusion of other strong metals.
In this case, it's lateral pressure. I guess a tension pulley is only keeping minimal lateral pressure on the belt to keep it within operating tolerances.
My March pulleys are aluminum, and yet just a tad heavier than the factory steel ones because of the aluminum thickness to sustain such stresses.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1994457
01/19/16 11:05 PM
01/19/16 11:05 PM
State of confusion
State of confusion
What about trans bolts............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1994464
01/19/16 11:14 PM
01/19/16 11:14 PM
As far as trans fasteners and such, I have been running for some time now aluminum trans pan bolts and Titanium trans to engine bolts.
Also have been running speedometer cable housing to trans main body aluminum bolts and a mixture of aluminum/Titanium trans cross member to chassis bolts and trans mount bolts.
I'm about to build an extra trans to have for a spare and will use a limited amount of titanium bolts on the inside.
Maybe the tail shaft housing to main housing mounting bolts will be titanium.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1994496
01/19/16 11:40 PM
01/19/16 11:40 PM
Though most of these can be had from mail orders spots like Mettec, McMasters or Ti-64, here's a stash of aluminum lock washers I found in an old warehouse in Detroit.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1994497
01/19/16 11:41 PM
01/19/16 11:41 PM
Here's the flat stock washers in various ID and OD diameters.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1994557
01/20/16 12:37 AM
01/20/16 12:37 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If your not running full auto cut the park pawl gear teeth down to 1/4" thick. Then trim the main section just after the 1st governor seal ring groove. Eliminate the governor assy. Cut a new snap ring groove in the shaft and your done. You can get 1 lb out of the sun shell also.
Doug
